Question about Epson Stylus RX500 All-In-One InkJet Printer
Epson RX500, Paper Jam - printing couldn't start
Everytime when I try to print. It starts normal, but when the paper starts to move, everything looks fine, paper moves straight in, then paper just stop in the middle before the printing job start, and it shows Paper Jam everything still looks fine at this point, the only thing is the printer says Paper Jam, and I cannot print anything.
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button, applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Posted on Jan 07, 2009
How to Fix Epson Printer Error code e-01.
Unfortunately the E-01 error can indicate a hardware failure with the unit that requires repair. Either a paper sensor has failed or the printer board has gone bad, please try these hard reset steps:
Sharply unplug the printer from the wall outlet while it is still on, and disconnect it from the pc if connected there
Remove all paper from the paper feed and blow it out with compressed air a few times > With a flashlight look in the paper feed
Make sure there is no foreign object like a paper clip > Blow some compressed air inside the printer as well to remove excess dust > Very carefully double check on the far left and right sides of the printer (Where the printhead moves back and forth) to make sure no paper has jammed up in there as it often does.
Still have issues, feel free to contact Epson Printer Customer Support +1800-243-0019...
Apr 13, 2017 | Epson Office Equipment & Supplies
Hi My epson RX500 is not taking the paper, tries but then goes to paper jam
Try putting less paper in the tray. The paper you are trying to use mauy be too heavy a bond (to thick) for your printer to use.
Refer to the manufacturers user guide.
Feb 27, 2015 | Epson Stylus Photo RX500 Printer
Red light blinking
ok this looks like a paper jam, usually a paper jam is shown by a flashin light.
open the printer and check to see if any thing is obstructing the inners of the printer, turn power off whilst doing this.
if nothing is in the printer and it's still doing it message me back and i'll go through a few more options with you.
all the best
Nov 09, 2013 | Epson Stylus RX500 All-In-One InkJet...
Epson Photo PX710W Unable to print on photo glossy paper. Always a paper jam message. Will print fine on ordinary paper. (Will print 6x4 size on upper tray). Help!! Geraint.
Im having the same problem, will print on normal paper but when I try to print onto Glossy paper it comes up with paper jam,or paper not loaded properly is anyone else hjaving this problem? Please help!!
Caroline.
Aug 25, 2010 | Epson Office Equipment & Supplies
Epson Stylus Photo R425 will not print. Screen says "Paper jam" but no paper is visible. All docs. have been cleared from the document queue. A whirring sound occurs when trying to print. Any advice...
Please turn-off your printer and disconnect from PC then get a flashlight and try to look inside the printer starting at the paper loader mechanism. Try to look for paper or any materials that could have blocked a sensors path. Often this are not easy to spot and difficult to remove.
Contact me if this doesnt work.
Jul 22, 2010 | Epson Stylus RX425 Multifunction...
Roller Marks
Try this to clean the rollers:
Put in blank sheets of paper in then print out from microsoft word a blank document.
This should clean the rollers. Also, there might be special cleaning sheets that you can purchase from Epson.
Oct 29, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson cx7800 error e-04
make sure the ink cover was down tight. Shut down the printer open it up and resecure the ink cover. That has fixed this error in many a case.
Jul 31, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Epson RX520 dont print the full picture
It's a problem with the paper not feeding straight. The printer will make a pass & sense the width of the paper & print accordingly. If it feeds in crooked then it sees it as being narrow & only prints to that width. Happens more easily with heavy photo paper.
Apply a bit of pressure to the paper as it feeds & it's happy days.
Feb 20, 2008 | Epson Stylus RX500 All-In-One InkJet...
Screeching sound
If you haven't already done so, look into the printer roller areas, and look for a piece of paper stuck somewhere, or maybe a paperclip or other foreign object which has found it's way into the mechanicals. Also, check the printhead assembly for free movement.
Apr 26, 2007 | Epson Stylus Photo RX500 Printer
Epson Stylus RX500 All-In-One InkJet Printer Logo
266 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
