Question about Saeco VIA Veneto Espresso & Coffee Maker
EXPLODING SAECO VIA VENETO
I have a second-hand Saeco Via Veneto which worked a couple of times after I purchased it, then is started exploding meaning the pump explodes out, leaving coffee powder all over the machine, kitchen counter, floor etc. Can anyone tell me the reason for this? Is there a way to prevent this "explosion" from happening again?
  • 515 Answers
I think your machine is overheated, try to replace the thermostat on the boiler.
Posted on Jul 12, 2008
Where is the cutt off security switch located on Espresso Machine Saeco Via Veneto Deluxe?
Have a close look around the outside of the cabinet for a small button or hole. Inside the hole, there may be a button that can be pressed to reset. Not sure about Saeco but I doubt if you have to take the cabinet off to get to a reset button.
Apr 26, 2017 | Saeco Coffee Makers & Espresso Machines
Grinder does not work, keeps blowing fuses! Can I fix it?
You need to return it for repair or buy a new one.
Nov 24, 2015 | Saeco VIA Veneto Combi
I have the via veneto model that has the rubber tube that draws the milk in. It doesn't seem to build enough pressure now to do it. I have been cleaning and descaling it on a regular basis. The expresso...
Hi
There is a pin on top of the cappuccinator the will twist to create suction. Turn it slowly when steaming until it starts to draw milk up to foam. Then leave it. If you don't have the pin, thats your problem.
Jan 02, 2011 | Saeco VIA Veneto Espresso & Coffee Maker
Via Veneto will not prime
Yes, unfortunately the Via Veneto is a difficult machine to prime, however, I have a simple way to prime the pump if you run into this problem. Simply remove the water tank, fill a clean turkey baster with water, open the steam valve fully then mate the baster tip with the water tank flow valve on the espresso machine. Wrap a towel or paper towel around the flow valve/baster tip then inject the water (agressively, but not forcefully). It's works for me every time.
Sep 18, 2008 | Saeco VIA Veneto Espresso & Coffee Maker
Via veneto won't make coffee
I removed the top filter where the water comes out and cleaned it good with a pin for all the holes, then I did the same for the coffee filter. I found alot of the holes plugged which would avoid the from alowing the coffee to come out.
Now it works like new.
May 24, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
Soggy Pucks & Portafilter retains water Saeco Via Veneto
It sounds like you are short on water due to a blockage somewhere...either in the flowmeter or the group head. You might also have a faulty pump, and you're not getting enough pressure during the shot. If you're not getting crema, then it's most likely pressure related...shots will also have a burnt smell and very bitter taste.
Mar 14, 2017 | Saeco VIA Veneto Espresso & Coffee Maker
Saeco VIA Veneto Espresso & Coffee Maker Logo
511 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
