Question about ASUS P4S8X-MX Motherboard
AGP problem I used till today an AGP card even if my motherboard has built-in video card. Today, I switched in BIOS the config to the built-in card and of course plugged in correctly the cable of the monitor. The problem is that the monitor is not getting any signal. Monitor is fine, cable is fine, the built-in card worked fine in the first days of usage. Please help me, at least tell me how can i change back the config to my AGP card without seeing the screen. thank you very much
  • scarlat_petr Jan 06, 2009
    I will as soon as I have video signal in my monitor. How can you uninstall something when you can't physical or virtual see it?
    Problem Solver:
  • 7 Answers
You need to uninstall addon card
Posted on Jan 06, 2009
  • hopkinzer jay Jan 06, 2009
    i mean you should physically remove that agp card from your motherboard which you were using before
What is Bluecell
The video card that you choose for your system largely depends on your requirements. If you use applications that are very heavy on the graphics, then you should consider a PCI express video card with SLI capabilities. However, if the most graphics intensive thing you plan on doing on your computer is watching a usb 3.0 pci cardDVD movie, then you don't really need one that's very powerful, any standard one should PCI Express card do. In many cases, you might even be able to make do with the card that came with your system.
If you're interested in purchasing a new video card, then it's important that you examine the current capabilities of your motherboard. usb 3.0 pci express card The older motherboards support only one graphics card at a time through an AGP slot. Motherboards today do not support AGP cards. Today, the new standard is PCI express, usb 3.0 pci card which has recently replaced AGP as the favoured graphics
Jun 30, 2013 | Computers & Internet
Motherboard problem
Jun 25, 2013 | Nvidia Bios Chip:ecs Geforce6100pm-m2...
Weres is the power lead in reset in the p4vxasd2+ elite thank yuo
Since that motherboard comes with built-in VGA, it could be that you have to set the AGP graphics card as the boot video device in BIOS before the computer will use it.
1.) Plug into the built-in VGA port in the back of the computer with your monitor 2.) Power on the system 3.) If you see something on the screen - golden! 4.) If so, enter BIOS - usually by hitting the DEL key, or ESC key etc... Check your motherboard manufacturer's book etc, also it's almost ALWAYS displayed on the screen. 5.) Once in BIOS, scroll through the options but TAKE CAUTION as changing values in BIOS you don't understand could render your computer useless to you in many ways or even brick your CPU or board! 6.) Find where it mentions something about integrated devices or peripherals, maybe something along the lines of video card options etc... Make sure you set the primary boot video device as the AGP port. 7.) Reboot and see if your screen fires up!
Let me know how it goes!
Joe
Feb 05, 2011 | EliteGroup P4VXASD2 Motherboard
Need to know compatible video card for M863G V5.1A AGP1 slotted motherboard.
Thanks for asking FixYa for help. My name is Jeff and I will be assisting you today. You didn't specify your operating system or how much system ram you have. I will assume that you have a 32 bit OS (XP or Vista) and the maximum supported system ram of 2 GB. Here are some AGP cards:
http://www.outletpc.com/video-cards-agp-video-cards.html
And here are some PCI cards:
http://www.outletpc.com/video-cards-pci-video-cards.html
I would tend to go with an AGP card in your case because the board seems to favor that approach. You can go all the way up to 256 MB if you like. Depends on what you want.
Several years ago I used to game with 2 GB of system ram and a 512 GB video card. It was a PCI Express however.
If you are in need of additional help, please let us know.
Thank you for allowing us to help you today.
Jan 20, 2011 | AMD M863G (M863G15CV22ARV000) Motherboard
What agp video card will work with a Soyo p--4vte
One like this one
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3053804&CatId=318
Jun 16, 2010 | Soyo P4VTE (SY-P4VTE) Motherboard
Black screen even the power is ok!!
Your Intel D850MV motherboard uses an AGP video card. There is no onboard video (built into the motherboard). Before replacing the video card try swapping out your monitor with another. Check for display. When the system is powered on can you hear the internals running? If the swapped out monitor does not show display you'll have to replace the AGP video card. The Intel D850MV motherboard only supports AGP cards that run at 1.5volts only & can run at 2x or 4x speed. Intel shows the difference between compatible 1.5v AGP card connector & the 3.3v non compatible video card connector. Click on the Intel link to see this; http://www.intel.com/support/motherboards/desktop/sb/cs-009010.htm This next link shows a compatible AGP video card that will replace your old card; http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4116644&csid=ITD&body=MAIN#detailspecs Thanks for using fixya
Jun 04, 2009 | Intel D850MV Motherboard
NO VIDEO FEED
just connect to your built in video card first , go to the bios next and disable the built in video card, F10 to save your settings , restart your PC. and connect to your geforece.
try it out.
Mar 24, 2009 | Foxconn 915PL7AE-8S Motherboard
Elite P4M800-M7 Motherboard
You could go as high in memory as you can find. You need to stay with the AGP bus though. Newegg has a good bunch of 512 mb AGP cards some even have DDR3 and that caught my attention.They'll set you back between 50 to 100 bucks for the realy good ones.
Nov 29, 2008 | EliteGroup P4M800-M7 Motherboard
AGP installation problems
If you do see the BIOS post but the screen turns black when your OS is loading, then the AGP-card should be OK. HOWEVER, you do need to uninstall your MB-video drivers before installing a new GPU.
Jul 06, 2008 | ASUS K8V-MX Motherboard
ASUS P4S8X-MX Motherboard Logo
96 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
