Question about Umax Astra 2200 Flatbed Scanner
Bulb inside the scanner is fused - Umax Astra 2200 Flatbed Scanner
  • 404 Answers
Hello!
I hate to say this but you will possibly find the cost and time to replace the scanning reader lamp will outway the price of a New scanner.
Sorry to be the bearer of Bad tidings.
I hope this helped?
Paul 'W'
Onyer~EDson(:0)~[><
Posted on Jan 07, 2009
Why do interior lights stay on 1998 silverado
well need to sort the buttons on the side off the doors mate be jammed just flick everyone of each door .
Aug 27, 2014 | Cars & Trucks
My 1999 Ford Explorer Sport started blowing the fog lamp fuse. I discovered that one of the bulbs was blown. Well, actually, not blown, but broken inside. The two wires holding the element inside the bulb...
If you still have the bulb do the following , connect your meter, one probe to the bulb contact and the to the metal part of the bulb i am sure one will not show open circuit , but will be earthed through the insulation.
Apr 03, 2017 | 1999 Ford Explorer
Tail light fuse keeps blowing. I have traced the wiring back to the tail lights and it all seems fine. I have taken out the turn signal lights and the light switch, put in to the first position for parking...
Are the bulbs out of the sockets and the fuse blows?
Take bulbs out and check again
Place one back at a time if fuse was OK with bulbs out to locate bad bulb.
Otherwise.......
Do this........if still needed with bulbs out and fuse blowing.
Put a circuit breaker in to replace the fuse of the same amperage.
It will trip off then back on.
Use a standard cheap magnetic compass........place along lighting wiring........the wire with current will cause the needle to jump as circuit breaker trips on and off.
Follow path of current to problem.....the compass will stop moving once past the shorted /grounded wire/connection.
Sep 02, 2009 | 1997 Toyota Corolla
Hp 3055 no lingt on the control pannel, no power up, no warm up, it just like pluck off machine. nothing comes on.. what is the problem? anyone experience it? please give me a hand... thanks
Hi benkoh76: Here is your problem. Troubleshooting checklist Follow these steps when trying to solve a problem with the all-in-one. Step number Verification step Possible problems Solutions 1 Is the power on? When the all-in-one is connected to a grounded power source and is turned on, the control panel shows Hewlett-Packard with moving cursors indicating that the firmware code is loading, and the main motor rotates for approximately 45 to 60 seconds. When the firmware is done loading, Scanner bulb warming up might appear on the control-panel display, and the scan head moves back and forth for 10 to 15 seconds. If you lift the scanner cover, you will see that the scanner bulb is lit. Near the end of this time, the ADF motor turns on for about two seconds. No power as a result of a failed power source, cable, switch, or fuse. 1. Verify that the all-in-one is plugged in. 2. Verify that the power cable is functional and that the power switch is on. 3. Check the power source by plugging the all-in-one directly into the wall or into a different outlet. Motor does not start. 1. Verify that the all-in-one is plugged into a working electrical receptacle. 2. Verify that the print cartridge is installed correctly. Follow the instructions on the control panel to remove and replace the cartridge. 3. Verify that the top cover is closed. ADF motor does not start. Open the ADF cover and remove any orange shipping tape inside the ADF. Verify that the ADF connector is connected correctly to the scanner. If the ADF motor still does not rotate, replace the ADF. Scanner bulb does not light. If the scanner bulb does not light, verify that the wire-harness connectors from the scanner to the formatter are connected correctly. If the error persists, replace the following components one at a time until the problem is resolved: scanner assembly, formatter. Hope this helps
May 30, 2009 | HP LaserJet 3055 All-In-One Printer
Copies now coming out with dark background sharp ar-m 207
Hai vipepheag
Please clean the scanner refflecting glasses,scanner lens,Scan bulb and Laser scaner units
One refflector glass is located at the bottom of scan bulb,another refflector glass is in left side of bottom and top of scan bulb
LSU is located inside and near the Drum units open side it include2/3 refflectors and one lens plean clean it all after problom continued check and condact me kabeercb@yahoo.com now and future
Apr 17, 2009 | Sharp Office Equipment & Supplies
Scanner error message hp laserjet 3030
This problem has to do with the scanner mirror. You may hear a grinding sound, also. The reason it does this is because the scanner bulb cannot find 'home', so it keeps trying to find it. Well, it uses the mirrors to reflect on another object inside the scanner to tell it when to stop. The mirror on top of the right next to the scanner bulb may need to be cleaned. This works every time for me, except the same problem always comes back sooner or later.
how to clean-
1.unplug your scanner
2.notice the glass covering on the left side, it can be removed with a Phillips screwdriver. Unscrew the plastic surrounding the glass and then remove the glass covering.
3.Plug the scanner back in and wait for the scanner to move left and then unplug it before it starts moving to the right. Repeat this until scanner bulb is all the way on the left of the machine.
-an alternative method-
with the glass covering removed, use a pair of pliers to move the small belt that moves the scanner bulb. keep moving it until the scanner bulb is all the way on the left of the machine.
4.With the scanner bulb assembly in reach, grab a Q-tip and gently clean the mirror that is just to the right of the bulb. You might want a flashlight to see the dirt and dust.
5. Put the glass covering back on.
6. Plug in the scanner.
At first to me it seemed like it wouldn't work, but it does.
Hope it helps. Reply back if it does.
Jul 14, 2008 | HP LaserJet 3330 All-In-One Printer
Bliking red light.
sounds like the 'transportation lock', check the lower left hand side corner of the inside the scanner cover and the left-back side
check this out:
http://files.support.epson.com/htmldocs/pr48ph/pr48phrf/maint_3.htm
so far it is not a sign of changing the bulb, plus replacing the bulb may cause more, but if in case, please try this out first.
Jun 22, 2008 | Epson Perfection 4870 PRO Flatbed Scanner
Umax Astra 2200 Flatbed Scanner Logo
44 people viewed this question
Top Umax Office Equipment & Supplies Experts
Tony
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
