Question about Toshiba Satellite A135-S4527 Notebook
Motherboard I have a year 4 months with my laptop and now it doesn-t turn on. They tell me I have to replace the motherboard but I am undecided whether it will be worth it or not....or what if I replace it and it goes bad again? What do yoy recomend I do?? Thanks a lot Also can I download word 2007 though the internet ?? Thanks a lot (my laptop is A165 but It is nos showing so I chose A135)
  • 4 Answers
Been there, done that....
1) If your battery has a bad cell (18 months normal life) it could cause this. Take the battery out and see if the system works using just the AC power and no battery.
If it works without the battery get a new one and you are good to go.
2) HOWEVER some systems require the battery to be in place to complete the circuit, so you might have to borrow a "good" working battery from someone if my first suggestion does not work.
3) Finally, sometimes the solder connection for the power connection to the motherboard can be broken by mild abuse or stress from the power cord being pulled at an angle. These typically have three solder points and the one on the back is the most likely to fail.
Summary: If #1 and #2 don't work, get a second opinion, specifically in relation to the power connection to the mother board.
Posted on Jan 06, 2009
I have an ASUS laptop which has been shutting down for the past 1 hour. It has little battery left so I have disconnected pwoer hoping it would go flat.
Asus WHAT laptop?
What is the model number? Bottom of laptop.
Two, is the laptop dirty inside?
If you have never had it cleaned, it is.
Three, "It has little battery left so I have disconnected power......."
Shouldn't have low battery power, if the thing is plugged in.
Four, have you tested the AC adapter's (Charger) output voltage?
Five, is the DC Power Jack in good condition?
[DC Power Jack (DC_IN), is the jack on the laptop that the AC adapter plugs into ]
Could be.........
A) The Battery is older than dirt........
("How old is that battery?
Lemme tell ya,.......that battery is so old that.........")
Battery needs replacing.
B) Power MOSFET's are going south for the winter, and didn't invite you, or the laptop along.
("Pssst..........let's go to the Bermuda's, but xnay on telling the laptop, or dlemaistre)
They control whether the Battery is to have a trickle charge, or full charge; OR, whether the laptop is to just run off of the AC power, and not the Battery.
(Actually the AC adapter {Charger} is a converter. Converts the AC electricity from the home, or business; into DC Voltage.
So it should be stated, ".......OR, whether the laptop is to just run off of DC power from the AC adapter)
Air is used to cool the hardware components inside the laptop.
The two hardware components that give off the most heat, is the Processor (CPU), and graphics chipset. (GPU)
When the Processor overheats it turns off. (BIOS turns it off)
This is a fail safe feature that is built-in.
Keeps the CPU (Processor) from burning up.
So the laptop could be turning off, because the Processor is turning off; due to the laptop is dirty inside.
The battery could be low on charge, because it is old; and not keeping a charge.
OR,
Power MOSFET's are bad, and battery is not being charged up.
Also no power TO motherboard of laptop, because power ends at the DC Power Jack on motherboard; and rest of motherboard isn't receiving power.
Using HP Pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's; to explain,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
So,.......
1) Is the laptop dirty inside?
2) Is the Battery more than 2 years old?
3) Does the AC adapter (Charger) prove to be good?
Putting out the required Voltage?
4) If the DC Power Jack on laptop, is the design that has a Center Pin; does the Center Pin move around, when you try to gently move it with a tool?
(BATTERY removed)
Post back in a Comment.
Regards,
joecoolvette
[If you do not have access to a multimeter, an economical unit can be purchased for around $5.
I have seen them on checkout aisle racks, at major discount stores.
Auto parts stores have them, but usually higher in cost ]
Apr 15, 2013 | ASUS P8P67 LE LGA 1155 P67 SATA 6 Gbps and...
Dell Studio 1737 with Back lit keyboard but Cap Lock Doesn't Light, replaced Keyboard less than 3 months ago, light worked then and went out just recently.
I'd try a different keyboard and see if the caps light works on that - so you can confirm whether it's the keyboard, or computer.
Oct 19, 2012 | Dell Studio 1737 Laptop
My Grandson has a compaq presario V6000' When he turns it on ( either by Battery or Ac connection) the screen lights up for a second. then goes dark goes to windows intro then goes and stays dark. He...
hiya:) My opinion: If you can get someone to give you a free/cheap estimate of the cost to repair I would do it just to find out, but that computer is getting old and maybe is not worth spending any money on. Unless of course you want to fix it to give it to a younger grandchild and buy the older child a new one. Keep in mind a decent laptop is gonna be 4-600 dollars U.S. hope that helps and good luck:)
Jul 26, 2011 | Compaq Presario Notebook
NO POWERE UNTIL 4-5 TRYS
Try hooking up only the power supply connector to the motherboard. That way we can rule out whether its a piece of hardware that is shorting out the motherboard.
If the power supply is still acting up then try another known good working power supply. If it turns on like normal then your original power supply is bad. If the power supply still doesn't turn on then you know at that point the motherboard is bad and would need to be replaced.
May 28, 2011 | HP Computers & Internet
My laptop is year and half old and couple of days back suddenly my laptop's speakers stopped working . i tried all option in the laptop to fix it .its not working.please help.
Steps to be followed:
1. check whether audio driver is installed properly ? if not install audio driver & check
2. check audio setting in control panel & confirm
3. connect external speaker in laptop and check whether sound is coming? if sound is coming then ur laptop internal speaker need replacement
4. if there is no sound in external speaker then need to check ur motherboard or sound card.
All the best.
Aug 16, 2010 | Computers & Internet
Acer Aspire 5920 won't turn on, the charger lights up, (bright green) until you plug it into the back of the laptop, then the light goes dim and flashes.still no power to the laptop,not even the fan.
Your power supply or regulator in you laptop has gone south. sorry no quick fix for this one. It needs repaired and would include tracking down soldered connections.
sorry to tell you this.
clb199@yahoo.com
pls rate me 4 stars
Nov 27, 2009 | Acer Aspire 5920-6727 Notebook
E Machine T6534 fails every 6 to 9 months
This could be caused by the processor or fan,But very unlikely to be the mother board.
May 28, 2009 | eMachines T6534 PC Desktop
Acer laptop won't turn on or off!
if it is a nvidia based motherboard, then i m sure of motherfaulty.
Jan 31, 2009 | Acer (ACERMOTHERBOARD)
Laptop went completely dead
Get in touch with Dell again as the replaced part will be under warranty. You can never tell whether a new or second hand motherboard has been fitted, as manufacturers are able to do either when they repair it, so it just may well of failed again.
Dec 10, 2006 | Dell Inspiron 8500 Notebook
Wireless Switch
From your description I agree, its probably a damaged switch. I never recommend anyone taking apart a laptop unless they are a mechanical whiz, have experience with laptop disassembly or can afford to break it beyond using. As far as turning the built-in wireless card on without the switch there might be a way. I don?t have a Compaq laptop to experiment with, however, my Dell Latitude BIOS settings has a setting to automatically turn on the wireless card at boot-up. Perhaps yours does too, during your laptops initial boot process get into your BIOS setup menu (press F2 or if that doesn?t work F10 keys). Look for an option relating to your built-in devices or wireless device. My Dell setting is fairly ovious: "Turn on wireless device". If you find a simliar option turn it on, reboot and look for the wireless adaptor. Another option may be to buy an inexpensive UPS wireless adaptor. You can pick them up on Ebay for around $30, not as spiffy as the built-in but probably a lot cheaper than paying a repair shop to fix a three year old laptop. Good luck.
Dec 02, 2006 | Compaq Presario 2100T Notebook
Toshiba Satellite A135-S4527 Notebook Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
