Question about Sharp AR-M207 All-In-One Laser Printer
SHARP AR--M207 Error L4-11
The shows this error L4-11 call for service, this has happened before but sorted itself out ?
  • Sharp Expert
  • 316 Answers
1. Main motor lock detection
2. shifter motor trouble
Posted on Jun 01, 2010
Why is error 09 still happening after disconnection aerial and power for 10 mins?
I hope it's fixed itself (sometimes those are software glitches)
May 10, 2015 | Televison & Video
My intex spa shows error 96 and 143 degrees F. water is cold
well first the manual should say what a error 96 is but i'll save you the trouble , the control is saying heater failure as the water should never be 143 degrees this would burn/kill you if you got in , id look at temperature probe 1st (its in pipe right past the heater ) and next id look at control itself , sometimes water intrusion dammage in controller makes for some "funny" and wrong things to happen
Oct 12, 2014 | Intex Pool & Spa
Wurlitzer W 64 Coke Machine
Most likely main control board is defective contact manufacture for service manual for trouble shooting the unite
Dec 06, 2013 | Wurlitzer W 64
Not working error showing
another way to determine what sort of error occurred try control panel administrive tools then select event viewer select application scroll to the date that the error occurred it should be in red right click select properties you will see the type of error the date which it happened and an address for help and support and more information by selecting system then properties will do a similar task
hope this helps
Nov 30, 2010 | Computers & Internet
Error 33 cannot connect to activision matchmaking
Don't worry, happens from time to time is just when they are doing stuff to the servers or making updates. Will sort itself out.
I've got cod5 and I get the same, the Playstation network is just a bit dodgy, lets hope they sort themselves out before
cod modern warfare 2!
Jul 01, 2009 | Activision Call of Duty 4 Modern Warfare...
Call service
Shows ASIC error. Unplugg the copier, wait 30 seconds and turn it back on again. See if the error appears. Does this error code happen when you turn it on or when you print something to it?
Aug 02, 2008 | Sharp AR-275 Copier
Error Message with D70 when pressing Shutter
No quick fix on this one... mine is fully jammed now, was sporaic previously.
Best option is to get it serviced or upgrade like I did...
Apr 27, 2008 | Nikon D70s Digital Camera
Sharp AR 250 with error code H5-01
SHARP AR250 H5-01 Papersensordefective in the fusing unit
Normally you can clean the build up of toner off the sensor, and it'll sort itself out. It also could happen by having 5 paperjams in a row.
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Feb 25, 2008 | Sharp AL-1641CS Laser Digital Copier
Tv switches itself off then back on again
Hi.
If the tv set is still under warantee get it sorted before gtee runs out.
The problem is caused by cummunication error between ATV Micom and DTV Micom.
To correct this problem requires going in to service mode to make changes & updating the DTV firmware.
This will need to be done by a proffesional.
http://dysonmanuals.llc.nu/
Chris.
Jan 02, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Sharp AR-M207 All-In-One Laser Printer Logo
2,374 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
