Question about Soyo DYLT032D 32 in. LCD Television
Soyo DYLM019A VT19n79 19" LCD monitor dead
I seem to have the same problem. I saw Q503 on the bottom had a hole blown out, so I can't see the markings on it. When I apply power, I get 12v on both sides of F500 but no voltage on Q500. (larger transistor between main chip & coil. There is a glue or something between Q500 and the coil as well. If you need component ID's most of mine seem clear. ronkloiber@yahoo.ca
3 Suggested Answers
  • 2326 Answers
SOURCE: The power supply in my
Is very hard to find these parts for servicing. The only option will be to DIY, by replacing some of the capacitors that become defective. Try to trace where the 12 volts are coming from and replace the capacitors or the 12 volts regulator if you find one in the circuitry.
Good Luck.
Posted on Mar 23, 2008
SOURCE: I have a SOYO-DYLT032B...32in LCD and I need a
i had this problem when i bought mine 3yrs ago.even soyo's web site didn't have a code.but recently direct tv downloaded some new codes in the remote set-up section. now they have one for soyo it is 11520.
Posted on Dec 23, 2009
I have a soyo dylm2284. On power up it displays screen but quickly turns itself off untill I power back up....Any suggestions to fix. It is out of warrenty
It may have backlight power supply problem or inverter circuits problems.
Check for caps with domed tops first.
http://lcdalternatives.auctivacommerce.com/Repair-Kit-Soyo-Topaz-DYLM24D6-LCD-Monitor-P1660441.aspx
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 21, 2011 | Soyo DYLM24D6 LCD Monitor
Hi there i have a flat screen monitor that is flashing at the power supply and causing the screen to flash in sync with teh green led can you tell me if it is the power supply or the monitor itself the...
One way to find out if it is the power supply or not is to use light bulb as a load, load it up to the current rating of the power supply to see if it will maintain the output voltage as indicated on the power supply.
I could not find the spec of this regulated switching power supply so I do not know the exact rating of this power supply.
Post more info about the power supply will help.
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Dec 31, 2010 | Soyo 19" LCD Flat Panel Monitor
My Soyo DYLM24D6 monitor screen goes black on reboot, can hear Windows XP Pro loading music but cannot even see the start-up screen from motherboard BIOS. I'm trying to find SOYO website but keep getting...
I would not be surprised if it does have bad caps in the power supply section.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Aug 06, 2010 | Soyo DYLM24D6 LCD Monitor
Computer 19" LCD Monitor with TFT 1280 x 1024 8ms DVI Connector Integrated Speakers - DYLM1967 ...: After a thunderstorm, my Soyo monitor would not tu...
If it uses AC adapter, then check the DC voltage at the DC plug to see if you get any voltage, if it use Direct power cord then it may have blown fuse inside the monitor, then you will need to open up the monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 17, 2010 | Soyo TFT 19" LCD Monitor
My Soyo DYLM1986 won't come on and is clicking inside. I have rebooted the computer, disconnected & reconnected from the CPU & monitor. Can you reccommend anything to help? Cindy
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Soyo DYLM1986 Monitor
My Soyo 19" widescreen monitor suddenly went all white. Powering off for a few hours does not help, it only glows white. Any suggestions?
It glows white because the LCD controller (part of the LCD panel) is not getting the 5vdc from the logic board or the LCD controller board has blown fuse due to short circuits, see what LCD controller looks like here: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
First thing to look for is to see if the ribbon cables on both ends are in place and have clean contacts.
Mar 26, 2010 | Soyo 19" LCD Flat Panel Monitor
I need the drivers for this unit
u can need widescreen driver for soyo.
u just go on that and check it out:
www.techsupportforum.com/.../driver.../264735-widescreen-driver-needed-soyo.html -
thnxxxx
Sep 18, 2009 | Soyo DYLM019A 19 in. LCD Television
Soyo monitors
your monitor doesnt have drivers for it.. and doesnt need drivers for that matter. It sounds like you dont have the right drivers installed for your graphics card. here is a link to the drivers you need.
http://www.nvidia.com/object/winxp_169.21_whql.html
hop this helps, good luck.
Jan 22, 2008 | Soyo Dymond DYLM017A 17" LCD Monitor
Soyo DYLT032D 32 in. LCD Television Logo
688 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
