Question about LG LSC26905TT Side by Side Refrigerator
Damsel in Distress - Fire Hazard?? Please help...
I have a LG GR-L197NIS side by side fridge freezer and having come home from work thought I had a tractor in my kitchen. It seems as if the fan has sheared off and I have reported it to place i bought it and they advise it will be 2 days before someone attends!! The fix it man will clal tomorrow and I am worried that if i go to work tomorrow i will come home to a house that has burnt down because of overheating !!
Can you advise if the fridge freezer still works when fan whizzing round but clearly sheared?????Also is the thing likely to overheat.
  • 700 Answers
Sounds like the fan blade may have started to hit ice inside of the unit. Make sure that the unit is clear of ice by defrsting it manually with either a shop vac reversed or by using a blow drier on the coils inside until they thaw out. good luck with this.
Posted on Jan 06, 2009
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
LG LRFD22850SW light won't go out!
if you stay on the line and dont take no for an answer
they just might cover it for you
make sure you mention several times its a fire hazard
and just dont take no for an answer
Oct 08, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
My freezer is working perfectly but the fridge is not
The channel in the back were the cool air comes down from the freezer to the fridge may be iced up. Try defrosting the fridge/freezer for much longer than usual, all day if necessary.
Aug 30, 2009 | LG LRTP1231W Top Freezer Refrigerator
Damsel in distress level how do i get from the rope to the platform when i press x to let go of the rope he jumps away from the wall and not towards the platform
please see the following link for the complete walkthrough of Damsel in distress level
http://www.gamespot.com/features/6115082/p-6.html
Jul 14, 2009 | Ubi Soft Entertainment Prince of Persia:...
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
Amana ice-maker
Very curious. When you say the tube to the ice maker was disconnected I am unsure as to which tube you are refering to. However hopefully a few pointers might help a damsel. Most units have the water supply enter into the cabinet through a two way water solenoid valve (i.e. one for chilled water one for the ice maker). It then normally enters the top of the freezer section for the ice maker. It then drops down inside the freezer section to the icemaker module. Therefore the only control over the water for the icemaker is the solenoid valve which is controlled by the icemaker "module". A trick is to switch the control at the solenoid valve so that you can use the chilled water dispenser to check if the water valve for the icemaker is working. If it is then you probably have a problem with the icemaker module or the temperature in the freezer section (which you would probably have noticed if that was the case). If you have a problem with the module then you normally have to replace the module as they dont like supplying spares for modules.
Anyway hope this is of some help and good luck.
ps model is normally near the salad drawer or top of the fridge section dependent on brand.
Feb 08, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
LG LSC26905TT Side by Side Refrigerator Logo
149 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
