Question about Samsung RS2534 Side by Side Refrigerator
Beeping our fridge keeps setting the temp up and down itself and beeps all day long while it does it
  • 700 Answers
Basically its telling you that it's not maintaining the temperature that you have it set for. if indeed you do have this particular model number contact me and i have the service manual for it.
Posted on Feb 04, 2009
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Fridge keeps bleeping
Mar 19, 2016 | Refrigerators
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jan 20, 2016 | GE Refrigerators
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 10, 2015 | Refrigerators
How do I fix a buzzing sound in my fridge?
Apr 09, 2015 | Refrigerators
My Cyberccool Wine Fridge started beeping a few weeks ago and the temperature keeps flashing between 0 and 13 degrees but keeps beeping. I unplugged it and have just plugged it back today. It has come...
There are several temperature controllers that has sensors that when the temperature has not gone down a degree for 5 or 10 mins. it will make an alarm to tell you there's something wrong. There are also some that if the temperature that has been set is never been reached and the compressor is not shutting off, it will make an alarm to tell you there's something wrong. Basically, in refrigeration, if the refrigerant is low, it takes time for it to reach the set temp. or it never reached at all. Have your refrigerant checked.
Dec 17, 2017 | Refrigerators
Left door of F/P fridge part for a week. Now red light is flashing, beep stopped but fridge not cold enough.
Hello Jennifer;
My name is Peter. I am a retired field service refrigeration technician.
No. Your problem is not defrost.
The normal temperature setting for a freezer is -2 to +2 degrees F. or -18.8 to -16.7 degrees C. The fresh food section should be set at 35-40 Degrees F. or 1.6 to 4.4 degrees C.
Reset your temperature controls to the recommended settings.
Up plug your unit for 10 minute to power down. Plug your refrigerator in.
Jan 01, 2015 | Refrigerators
My fridge is beeping, too
You are most likely experiencing a stuck key issue on the touch pad, the unit is signaling you with 3 beeps telling you there is a stuck key. Part# WR04X10097 approx $183.65. Pleazer Appliance...
May 06, 2014 | GE Refrigerators
Its beeping and there is a d flashing where the fridge temp should be? we had just returned home from a shopping trip and noticed the fridge and some of our plugs was off. the trip switch had been thrown...
you dont say what make it is BUT the unit has got warm enough to start defrosting itself,(hence the beeping)after a full defrost it should start back up no problem.it may take 24 hours to settle down.
Oct 23, 2010 | Refrigerators
The temperature alarm is beeping and the fridge and freezer continue to get warmer.
Hi i have a jenn-air side by side ice & water dispenser and the ice & water bottons keep beeping and flashing, what does this mean
Jan 26, 2010 | Jenn-Air JCD2389G Side by Side...
Samsung RS2534 Side by Side Refrigerator Logo
424 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
