Question about Velodyne CT-120 Speaker
Velodyne ct 120 series sub cut out for good
My ct 120 is about 8 years old and it stated cutting out about 4 years ago while watching movies. I could turn it off and then back on and it would come on. It finally cut out for good last week. It has power and I have the sub monster cable. I is connected to a Denon 2801. What could be bad on my sub?
  • 124 Answers
Contact Velodyne for service
Posted on Dec 20, 2009
I have 2 velodyne fsr 12 subs. both were taken out by PG&E power surges. One make a white noise that cuts in and out, but will still play bass when fed a signal, the other makes a loud static sound...
Register and download the manual for free at
Not that it would help.
Is the white noise present in the absence of an input connection, free-floating?
The amps in both of them sound like they
Mar 24, 2011 | Velodyne FSR-12 Speaker
I need an amp for my sub 12
Search for "plate amp" on They have good selection of amps that will work.
Jan 21, 2011 | Velodyne CT-120 Speaker
I have a 2002 Velodyne SPL10BV. I used to leave it on all the time because on auto it would cut out. It would come on late when watching a movie. Like the signal was delayed to the sub. Now the sub...
The problem is in the amplifier section.
This sub uses the same amp the HGS units have. The pre-amp is a lot like the HGS units as well.
The only place you will find to service the unit will be Velodyne.
My guess is that you will need to send the amp section to them.
It is easy to remove, just make sure to mark the speaker leads before you remove them.
For the auto on function.
You may have a low signal to the sub.
If your source has adjustments for the sub output, try setting it up a number or two. Then use the volume control on the subs amp to mach your main speaker volume.
Dec 19, 2009 | Velodyne SPL-1000 Subwoofer
Velodyne sub woofer: Series S Model: VA08BVX10
The volume control pot can be replaced.
Any good quality audio shop or electronics repair shop should be able to fix this.
Nov 17, 2009 | Velodyne SPL-1000 Subwoofer
Gets hot and cuts off have to reset it all the
You did not give the model number
Make sure you have a space around the unit for air flow to the heat sinks.
The amp IC may be going bad. Overheating problems can be hard to pinpoint.
Contact Velodyne for service.
Jul 05, 2009 | Velodyne Audio Players & Recorders
Bostom tweeter cutting out
get a new tweeter. really, if its starting to cut out, or static, then its prabably old and need a new 1
hope i was help :)
Apr 28, 2009 | Car Audio & Video
No sound for Velodyne ct-100 sub woofer
Sounds like a dead amp. You could check the xformer output and the amp IC's with a VOM.
These amps do not cost a lot, about $40.00. and are easy to replace.
Contact Velodyne
Feb 25, 2009 | Velodyne CT-100 Speaker
Lost manuel
The Q55 is not a velodyne product
Nov 17, 2008 | Velodyne CT-80 Subwoofer
My Velodyne CT 80 powered subwoofer does not power on?
Fuse in amp may be blown or the amp is dead
Contact Velodyne, the replacment amp is not very expensive
Sep 03, 2008 | Velodyne Audio Players & Recorders
Velodyne subwoofer
First make sure that the cables are properly connected up. Make sure that the output of the amplifier feeding the sub is working properly and has no faults.
If the above is okay, it is possible that the power supply in the sub, and or the output stage has a failure. In this case the sub will require shop service to have it working again.
Jerry G.
Jun 12, 2008 | Velodyne DPS-12 Subwoofer
Velodyne CT-120 Speaker Logo
433 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Vito Vacirca Jr.
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
