Question about Bulova Watch
Opening Band of Philip Persio Diver Watch Band
I see that the band does "unsnap" but then will not open. I do not see where you push or unsnap to open the band completely.  I know it "locks"
it is a diver band.
Thanks!
Sandi
  • Arturs Kalnins
    Arturs Kalnins May 11, 2010
    Would be very helpfull if you can upload pics from diferent angles. Verbal explanation does not do much help as there are thousands of band and clasp types.
5 Suggested Answers
SOURCE: my Invicta pro diver watch
I would go to a watch repair shop and ask if the band can be fixed, DON'T ask if they can replace it, I don't know the extent of how bad it is broken, but alot of times it is something that can be repaired. If they say they can repair it try to find out (if you can ) what they would have to do to fix it. Then get back to me .
Posted on Aug 11, 2008
escapement
  • 2334 Answers
SOURCE: AMITRON MENS WATCH NEEDS A LARGER BAND. CAN YOU
Follow this link and find the phone numbers and addresses to get the parts for your Armitron watch (bracelet link is a part as well):
http://www.armitron.com/service_centers.asp
Do not forget to rate, please.
Posted on Mar 09, 2009
escapement
  • 2334 Answers
SOURCE: stainless steel band adjustment
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 19, 2009
  • 8 Answers
SOURCE: link removal from band
if you don't have the necessary tools or knowledge then your best bet is to take it in and have a professional remove the link(s) for you. It all depends but sometimes if you take it to Macy's or Neiman's they will do it for free.
Posted on May 23, 2009
  • 183 Answers
SOURCE: I have an invicta pro diver watch with stainless
I know of a couple places in San Antonio and Austin that would be able to custom fit your new band or help you with a repair.
Precision Time
They are located in the malls in either city. They also have a web site.
PrecisionTimeCo.com
You can try to contact Invicta for new links and they may have them depending on the age of the model. Look at your owners manual for contact information.
Posted on Sep 18, 2009
Testimonial: "Thank you for the help! You were a extraig help."
Need a replacement band for Invicta Mens 4578
with the model number you should be able to find one easily on ebay or amazon. ask the seller any questions before purchase if unsure.
Mar 24, 2014 | Invicta Mens 4578 Russian Diver Collection...
My daughter got the watch as a gift, and we can't get it open for her to put her hand through it. Is there a specific catch or trick to opening the band and make it work? Thanks.
I need to know what model/brand the watch is.
check the sides of the clasp if there is a button. Sometimes it might just be tight and needs a good pull
Feb 28, 2011 | Watches
How do I shorten the mtal band on the Casio 4334. The back of the band has direction arrows but I cannot understand how to move the links. Can you supply me with directions and an illustration to assist...
Push the pin through, in the direction of the arrow. I used a thin paper clip and a pair of pliers. Poke it through by about 3mm and then grab it and pull it out.
Oct 25, 2010 | Invicta Pro Diver 9321 Wrist Watch
I need replacement screws for my band lds philip stein teslar
mcdevito75 here, Best Bet, visit a small watch repair shop in your area for these screws.
Jun 28, 2010 | Philip Stein Teslar Diamond White...
How do i shorten a metal watch band i have a casio 708
Look for removable pins in the band to allow removing one link at a time until it fits ok.
Dec 06, 2009 | Invicta Pro Diver 9321 Wrist Watch
I have an invicta pro diver watch with stainless steel band. I need to buy 2 or 3 links and pins. Would a new band be better and where do I buy either item? Ilive in area code 75601, Longview, Texas. Thank...
Precision Time
PrecisionTimeCo.com
Sep 18, 2009 | Invicta Automatic Pro Diver 8926 Watch
Resizing my watch
screw
small jeweler tools
take to jeweler for 5 bucks they will knock a link or 2 out for you
Jun 12, 2008 | Invicta Pro Diver 9745 Clip-on Watch
Invicta pro diver strap length
ur supose to leave that one open and the rest u can tightin
Jun 10, 2008 | Invicta Pro Diver 9321 Wrist Watch
How to open a ladies rolex watch band
how to open rolex wrist band brand new watch
Oct 03, 2007 | Watches
Bulova Watch Logo
Top Bulova Watches Experts
Geoff
Jimmy Accardi
Are you a Bulova Watch Expert? Answer questions, earn points and help others
