FixYa.com
Tags:
Sony XM-504Z Car Audio Amplifier
Amp worked fine for 1year, all of a sudden it...
posted by eXiscute on May 25, 2007
I got this set up for a year now, a sony 500w amp with an xplod sony 300w subwoofer ...
I got my battery changed last week and 2 days later my Amplifier turns off, at high volumes, I saw the exact same problem on another post, but the "help" didn't help, or let's say I don't nessiceryly know what a 4 gauge wire and a 8 gauge wire are, and why my setup started doing this just now, after one year! (is my battery giving out too much volts, or too much amps?
it seems to be getting real hot on the outside (like when I put my hand on it I feel a little pain the first touch but after a while my hand gets used of the heat!? is that an overheating problem?
it sometimes happens and sometimes it just doesn't for a while! I don't want to go back to sony and give it for service!? they'd only want more money! I'm even thinking of buying a new one!? please help me!
(It does this also when the device is cold)
I checked the wireing already, and everything seems fine! (I connected the Amplifier to a random MP3 player and had the same problem for a while, and all of a sudden .. it stoppen, and started working normally!)
Comment by eXiscute, posted on May 26, 2007
when it shuts off, it goes into protection mode...
Comment by eXiscute, posted on May 27, 2007
there is another thing!
when I turn off my Radio, or if I lower the volume to 0 ... from vol 1 to vol 0 , my sub does some kinda cracking sound!, is that the grounding?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 06, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I would definately go over all connections....sounds like you have a loose wire. If you are brave take the cover off and have a look for obvious things. I had a problem like that thought it was the amp turned out some corrosion on the post of the radio (was and older unit) I shot some WD40 in the post turned it a few times bye bye crackle
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Thanks for Trying (70)
Guest
Guest
Rating: 0%, 0 votes
litle cance bicose you need the halp end asistans profesional
Can you Help with these Car Amplifiers problems?
Car Amplifiers
genon avr1601
Hi gud day i have genov avr1601... Answer This...
Car Amplifiers
i need a code for a universal...
code for a remote control... Answer This...
Car Amplifiers
schematic for washburn pg 65 c
need schematic Answer This...
Car Amplifiers
NASHVILLE DAB35
CONECTARE Answer This...
Amp enters protection mode at...
Hi! I have 4 speakers (2 6x8... Answer This...
Repair Service
Find Car Amplifier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
