I have green screen solution where now it changed to whole black screen with some red line and produce a sound like TV Signal..I don't know everthings about repair my netbook..What should i do?
The problem is from the ribbon that attach the screen to the main board of the phone, it is not properly connected that is why you do not have display. If the phone should have fallen, then the screen might be faulty. If it did not fall from you, then it means the ribbon of the screen is disconnected from the phone.
First, try to flash the phone, then you open it up carefully. And sit the ribbon that links the screen to the main panel of the phone properly.
And if that does not help, then you need to replace the screen of the phone.
it is possibly you have put it into Cable mode or Video mode or even channel 3. also check and see if the remote has vcr/tv or tv/video you might have pressed this and that is why your tv is blank.
One of two things either the disply has gone out which is likely as it is a common failure for that thermostat or your heating unit is not sending control power. the older chronotherms were system (24volt ac) powered the new hardware/box store units are battery powered. Either way display should not be blank with fresh batteries. to get heat on remove the thermostat jumper or twist together the wire from the R terminal with the wire from the W terminal. note the color of each wire for later reference, heat up house disconnect wires from each other and go purchase a new thermostat
first of all check brihtness control of your screen was adjusted properly and fied with sufficent level.
if ok
then check RAM slot and re fixed it properly.
if stil you have the problem chek disply card mother boadrd and of laptop unit.
