Screen does not work
After i begin watching a dvd for about 15 minutes, my screen has a really weird pattern appears on my screen and only audio works
  • Billy Marshall
    Billy Marshall May 11, 2010
    does the whole screen change or just the video stream.
    you may have a currupt video driver, a currupt video decoder, a damaged video card. or if it is an onboard video card you may have damaged ram.
    Please confirm your video adator, the appliaction your are using to play the video, the type of video eg divX or MP4 or DVD.
    also run a memtest. a free CD ISO is avaliavle from here
    http://www.memtest86.com/
    this will boot your computer into a test enviroment and requires to be run for a at least 4 hours to thoughly test your system.
    I reccomend over night.
  • Michael Fisher
    Michael Fisher May 11, 2010
    On What?
    Problem Solver:
  • 6 Answers
Hi
i was also had that type of problem. 1st you make sure that graphic card are installed your pc or not
because in my pc i haddent graphic card. i was installed graphic card in my pc then i never problem again so plz try it
Thank you
Posted on Jan 06, 2009
Why is my Samsung RF26XAERS refrigerator repetitively chiming, and how can I fix it?
NOISE? from the fridge inside? or from the outside compressor? In overstressed compressor or low freon level will make weird noises? a bad fan in freezer will? Even seen bad ice makers make weird noises? if the ice making is hindered by obstructions?
Aug 20, 2014 | Samsung RF26XAERS 26 Cu. ft. French Door...
I brought a audio sonic 24" tv/dvd 5 days ago. today while watching a dvd that i have watched before the screen and sound went all weird. now dvd stuck and says no service when i select dvd mode.
DVD drive section circuit fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 27, 2014 | Televison & Video
StairMaster 4000PT console gets pixalated, machine freezes after 15 minutes of working out
This really still sounds like a console issue. You can check your load resistor just to make sure that is not causing an issue. It should be labeled as to what ohms it is rated as. Simply unhook it and, using a multi-meter, check the ohms. It should be +or- 10%. I am attaching a link to a video on how to use a multi-meter just in case.
Video about Multimeter Testing
Mar 31, 2014 | Stairmaster Exercise & Fitness
??? My LG 50PN4500 TV has a strange one-time issue, I turned it on last night (was on standby) and a full screen "shadow" pattern of squares appeared? They were gray but I could see the colour...
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 12, 2017 | Televison & Video
Question
You might need to clean the lens. They have CDs that will help clean this.
Aug 28, 2012 | Memorex MVD2016 DVD Player
The audio and picture on my vizio vt470m are scrambling and then the whole tv locks up and turns itself off. tried fixing with the "unplug everything, hold power button for 30 sec, and turn back on...
You could have Bad Capacitors on the Power supply board they will be vented or swollow on Top
1000uf 16v 2200uf 10v 3300uf 10v.
PTS they rebuilt boards 1-800-844-7871
May 30, 2011 | Vizio VT470M 47 in. TV
After the dvd plays for like 10-15 minutes(when dvd player warms up?) all the colors on the screen turn to black, yellow and purple for the rest of the movie. What's wrong?
I gotta know more clearly about your question, i am going to explain in 'Guide Solutions'
Guide 1: Is it the color just cover the main grid? (Color cover like blocking the others, such as watching 70s TV shows, the colors blocked in black and white.)
Source 1: Audio input problems, your dvd audio input linked with three different 'rops', they are appeared to be push by pressure.
Solution 1: Determine more spaces to them!
Guide 2: Is it the color cover the photon grid? (Color cover at all pictures, each of them doesn't stand the other colors instead of replaced by unique color)
Source 2: Undefined
Solution 2: The TV setting menu seems to b set by specific colors, change it on your own using remote. OR this is a specific part that the DVD need to show the color in unique color (only one)
(No problems, keep watching)!
Jan 22, 2011 | Panasonic Home Theater System System
Picture looks concave ,mostly yellow,and double vision on words
Remove unshielded speakers or other metallic objects near the TV. It can cause picture distortion.
  1. Tune the TV to channel or cable program.
  2. Run the TV for at least 30 minutes.
  3. Press FLASH FOCUS on the front panel of the TV.
  4. A cross pattern appears and FLASH FOCUS begins to
    work. The adjustment is completed when the cross pattern becomes white and you are returned to the program you were watching.
You cannot perform any other functions until FLASH FOCUS has
completed its cycle. If you perform any other operation while FLASH FOCUS is in progress, FLASH FOCUS operation is canceled.
Oct 30, 2009 | Sony KP-57HW40 57" Rear Projection...
DVD picture jumps -- doesn't track
the lens is bad buy a lens cleaner.
Jan 10, 2009 | GoVideo Go Video DVD/VCR Combo
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
