Question about Nintendo Wii Console
Cannot connect console to internet to see weatherforecast & news
I used to used my wii console to check weather forecast and news but today cannot error code 52030 myu internet connection is fine need help please thank you
    Genius:
  • 1,234 Answers
Error Code: 52030 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. If your connection was working previously, try power cycling your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. (Some routers may lose their connection to the Wii console while it is in Standby or turned off for a period of time. Check with your router manufacturer's website for the latest firmware, as there may be an update that will help prevent this issue from occurring in the future.)
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Posted on Aug 27, 2010
Getting an error code 109139 how can i fix this ????
According to Nintendo it means your WiiConnect24 is not enabled.
"WiiConnect24 allows the console to receive downloads even when the console isn't in active use, as long as it has a working connection to the internet. The types of information that can be received include News and Weather, messages posted to the Wii Message Board, and any messages sent by Nintendo about new Wii console features."
Fix Problem: To Access the WiiConnect24 setting:
  1. Access the Wii System Settings (How To Shown Below)
  2. Move the cursor over the blue arrow on the right and and select it once to reach System Settings 2.
  3. Choose "WiiConnect24.
How to Access the System Settings
  1. With the Wii console properly connected, power on the console to reach the Wii Channel menu.
  2. Use the Wii Remote to move the cursor over the "Wii" button in the bottom-left corner of the screen and press the A Button.
  3. From the main Wii Menu and System Settings screen, use the Wii Remote to move the cursor over the "Wii Settings" option (wrench).settings.gif
  4. Press the A Button to enter the System Settings.
Hope This helps Giles102
Sep 25, 2011 | Nintendo Wii Console
What does it mean when you close the wii console and instead of having the red light appear, you have a yellow light?
It means that WiiConnect24 is still active.
WiiConnect24 allows the console to receive downloads even when the console isn't in active use, as long as it has a working connection to the internet. The types of information that can be received include News and Weather, messages posted to the Wii Message Board, and any messages sent by Nintendo about new Wii console features. Click the following link for more information about this.
http://www.nintendo.com/consumer/systems/wii/en_na/settingsWiiConnect24.jsp
Aug 03, 2010 | Nintendo Wii Console
Error code 107305
Error Code: 107305 If your recently received a system update, and use a router that has an SPI firewall that may not be compatible with the Wii console (click here to view a list of known routers), please note that access to the News, Weather and Everybody Votes channels, as well as any channels that utilize the WiiConnect24 feature, may be inaccessible or have limited function with this update. A future Wii console system update is in development that will enable the use of all of the Wii console's online features. Please check back for more information.
If the above information does not apply to you, please try the following steps to resolve the issue you are experiencing:
  1. Our servers may be busy. Please wait and try again later.
  2. Check the internet Connection Settings of your Wii console. If you need assistance, we can walk you through the process using our step-by-step guide that allows you to follow along. Please click here to begin.
  3. Some routers and Internet Service Providers may not be compatible with the Wii console's ability to connect online. Check to see if your router or ISP is incompatible by clicking here.
  4. If you are still receiving this error code after waiting at least 24 hours, and have confirmed your Wii console's Internet Connection Settings are correct, please call for assistance.
    US and Canada: 1-800-255-3700
    Latin America: 1-425-558-7078
Jul 02, 2010 | Nintendo Wii Console
I cant find the code for the internet
right to set up the internet you need to go to wii settings then find internet then connection 2 set it to wireless then search for your router then input you security code which is marked as wpa-psk or wep key then it should run and it will upgrade its self then will jump back to the wii menu but then you should be able to access the wii channel weather news and others
Jan 22, 2010 | Nintendo Wii Console
When trying to connect the Wii to a wireless internet, where would I be able to find the SSID on my computer or modem so that I can get the forecast and news on my Wii. Thank you
go into internet settings or wireless networks on the control panel and jus search in the advanced folder for the SSID it should be in advanced :) hope this helps
Oct 21, 2009 | Nintendo Wii Console
Getting error code 107305; unable to connect to linksys router
Oct 07, 2009 | Nintendo Wii Console
Wii internet
This disc slot of the Wii console will illuminate to indicate that you have received new information from WiiConnect24.
  1. Access the Wii System Settings (how to).
  3. Choose "WiiConnect24."
The following options will be available:
Jan 08, 2009 | Nintendo Wii Console
ERR!!!
i went to the support.nintendo.com and it helped me out lots by telling me what to do !!! i suggest it to anyone with a problem with their wii or any nintendo device !!!
thanks for asking !!!
cowy-moo608
Nov 09, 2008 | Nintendo Wii Console
Nintendo wii to pc
How do you mean "connect" to your PC?
If you mean you want to connect to the Internet from your Wii (for updates, Weather, News, etc) using your Dell PC's Internet connection, then you will need to get the Nintendo Wi-Fi USB Connector.
This will let your Wii use your Dell PC's Internet connection (while the PC is on, at least).
If you mean you want to use your Dell PC as a controller for the Wii, or to send/receive data from the Wii, there is no way to do this as far as I know.
Apr 01, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
