Seagate freeagentGo does not work with windows server 2003
  • Billy Marshall
    Billy Marshall May 11, 2010
    dose the device power up at all, or give an error message. please provide more detail.
    Scholar:
  • 61 Answers
Symptoms The problem I encountered after connecting the drive to the eSATA card was the following error in the Windows System event log:
Source: Disk
Event ID: 7
Description: The device, DeviceHarddisk2, has a bad block.
At first I thought this indicated a bad disk. But eventually I saw apattern: the bad block error only occurred if the drive had enteredits "sleep" state, i.e. had spun down. By default, this happens after15 minutes. If I accessed the drive in Windows explorer after it hadspun down, in the few seconds that it took it to spin back up, Windowswould get impatient and report a bad block error. Note that the "sleep"mode I'm referring to is an internal feature of the Seagate drive--itis not under the control of Windows Power Options in the Control Panel.
If I attached the Seagate drive via a USB cable, let it spin down, and then accessed it, I did not get a bad block error.
Another symptom, one that I did not at first associate with theFreeAgent disk, was the following message in the Application event log:
Source: VSS
Event ID: 12289
Description: Volume ShadowCopy Service error: Unexpected errorDeviceIoControl(\?Volume{ba849e07-88fb-11d9-9c6f-806d6172696f} -0000017C,0x0053c020,00039B48,0,00038B40,4096,[0]). hr = 0x80070017.
This error occurred when I started an ntbackup job. Apparentlyduring Volume Shadow Services initialization, it couldn't immediatelyaccess to the Seagate drive and so logged this error. A bad block errorwas also logged at exactly the same time.
CauseMy speculation is that Windows knows that USB drives may spin down, andit will wait for them to become accessible. However, because an eSATAdrive runs as a BIOS-attached drive (similar to a SCSI drive), Windowstreats it as an internal drive and expects it to be "on" at all times.
SolutionThe solution is to attach the drive to a Windows XP or Vista machine,install the FreeAgent Tools software, go to Utilities, and set theDrive Sleep Interval to Never. Then move the drive back to the server.The Sleep Interval setting is maintained even though the drive ispowered down when moving it to another machine. Once I did this, boththe bad block and the VSS errors stopped.
ConclusionIt's obviously a pain to have to install a 142MB software package justto change the Sleep Interval, but Seagate Support said there is noother way. Too bad they don't make a simple command-line utility forupdating the drive settings. (The software has lots of slickbackup/restore features, integration with Internet drive access,etc.--all kinds of things that I don't need in this environment.) Itried installing the FreeAgent software under Windows Server 2003, butthe installation failed with a message that it only runs under Windows2000, XP, or Vista. Hence the solution of temporarily installing thesoftware on a desktop machine.
I wonder if others have had similar problems with eSATA drives thatlike to go to sleep? Eventually Windows may need to add an option totreat eSATA drives like it treats USB drives. Considering that thisdrive is only used once a day during backups, it would be nice if sleepmode worked without causing errors. In the meantime, I'll hope thatkeeping the drive out of sleep mode resolves the "bad block" errors.
copied from : http://blogs.mcbsys.com/mark/post/Seagate-FreeAgent-Pro-eSATA-and-Bad-Block-Errors.aspx
Posted on Jan 07, 2009
My seagate freeagent goflex 1tb hdd appearing as local disk in my computer... the autoplay dialog window doesn't come up when the drive is connected..
AUTO PLAY DIALOGUE IS OFF IN YOUR OPERATING SYSTEM
ENABLE AUTO PLAY
WHAT OS YOU ARE USING
OR CHECK BELOW LINKS
Windows 7, Windows Server 2008, Windows Vista, Windows Server 2003,or Windows XP
Fix it for meTo disable or enable Autorun automatically, click the appropriate Fix this problem link. Then, click Run in the File Downloaddialog box and follow the steps in this wizard.
Disable AutorunEnable Autorun
Fix this problem
Fix this problem
Oct 29, 2013 | Seagate FreeAgent GoFlex Desk - 1 TB...
I have window server 2003 OS and 500 GB free agent desktop USB hard disk is not showing in my computer. So how can i rectify it?
I just finished a Chat exchange with Seagate Tech support. MS Server OS's are not supported for FreeAgent devices.
It appears that whatever drivers exist in the XP install that recognize the USB device connection are not the same in the MS Server environment.
I plan to check the USB device drivers from both systems and see if the XP USB device drivers will work on Server 2003.
Oct 11, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hi, My desktop does not respond to segate 320GB external Hard disk on windows server 2003 operating system. But it works fine in windows xp . Can anyone suggest me how to solve this . Thanks in...
It must be some driver problem.Try updating drivers through windows update or you can also try installing latest service pack for Windows 2003 Server.It will definitely solve your problem.
Aug 10, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I used ''Drive Wipe'' to completely clean my FreeAgentGo 250GB external hard drive. Now the computer rejects any attempt to access it. What to do? If you are goint to charge for a answer then forget it.
You should try to go to the seagate website and download the free installation utility program, seatools.
It has an option to get your drive ready to go again.
It can't hurt?
Jan 28, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Problem with DG31PR board while loading windows 2003 server.
check HDD and RAM, make sure your HDD new formated
Sep 03, 2009 | Intel DG31PR Motherboard
Freeagent with server 2003 not working
Seems that Seagate did not release a version of software which could be used on a Windows Server 2003 platform. I checked their web site at the following link & didn't find any software supported on Windows Server 2003:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=freeagent-downloads&vgnextoid=3723b5b59b7d5110VgnVCM100000f5ee0a0aRCRD
Sorry, but I can't help you with this one. Try contacting Seagat for this & see if they have a solution to your problem.
Jul 24, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
New install scsi hard disk no detect in ibm x3400 server
you will need to add the new drive to your array bbfore it will how up to be formated do this throught the array configuration util
Regards Al "alstech"
May 26, 2009 | IBM x3400 Server
Does Seagate Free Agent 1TB support Windows 2003 Server
Go to Computer Management. (compmgmt.msc) then to Disk Management and assign drive letters .
u will c ur disk.
Jun 19, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My operating system will not load
Try removing all of the hdds or just leave one that you think it works. See what happens.
Nov 07, 2007 | Dell PowerEdge 2500 Server
Computers & Internet Logo
251 people viewed this question
David Payne
David Payne
