Question about Car Audio & Video
Is this ok?
Hae im running a Kd Sh1000 headunit to RF p4004 its running RF FNX2614 6.5 components upfront and a RF HX2 12" in the back, the hx2 is running 2ohm bridged and in parallel (dual voice coil) with gain up pretty high
is this ok for the amp?
i know its rockford nd i havent had any trouble but yeah just wondering?
thanks heaps
i have a 12' kicker dvc but two cheap mosfet 300 watt amps one is 1 channel other is two channel what positive and which negative do i hook up and
from what amp
  • Jason May 11, 2010
    A better detailed description would help here I think.
    One key point you should know -- the "gain" knob is NOT a volume control. This know is designed to allow the end-user to adjust the amplifier to whatever signal it is being fed. For instance, if you have a Kenwood cd player in the dash that outputs 2 volts down the RCA's, then the gain would have to be set rather high. On the other hand, if you have a Pioneer cd player with balanced 4 or 8 volt outputs down the RCA's, then the gain would be set much lower. If you use the gain knob as a volume control, you will clip the signal sent to your speakers and blow voice coils, especially in subwoofers.
    Through the years I've met alot of people that know how to install amplifiers and speakers. A small handful of them knew/know how to adjust amplifer gain correctly.
    Maybe do a little bit of research on your setup and then come back with some more specific questions? I know that it may sound tedious, but in the end, you will thank me. Your system will sound better and last for years, instead of sounding not so hot and blowing up in a year or less. Do your hard earned money a favor and educate yourself on parallel/series wiring, amplifier gain settings, and installation techniques.
    Feel free to come back to this post and ask more questions, and I'll help you out. =) I won't post this as a solution because its not really one, just more of a getting to know you and your knowledge sorta thing.
  • Boli May 11, 2010
    Sorry, so in a nutshell you have 2 12" subs (1 dual VC) and 2 Amps (1 2-channel)?
    Let me know...
    Matt
  • 45 Answers
Yes it sounds like it should work.
Posted on Jan 12, 2009
Have changed headunit and also speakers..but still got my problem..plays ok till i up the volume then the headunit reboots by itself ... help please
Check the DC voltage at the Yellow and red wire to see whether it falls down when you raise the volume. If you have no meter to check, then buy a battery tester from auto parts shop. If the voltage falls down with volume, check the fuse or contacts in the fuse box.
Feb 27, 2012 | JVC KD BT11 CD MP3 CAR RADIO IPOD AUX...
The radio is getting power and the blue light around the the volume knob is staying on but the rest of the unit isn't powering on
I would try and check two different items. First, using a multimeter or test light ensure that there is correct voltage going to each of the sources and you have a good solid grounding source. Second is trying a reset to the unit.
Nov 11, 2010 | JVC KD-SH1000 CD Player
How to connect a pioneer amplifier to sony cd player in car
easy as matey!
connect RCA leads to the preout in the back of the sony headunit run it down one side of the car into the boot and connect the RCA leads to the amp
You will need to wire in the power earth and remote
Remote lead connects to the BLUE N WHITE wire on back on head unit
Run the power lead and remote down one side of car and the RCA leads down other side which will stop interferance
then just connect the ground and that should be you done
Upfront Audio
May 08, 2009 | Car Audio & Video
Turns on no sound
Check the iso connector at the back make sure the speakers are all plugged in if they are then you have a faulty headunit there mate.
Best solution i can offer is to buy a cheap basic cd player for it
Hope this helps
Upfront Audio
Please rate and leave feedback :)
Apr 17, 2009 | Car Audio & Video
Remote wire?
The remote wire on the jvc unit is blue/white stripe if that isn't there it's the blue wire
Apr 08, 2009 | JVC KW-AVX800 CD Player
Is this ok?
yes 2ohm should be fine for that amp no problem
But dont bridge it any lower than 2 ohms.
Nov 26, 2008 | Rockford Fosgate Punch P4004 Car Audio...
I have a sega genesis. i hae no look how to hook it up. please help me.
well a sega genesis there are 3 different models all either using RF adaptors or AV cables
if RF adaptor please follow this
plug the RF adaptor into the back of your tv the coaxal cable for your tv service ushally runs through this, and plug it into the the back and you can also plug the service into the RF adaptor for the sega genesis. plug the power in and make sure you are on the correct channel (3or4)
If you are using AV cables please advise and I will post the following for that.
Aug 11, 2008 | Video Game Consoles & Games
P4004 - Blown Components
if burned components are on output stage or amplifier section on board..Then look at the oposite side of amp..Both amplifier section should be a mirror image oof componentc from other..that way you can know the values of parts.If they are on power supply section ..Then you might need manual if available..
Dec 23, 2007 | Rockford Fosgate Punch P4004 Car Audio...
Car Audio & Video Logo
115 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
