Question about T-Mobile Sidekick ID Cellular Phone
Side kick id keys
My side kick id key dont work i flip the screen and and the screen dose not move how do i fix this
    Brigadier General:
  • 8,619 Answers
Hi! Try doing the thing mentioned in article below-
http://wiki.sidekick.com/page/SYM+Key-Sidekick+iD?t=anon
If it still doesn't work then go to a t-mobile store (if its a t-mobile one) and they will surely do something and there are chances that they will supply you with a new or repaired one.
Thankyou
Posted on Jan 06, 2009
My dell screen is sideways
On Windows 7, it says graphics options instead of monitor settings.
Typically, to fix this type of error, you would use ctrl+alt+up arrow key to flip the screen right side up.
(incidentally...
ctrl+alt+right arrow = flip to the right
ctrl+alt+left arrow = flip to the left
ctrl+alt+down arrow = flip upside down)
If that doesn't work, or if your keyboard shortcuts have been disabled, right click on the desktop background, click on Graphics Options, then Rotation, then Rotate to Normal.
Also, if you have Intel Graphics installed on you computer, the software might have reset the default rotation setting. To fix this, right click on the desktop, then click on Graphics Properties. This should bring up the Intel Graphics window. Choose Advanced Mode, and click OK. Find the rotation settings (right side, 2nd from bottom), and choose Rotate to Normal.
Feb 11, 2015 | Dell Inspiron Computers & Internet
05 deville no start turn key on dose nothing
hello Allen. Deville leaks in to my Toyota, forum section, oddly?
but
Engine size not stated.
nor if it cranks robustly
if key is dead, and dash dead, and or head lights dead
check all fuses first in the cab and in the engine bay.
always check fuses first. the battery voltage.
bam 10v bad battery ,dead, or discharged, (i charge it and ./...???)_
battery is good and jumper starts fail.
you turn the key to on, the check engine light glows, (and othere)
that is something
then you move key to crank position (start) i will wiggle the shiftlever.
boom is cranks
no it dont so i try starting in neutral. bam , it cranks. over. bad PRNDL switch.
no it dont, so i hit the starter with a hammer, not crazy just tap tap.
no it dont start.
I hot wire the starter solenoid. it cranks (wont start , key in pockets)
hot wire fails,battery good, starter is toast.
hot wire test passes ,cranks nice.
i then grab my trusty DMM and flip dial to Volts.
i then find why my KEY line is dead.
if you get this far, ask how to fix a dead Key line.,
the starter ST key line,
Dec 12, 2013 | Vehicle Parts & Accessories
Drive side power door lock is not working
If the door lock works ok with a key, I would say the lock actuator is failing. Its a small electric solenoid that moves the lock rod.
Jun 26, 2012 | 2008 Hyundai Veracruz
My son's dell Inspiron mini is having problems after sign on. The Desktop and windows that appear after that are reading upside-down and we cannot figure out why it happened. Any advise to get it...
I think that Ctrl+(Alt and/or Shift)+(Up or Down) should fix it. There are a couple of key combos to check, but I'm sure that one of the above will fix it for you.
If the key replys dont work you can go into the advanced settings of your video card and set it there. On my x1400 I can do the same thing in the ATI Catalyst Control Center. Once your in there you can turn the Hot Keys off that will flip your screen like that and you can also flip your screen the right way round.
Steps to get there if you have an ATI video card and ATI Catalyst Control Center installed.
1 - Right click on your desktop.
2 - Select "properties".
3 - Select "settings".
4 - Select "advanced".
5 - Select "ATI Catalyst Control Center".
6 - Select "Displays Manager"
7 - Once the "Displays Manager" tab opens you should see at the bottom tab you should see a box marked "rotation". Set your rotation to 0 degrees landscape.
While you are also in the ATI Catalyst Control Center you can also click on the "Hot Keys" tab and turn the ATI hot keys off that flipped your screen in the first place. John
Feb 08, 2011 | Dell Inspiron Mini 10 Notebook
MY COMPUTER SCREEN IS UP-SIDE DOWN
When the computer screen flips upside down, make sure that you remain calm and cool, this will help you a lot.
Simply press CTRL + ALT + Up Arrow to fix the screen. To prove this works, press CTRL + ALT + any arrow key to flip the computer screen in any direction you want.
Thanks
Have a great day.
Oct 25, 2010 | Computers & Internet
How do i flip my computer screen upside down
1.
When the computer screen flips upside down, make sure not to burst a blood vessel in anger. Try keep checking.Just be calm and you will be able to fix this.
Thanks.
Have a great day.
Sep 16, 2010 | Computers & Internet
My screen on my phone stays black. the music, ringtones,key pad noises, touch screen and phoning people works. basically, everything works but the screen is black all the time. how do i get it to work...
dear,
the strip that connects the keypad with the other circuitry is damaged. you need to repair it or replace it...it will be checked by an expert technician of mobile that either it is to be replaced or repaired...
flip and slide mobile have this kind of problem..moreover, it depends upon the usage of phone for flip/slide...
dont use it roughly, next time , it needs a lot of care..
goodluck..
hope it will fix the issue so dont forget to rate it...
Aug 27, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Motorolav3 help the screen stays black while the key pad turns on
Sounds like a glitch in the software I have seen this before. You can take it to your carrier's store and ask them to re-flash the firmware that should fix it.
Jan 08, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Side Kick Id
A replacement LCD Screen for the Sidekick ID runs from 45-60 dollars. That is on ebay which is the only place I have seen them for sale.
Here is a link for them:
Sidekick ID LCD Screens
Hope that helps out.
Dec 19, 2008 | T-Mobile Sidekick ID Cellular Phone
Round button in middle quits working.
Sounds like you may not be selecting the right menu buttom. The soft keys are right below the screen. these three buttons function change depending on which screen you are viewing. I have copied the instructions from the manual below. You must select phonebook to view the phone book using the round button. You must select volume to change the volume with the round button.
The Standby Screen
When the phone is in standby, the handset display shows the following items:
Handset
Ringer off icon (when the ringer is off)/ day of the week and time / battery iconHandset ID and BannerNumber of new Caller ID calls received (If there are no new Caller ID messages, the Handset ID appears here.) SUN 12:00A Handset #1 New CID: 5REDIALMENU
Using the Four-way Function Key
Your handset has a four-way function key that allows you to move the cursor (or highlighted area) on the display and access the most commonly used features at the touch of a button. By moving this key to the left, you open the Phonebook. Move the key to the right to access Caller ID information. To use this four-way key, place your thumb over the key on the station and move to the four positions to get the feel of how it moves and operates.
Using the Handset Menu
To open the menu, press the MENU soft key. Highlight the option you want by pressing the four-way function key. This will move the cursor; the option currently highlighted appears in reversed out text. Select the highlighted option by pressing the OK soft key. To exit the menu and return to standby, press [].
If you do not press a key within 30 seconds, the phone will time out and exit the menu. When setting Date and Time, the time-out period is extended to two minutes.
Note: For GLOBAL SETUP and DEREGISTRATION menu options, make sure the line is not in use and the handsets are within range of the base. 123abcdefView the phonebook Four-way Function KeyUpView the Caller IDDown123abcdefView •
Jan 31, 2008 | Uniden TRU9480 Cordless Telephone
T-Mobile Sidekick ID Cellular Phone Logo
76 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
