Question about Zenith R40W46 40" Rear Projection HDTV-Ready Television
Won't turn on
When i press the power button i only hear a few clicking noises and thats it,...then a few seconds pass and i press it again and it does the same thing, no picture no sound nothing
The clicking you here is the mosfet trying to turn on power on the the oscillator then power to the tranformer. The thing with red wire come from the top to a anode splitter. The question is where the power stops. You know it is going to the mosefets but is the trasformer powering the tubs. Email me for anymore questions Christopherclhurst@hotmail.com
Posted on Jun 26, 2007
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
Reset button on a powerbook g4
The Powerbook G4 power button functions like a reset button if you hold the power button in for a few seconds until the computer powers down.
  1. Hold the power button in for a few seconds (until you see the screen turn off/go black and hear the fans & hard drive stop spinning).
  2. Press the power button again to turn your computer on.
  3. If you have more trouble, you may need to boot in Safe Mode or "perform a Safe Boot":
    Press and hold down the "Shift" key immediately after you hear the start-up tone. Release the "Shift" key when the gray Apple icon appears on the screen.
May 02, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My radio turns on but dies in a few seconds, what relay powers my radio ?
Is this a factory radio or aftermarket. is this the radio vw put in or is this a radio you put in,
Nov 18, 2012 | 2003 Volkswagen Passat
Replace bulb in lg dlp projection tv and tv won't come on
Presuming bulb was installed correctly it could be the ballast that powers it.
If possible try to look from outside where lamp is to see if it even fires up for a few seconds.
Mar 22, 2012 | Televison & Video
My laptop went to hibernate and I cannot wake it from that mode. I only have a blank screen.
you have to press the power button once to get it out of hibernation. If nothing else works you can do one of two things:
1] Press and HOLD the power button for about 5 seconds or until you hear the laptop turn off. Then turn it back on again by pressing the power button momentarily.
2] You can DISABLE hibernation. To do this - follow these steps,
  • right-click the desktop and click on and click on "properties".
  • click the screen saver tab.
  • click the power settings button
  • in the power options properties dialog box click the hibernate tab.
  • uncheck the enable hibernation check box.
  • click OK then click OK again
Hope that helps
Good Luck
Feb 07, 2011 | HP Compaq Presario V3000T Notebook
Will not print. turns on lights up makes noise
There are two self tests you can try to test the printer. With only the black cartridge and on sheet of paper. Disconnect the printer from the computer and unplug it. Plug it back in and do the following:
Press and hold the power button. At the same time, press and hold the Ready/Insert button. Release the power button, but keep holding the Ready/Insert button. After 4 seconds, release and press the button again and release. It should print a one page diagnostic test.
The second self print test using all 4 cartridges. Turn the printer on, press and hold the Ready/Insert button for a few seconds and release the button. The test will use all 4 inks.
Jan 02, 2010 | Alps MD 1000 Thermal Printer
My tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Apr 07, 2009 | JVC LT-42X579 42 in. LCD TV
Power on problems
Having to press the power button multiple times before the set comes on is usually caused by low standby voltages in the power supply or bad connections on the printed circuit board. The "D" board is not your problem. Most likely there is bad capacitor in the 9 volt standby supply.
Nov 14, 2007 | Televison & Video
TV won' turn on
Solder, solder, solder! Shut down circuits protect crts to avoid permanent damage. If any of the deflection circuits are defective, or intermittent, shut down occurs. I have not only seen bad solder on deflection circuits, especially vertical, but also intermittent connections on the yokes themselves. I've also seen shorted convergence ics cause shut down. Don't forget solder connections in the power supply.
Jul 05, 2007 | Mitsubishi WS-55807 TV
Zenith R40W46 40" Rear Projection HDTV-Ready Television Logo
105 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
