Question about Nikon D70s Digital Camera
Soft or blurry photographs
I have a Nikon D70 with a 18-70 mm lens and a SB 60 flash. I mostly use P mode and have been getting photographs with either soft or blurry images. I reset to factory settings but this did not solve the problem. What could it be. I used to get crisp photos almost every time.
  • Randy Wheatley
    Randy Wheatley May 11, 2010
    tannero,
    Did you shoot in automatic prior to using program mode? If you are experimenting with depth of field?, trying different f-stops you will decrease your background focus and will have the focus sharper on your subject. Let me know what other factors are at work, maybe there's a simple approach to get the sharpness back.
    randy320sgi
  • Randy Wheatley
    tannero,
    Is it a different flash unit or the original? How about when you use the built-in? Have you checked the AF on the lens and camera body? The blurry image in program mode may be the auto focus setting - Is your lens a VR one?
    randy320sgi
  • 88 Answers
I would try using a different lens. Check to see if there are any fingerprints on the lens, it could be dirty. The AF works thru the lens itself so if its dirty, that would cause out of focus images.
Was the camera dropped at any time, if so your autofocusing drive could be damaged. Send an email to Nikon and see if they can repair it for you.
Posted on Jan 08, 2009
Nikon EM (1979?) When I zoom out with my lens, the picture in the viewfinder is very blurry.
What happens when you turn the focus ring? And just out of curiosity, how are you getting to a 30mm setting on a 35-105mm lens?
Jan 28, 2013 | Nikon EM 35mm SLR Camera
How do i turn off m zoom nikon sb 800 and switch back to ttl mode.
Go to menu on camera, then flash/bracketing, then set TTL (through the lens)
then set flash the same
Sep 07, 2012 | Nikon Speedlight SB-800 TTL Flash
What setting should the camera be on for an
That depends on the flash. If it's CLS-compatible (Nikon SB-400, SB-600, SB-800, and SB-900) you can use it in any exposure mode (except flash off, of course). The easiest flash mode is Auto-TTL, though some of the other modes will give you better control under certain situations.
If it's not CLS-compatible, then you'll have to take it off Auto-TTL. If the flash has a sensor, you can let the flash control itself (assuming it's at the same distance from the subject as the camera). Otherwise you'll have to go manual.
May 12, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Please help! I have a nikon d80 with a 18-135 mm
Ask the players to run slower.
Seriously, there are limits. There's only so much light in the gym, you ISO only goes so high, and your lens is only so fast. A faster lens can get you a stop or two. You can try adding more light. Beyond that....
Dec 21, 2009 | Nikon D80 Digital Camera with 18-135mm...
Bakground of the photo is a bit blurry
this is, in most cases, a desired effect (bokeh) which is used to "detach" the subject from the background avoiding the viewer of the picture to be distracted by the background. This technique is widely used in portraits. This effect effect will be more pronounced when the lens is wide open (in your case it should be f/3.5 if I remember well...). To practice you may try the following: set you camera to "A" mode and take one picture of something (it should not be a landscape) using the smallest aperture after this take the same pic using the biggest aperture. With the lower f number you should get a blurry background and with the biggest the backgroud should be in focus!
May 17, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Can you use nikon sb25 flash with d40 dslr?
You can but with limitations;
Save me explaining,please read this http://forums.steves-digicams.com/nikon-dslr/137618-sb-25-d40-non-ttl-auto-mode.html
Apr 14, 2009 | Nikon D40 Digital Camera with 18-135mm...
SB-800 -3EV message after about 50 shots or so
IN THE INSTRUCTION MANUAL USING THE FLASH IN SHOOTING FAST CAUSES IT TO HEAT UP .
TRY USING THE FLASH IN MANUAL AND CUT THE RATIO POWER AND USE AS A FILL AND NOT A MAIN .
YOU COULD ALSO USE TWO NIKON SB800 FLASHES IN ITTL AND WITH TWO THE FLASH IS USING HAVE THE OUTPUT AND RECYCLE TIME IS INCREASED .
DAVE BLACK A WELL KNOWN PHOTOGRAPHER DOES THIS IN HIS SHOOTING .
BERRIE SMITH CAMERA REPAIR
bbmw@bellsouth.net
Nov 13, 2008 | Nikon Speedlight SB-800 TTL Flash
LCD DISPLAY FLASHING
THE REASON THE LCD IS FLASHING IS THIS . yOU HAVE LOST THE PROGRAMING ON YOUR MAIN CPU . WHEN THE CHIP IS REPROGRAMED THEN IT WILL WORK .
Aug 26, 2008 | Nikon Speedlight SB-600 TTL Flash
SB800 under exposure
Hi Stew,
Do the following:
ISO: 400
Shooting Mode: RAW or high JPEG
White Balance: Flash
Camera Mode: M
Camera Shutter: 30 or lower
Lens Aperture: 2.8
Flash Mode: A at 2.8
Flash: Wait until flash fully charged
Now, it's magic!
Send me some money for this tips when you make more money and produces great exposures:-)
Now, you're the top photographer in the town.
You can set ISO to 800 if you are not printing bigger than 8 X10.
Hope above are helpful to you and all photographers.
Alexander
atdlee@netzero.com
Nov 22, 2007 | Nikon Speedlight SB-800 TTL Flash
Nikon D70s Digital Camera Logo
145 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
