Question about Filter Queen Cheetah II Ash - MU305 Bagless Canister Vacuum
Something stuck in my FilterQueen Vacuum
I have a FilterQueen Vacuum and It stopped picking up so I stuck something up inside the metal tubing and felt something jammed in there..The only problem is I've tried everything to get it out, even sticking something up there but it made it worse. I would really appreciate some help, thanks!
  • LAURA FINLEY May 30, 2007
    your gay
  • Anonymous Feb 03, 2009
    a ballon or glowstick is stuck in filter and temperture keeps dropping
You should be using a broom or mop handle to clear the wand - metal tubing. If you still need help please contact the manufacture at 1-800-344-1840. I did and they were very helpfull, they also sent me a manual at no cost.
Posted on Jul 14, 2007
SOURCE:
Decreased suction for filterqueen vacuum
Put a broomstick or such down the hose, something may be stuck. Look inside with the bag out, is there a screen before the motor?
Dec 01, 2013 | Filter Queen Majestic Canister Vacuum
Vacuum cleaner makes very loud noise when starting to vacuum - like something is stuck in roller area
I'm sorry to hear you're having difficulties with your DC33. The brush control is designed to make a ratcheting sound to warn you if something is obstructing the brushbar. If you've checked the cleaner head and brushbar already, I'd encourage you to get in touch with us directly as we'd appreciate the opportunity to provide further assistance.
You can call us on 0800 298 0298 (UK), or 1-866-693-9766 (US) - please have the machine to hand when you call so we can run through some troubleshooting over the phone with you.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 30, 2012 | Dyson DC33 Animal Bagless Upright Vacuum
I have an Oreck Commercial XL upright vacuum. While I was vacuuming under the bed, I picked up something that must be stuck behind the roller. Not sure how to get the cover off the vacuum to look into...
First thing to check it to confirm that you have a clog. flatten out the bag and turn the vacuum on. if the bag inflates then you dont have a clog. if the bag doesnt inflate then you do have a clog. to remove the clog turn the vacuum upside down you will notice 5 Philips screws that are sunk in the baseplate. if you remove all 5 screws the baseplate can come off just by pulling up once you take it off you will notice a few things. i first suggest removing the belt by rolling it off the roller brush or motor. after the belt is removed you can now take off the roller brush by pulling up on it. now you will be able to look in to the intake pivot which it the peice that is left of the motor that the air flows through. I would look in there if you see something then pull it out if not then there is a step you can take further. remove the 2 motor screws but dont take out the motor. and remove the screw in the intake pivot. now you should be able to pull up on the intake pivot and it will come off. now you can look into the fan from where you just removed the intake pivot. if you see something there then great if not then I would start re-assembly once you have everything back together, turn the vacuum upright and so your facing the black metal tube. unscrew the lower black collar to the left. and then disconnect the outer bag from the metal clip an that same location. then pull staight up on the black tube and that will seperate from the base so you can look in the fanhouing and the tube it self. after clearing it put it back together tighten the collar and clip you outer bag in and your all set!
Sep 19, 2011 | Oreck XL2600 Vacuum
The chrome tubes will not come apart
It's a tight fit to start with, and it's nothing unusual about that if you don't take them apart regularly.
One way to loosen them is to tap the tube that goes in and near the union, with something that won't damage the metal.
Just keep turning the tubes and tapping.
They won''t come apart immediately, but with a little patience they will come apart.
Likely you'll see some rust inside as well.
May 30, 2011 | Henry Numatic "" Canister Vacuum
My extension tubes were put in incorrectly and I can;t unstick them. Suction is not great think something is stuck in tube.
Hello There! I had the same exact problem. Seems something was wrong or stuck in the tubes.
Finally, when I kept trying to clean it out, the tube ripped off and I found a clog of dust in it. So, try getting replacement tubes & it'll work for sure!
I wish I helped you! Let me know if you need anymore help! Don't forget to rate! :)
Jan 14, 2011 | Kenmore 25614 / 25615 Progressive Bagged...
My dyson dc25 pipe has lost suction..is something stuck in the pipe?
We had the exact same issue. Turns out my wife had inadvertantly sucked up a magnet that was the same size ans the tube. Hold the tube up to a light source. If you cannot see any light, there is something stuck in it. To dislodge the item, stretch out a wire hanger and run it through the tube. It should lislodge the item. Dyson's are great but are very tempermental!
May 20, 2010 | Dyson DC25 All Floors Bagless Upright...
When I move my bottom lever from Floor to Carpet
I cannot express enough you need to clean your dyson as great as it is its still a vaccum. look underneath at roller, clean out tube wash filter and check to see if vaccum ate something which is stuck inside. I have had mine for 4years and still picks up after 2goldens and kids.
Oct 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Wand
Do you have a telescopic/height adjustable wand or just two tubes which have to be stuck together? If they are made of plastic well, it may well be broken. If its metal check that the tops aren't corroded or the handle itself isn't broken. If the tubes/wand isn't sliding up and down (i.e. if its height adjustable) then something has got stuck. Sadly for this kind of repair you'd be better off to buy replacement wands or consider something aftermarket on EBAY. Check the diameter of the tubes with a ruler. If it is 3.2cm (32mm) or 3.5cm (35mm) you can buy replacement tubes. If you can't afford that then try furniture polish on a J cloth or similar and with a stick wedge it inside the tube/wand so that it adds a little lubrication or simply a clog - it sounds like there is dirt clogged in the part that slides. Dont forget to rate, thanks.
Jul 26, 2008 | Vacuums
Filter queen 95X (1991) Motor is noisy but still work fine. Can there be a loose screw inside ? Can I open the motor and look inside ?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766802
Generic problem for all Vacuums
Posted by alexun on Jul 10, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The sounds coming from the motor sounds like it is the 2 sheet metal fans that do loosen up and start to make noise; and if you are handy and can do service work yourself you can replace the fans, but make sure you mark the wires when you remove the wire and the motor. If you have questions feel free to contact your local vacuum cleaner dealer in your area or cal the Filter Queen cust serv line listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.filterqueen.com/
Customer Service 1-800-344-1840
custserv@filterqueen.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Filter Queen Cheetah II Ash - MU305 Bagless Canister Vacuum Logo
105 people viewed this question
Top Filter Queen Vacuums Experts
CJ C
CJ C
Marvin
Marvin
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
