Question about Toshiba Satellite A135-S4527 Notebook
MIC OF TOSHIBA....
ITS OPERATING SYSTEM IS VISTA.I DIDN,T TRY IT IN MSN BUT ITS NOT WORKING IN GOOGLE TALK.
What is the security code for toshiba laptops?
Security Code? I didn't know there was one.
Are you talking about a Password? If so, which Password? Bios Password? Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System? Windows XP? Windows Vista? Windows 7?
Apr 20, 2012 | Acer TravelMate 2300 Notebook
I'm trying to figure out how to get my webcam where I can talk on Windows Live Messenger, and I can't figure it out.
First job is to set your webcam mic as default
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
If it fails to work here concentrate on your webcam drivers and software before moving forward.
Set your webcam mic (if it has one as default)
Vista -
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Jun 15, 2010 | GE EasyCam Webcam
I am getting the voice from other end & my voice is not going
Mic issues can be tricky. Knowing what operating system you are using would help diagnose the issue.
First the simple things. Make sure your mic is plugged into the correct jack. It should be red. Second, you need to open your sound mixer and make sure your mic is not muted or the volume turned all the way down. Either of these will cause you not to be heard.
You can also open the sound settings in your control panel, it is the icon that looks like a speaker if you are using Vista/7. Under the recording tab, make sure you see your mic/headphones/etc (what ever you are using as a mic) in the list. Make sure it has a green check mark on it indicating it is the default device. You can then double click it and select the levels tab to ensure your volume is not all the way down on the mic. You can also click on the listen tab. Place a check in the listen to this device box and click apply. You should now be able to hear your own voice as you speak into the mic over your speakers. It gives you a way to troubleshoot the mic functions. Once you can hear your voice, remove the check and click apply again to return to normal.
Make sure you can hear your voice without Google Talk. It most likely is not the application causing your problem. If, however, your mic works on everything but Google Talk, then we need to do more troubleshooting. Let me know if this resolves your issue.
Mar 06, 2010 | Google Talk
New microphone works on one sight, but not another
Hi
Logitec cams have some issues with some Windows operating systems particularly Vista, However if you have Vista you will have to download Vistas driver for that exact cam model. If your operating system isnt Vista then setup the cam in "control panel, printers and other hardware, scanners and cameras". Also I trust when you installed the driver you did NOT plug camera in till it told you to do so.!! ALL USB powered devices must NOT be plugged in while loading drivers.
Cheers cbacer
Aug 11, 2009 | Logitech QuickCam Fusion Webcam
Msn problems with my notebook Toshiba
I to use a notebook (Acer Aspire one) and MSN wont run at all on this but there is a free download called Amsn which is almost identicle to msn you can use mics and web cams etc and all the smileys and you connect using your msn account
Mar 22, 2009 | Toshiba Satellite A135-S4527 Notebook
MIC PROBLEM
it is not working in programs like MSN? Also I would like to know if like yesterday this was working or not. Please also tell me the operating system - is it Vista ? Win XP ? or Linux?
Jan 05, 2009 | Toshiba Satellite A135-S4527 Notebook
Installed the LifeCam V3000 onto a Pentium 4 with Vista. It works fine until I power up MSN and then even when the person I'm trying to communicate with accepts my invitation to talk, the box that should...
do a cam / mic test in the audio/video settings in the tools tab in msn / yahoo. Then ya need to minimise the msn / yahoo screen and r. click on the cam icon in the taskbar and check that the mic and cam are enabled and that it is set to allow other programes to take control of this device.. hope this sorts it for ya xx
Nov 24, 2008 | Computers & Internet
MIC PLAYBACK IS NOT COMING OUT TO THE SPEAKERS
Dear sir/madam,
Go to the sound properties in tray icon, check the Mic is not muted and there is Line in button, u scroll up to high for sound in mic. check all the check box are not MUTED. ok.
thanks
good luck
Don't forget to rate the solution
Jul 23, 2008 | Microsoft Windows Vista Home Premium with...
I bout a microphone at Target. The name is 'PC Microphone with Detachable Laptop Mic' and it is from General Electris. It says it is supposed to work on Vista, Mac, Linux and Messengers, such as Yahoo, MSN...
Be sure mic is plug in the right input (the pink one).
Then open sound properties (in vista search for sound in startup menu) and then configure and test your mic in the recording tab.
Jun 22, 2008 | Audio Players & Recorders
Does not work on Skype and Messenger
In Vista, right click on the speaker icon in your system tray (usually located at the bottom right of the screen) and select "Recording Devices". Be sure that your microphone is enabled in this list. In Skype and MSN, find the audio hardware setup, and make sure to select your mic-in port into which the mic is plugged.
Dec 12, 2007 | Cyber Acoustics CV-1064 Microphone
Toshiba Satellite A135-S4527 Notebook Logo
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
