Question about Dell Inspiron 1501 Notebook
Cannot identify Battery
When I turn on my Dell Inspiron 1501 laptop, I get this:
Warning: the battery cannot be identified.
This system will be unable to charge this battery.
Press Any Key to Continue.
Press 2 times to enter SETUP.
Press and Any Key to enter Boot Menu.
However, when I press Any Key, it continues to boot and run normal and the battery charges fully.
How can it get rid of the Warning?
  • 2 more comments
  • Anonymous Jan 14, 2009
    I have this same problem but the link provided here does not work, there is no file. I am running XP.
  • fla20 Jan 15, 2009
    i have the same problem a message appears and i press any key and my system work but if i wanna run it on battery it shuts down instantly can you help me solve this problem please
  • umerfraz Feb 23, 2009
    im facing same problem. but if i tap any key to continue, the system works fine, battery charges properly.
  • revbrewm Apr 28, 2009
    I have the same message when I start my Inspiron 6000.
    I tried the download file suggested and got an error message.
    This is the second replacement battery, both new, where I get the "cannot identify the battery" message, while a previous replacement was identified and worked for over a year before this last two can't be identified.
    Does anyone have a solution?
Press <F2> 2 times to enter SETUP.
Press <F12> and Any Key to enter Boot Menu.
what should i do?
Posted on Jan 05, 2011
Please update your system using this file and if this does not work try to reseat the battery and check.
If you are using vista download the file to desktop. Right click. Click on run as administrator. Let me know if this resolves your issue or you need more help.
Thank you
Expert Dell Laptops.
Posted on Jan 06, 2009
My dell inspiron 1501 will charge the battery but as soon as i unplug the laptop turns off.
It's either the battery or charging circuit on the system board. If you have replaced the battery with a new one then it's probably the system board. A new system board could run between $150 to $300. Then there's the coat of labor.
Feb 17, 2013 | Dell Inspiron 1501 Notebook
How can i fix my new dell netbook inspiron mini 1010,when i turn it on there is warning that the battery cannot be identified.the system will be unable to charge this batt
Try to unplug the battery and plug it back well.
Does your battery's power ratings match with your Laptop? Check that information just on your battery, power adapter and on the laptop. If theres any mismatch, please get what matches your laptop.
Otherwise check whether your Power Adapter charges your Battery (Test for power within the Charger). If everything fails, change your battery and ensure it fits your Laptop in terms of Power ratings.
Good Luck!
Jun 24, 2010 | Computers & Internet
Battery Problem with Dell Inspiron 1501
just log on to website enter correct service tag download bios update for the same. and then try to connect cheger and check the things
Dec 22, 2009 | Dell Inspiron 1501 Notebook
Battery Not Identified.
I suggest you a few steps to solve your problem.
  • remove the charger and press the power button till all residue power is radiated.
  • then connect the charger and charge the battery fully and try booting the system.
  • if this don't work check the output of your charger and see if it is working fine.
  • if it is working fine then remove the battery and connect the charger and try starting the system.
  • if it works then there are two things possible.
  1. battery gone.
  2. IC responsible for charging is gone.
i hope you can figure out the problem through this.
Thank you
Aug 07, 2009 | Dell Inspiron 1525 Laptop
I just put a replacement battery on my Inspiron 710M. On startup I get a message that says, "The battery cannot be identified. This system will be unable to charge batteries until this battery is removed."...
This battery is not compatible with this laptop. Dell batterys have a sensor that tells to laptop is it dell battery or not. Unfortunately you have to replace battery with correct one.
Aug 02, 2009 | Dell Inspiron 1501 Notebook
Battery cannot be identified Every time I boot up my Dell Inspiron 1501 I get the following message: "Warning: The Battery cannot be identified. This system will be unable to charge this battery."...
Generally this is an indication that the battery has failed. The normal life span of a PC battery is 300 to 500 recharge cycles (Roughly 12 to 18 months) so the most likely answer is buy a new battery since this one is already out of warranty
Jan 27, 2009 | Dell Inspiron 1501 Notebook
Replacement battery for Dell Inspiron 1501 won't charge
If your old battery was doing the same (not charging), then is is because the charger is not charging the battery. Do you have a friend with a Dell laptop? Maybe you can use a borrowed charger to test and see if it will charge the batteries. To answer your question , no Dell does not have anything built in to prevent you from using a 3rd party battery.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 28, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
7,966 people viewed this question
Alun Cox
