Question about IBM 6400 Matrix Printer
Error 058 Shuttle Jam on an IBM 6400 Matrix printer
Each time I try to print on an IBM 6400 printer I get error 058 Shuttle jam. How do I resolve this issue?
  • harvey_mulen Feb 03, 2009
    Thank you for your help.
The most likely cause is the printhead is tootight.Pull the multiple copy lever on the right hand side back from "A"towards "C"..Keep trying that and it may fix the error code. Now find the real problem. Something may be obstructing the movement of the shuttle asm or the sensor on the shuttle motor may be bad or unplugged. I've never seen one become unplugged on its own but I have forgotten to plug it back in after having the shuttle out of the machine.
Posted on Mar 04, 2009
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 25, 2009
Where we get IBM printer model 6400 010 print head ?
Its not really a print head, its a shuttle assy, The shuttle takes individual frets are you looking for the frets or the whole shuttle assy? What ever you are looking for i would need the shuttle part# in order to get you the correct shuttle of fret.
Feb 28, 2012 | IBM 6400 Matrix Printer
Keep receiving "End of Forms or Forms Jam on device XXXXXXX"
The problem was due to a block/clogged EOF(End of Forms) sensor. I resolved it by using a can of compressed air to clean/remove any foreign debris from the sensor.
Apr 08, 2009 | IBM 6400 Matrix Printer
Hardware may be
first of all do one thing and that is keep your platen marked A,B,C in b or c position then start printer if it prints then it means your shuttle gets very much tight in position A, for that please switch off the printer remove paper and loose your shuttle and adjust your shuttle according to the movement of paper. also do one thing that is clean your shuttle senser also.
Feb 19, 2009 | Printronix Line Matrix P5005B Printer
IBM 6400-A00 prints normally and stops
GO ON LINE AND TYPE THE FOLLOWING INFORMATION:
IBM 6400-A00 PRINTS NORMALLY AND STOPS ERROR
ENTER
ROD
Dec 16, 2008 | IBM 6400 Matrix Printer
058 SHUTTLE JAM "ERROR"
See this post:
http://www.fixya.com/support/t746596-shuttle_jam_see_manual_problem
Jul 09, 2008 | Printronix Line Matrix P5210 Printer
"Shuttle jam" see manual problem on Printronix line matrix P 500E printer
Verify that there is nothing clamped between the platen and the shuttle.
Last time I had this fault, it turned out to be a broken wire in the harness that connects the CMX board to the shuttle module.
Other possibilities include a failed shuttle or CMX board.
Steve W
LazerTek LLC
Jul 06, 2008 | Printronix Line Matrix P5005B Printer
058 shuttle jam
This can happen for a number of reasons.:-
a. The print mechanism needs to be adjusted ( You'll need a technician to do this if yu are not familiar.
b. Something is clogging the print mechanism, eg Old ribbon residue, or sticky labels etc.
c. The paper thickness lever is set to incorrect setting . Try adjusting it out .
Aido
Jan 18, 2008 | IBM 6400 Matrix Printer
Forms Jam
probably the sensor. The one the paper goes under, lower left front of the machine. Had this loads of times.
Cheers
Aug 15, 2007 | IBM 4230 Model 102 Matrix Printer
IBM 6400 Matrix Printer Logo
1,333 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
