Question about Fedders X Chassis A3X05F2B Air Conditioner
"high" vs "low" dual control
I have a 5000 btu Fedders air conditioner which I purchased last year. The "High" fan or "High" air conditioning doesn't seem to be working. When I put the unit on "High fan" nothing happens, when I move it to "low fan" the system works. When I put it to "High air conditionning" I can hear the compressor kick in, but the fan doesn't move. When I put it on "low" fan or air conditionning the system works fine. I have taken it apart yesterday, cleaned all the parts and cannot see why the "High" options won't work. Any ideas or suggestions? Thanks for your help.
  • Anonymous Mar 26, 2014
    I have a no-24 air condition 26000 btu and the fan isn't working. The fan motor and capacitor is ok. Can you help me?
    President:
  • 1,462 Answers
Could be problem with either switch of fan. try continuity across both legs of the switch then try continuity across the fan windings.
Posted on May 26, 2007
How many btu's does the fedders model # A6X05F2A have?
The unit should have a boiler plate behind the front panel indicating btu's and other electrical parameters. Look for it. Or Google the unit
5000 btu..
Jun 01, 2014 | Fedders A3X05F2A Air Conditioner
My Fedders room A/C model a6u14wta is making weird noises at high setting. What could be the cause of it? I posted a video of the problem http://www.youtube.com/watch?v=nmekh1dsqJU . Noise only comes on at...
Could be your bearing are going bad on your indoor fan but you only hear the sound when you turn it. Could also be something hanging behind it and it only hits the fan when you turn it on high and it pulls it into the fan blades.
Sep 28, 2010 | Fedders A6U14W7A Air Conditioner
Can't find a manual for air conditioner
BTU means "British thermal units" and is a measurment of cooling and heating capacity. Other units are Kw "Kilowatts", and HP "Horse Power".
To convert
Multiply by
To obtain
kW
1.341
hp
kW
3,413
Btu/hr
hp
2,545
Btu/hr
May 21, 2010 | Fedders Q Chassis A6Q10F2A Air Conditioner
My RV AC unit was runs good on high cool last night but this morning it was only running on low fan(some what cooling it Seems)What should I check first. thermostat,fan ???
low medium high speed of fan iscontroled by selector switch on the thermostat or recheck the thermostat if ok check control wirnig from thermostat to the fan relay on control borad and from relay to the motor.
Sep 03, 2009 | Dometic Rooftop RV Air Conditioner
Unit Turns Off
Have you checked the breaker in the breaker box to see if it's tripped? Also check the amp rating on the air conditioner and the amp rating on the breaker the unit is plugged into, the breaker may be weak or not a high enough amps or rating for the unit it's trying to power.
Jul 01, 2009 | Friedrich QuietMaster RS10J10 Air...
Heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
Doesnt work like last year
If you haven't done so, you need to wash both coils. See if that fixes it?
May 18, 2008 | GE Heating & Cooling
Soleus kfr 18gwda
The fan blade can be purchased by calling 1-888-8soleus.
Mar 11, 2008 | Soleus KFR-18 Air Conditioner
Fedders X Chassis A3X05F2B Air Conditioner Logo
217 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
