Question about Logitech HARMONY 659 Remote Control
I cannot get my HK T-30 (harmony remote) to receive updates. Harman Kardon say that I need to learn how to get my system to allow their site to load an application onto my remote through the USB port. If turned off my firewalls and popup blockers and that hasn't helped.
  • delh1938 Jan 07, 2009
    I've followed the HK instructions and cleared cookies. I don't know what "remote nunplugged" is or how I can cause HK's application to download to my computer without the remote.
    I have had this site listed as a trusted site in explorer along with firewall and popup blockers turned off.
    Sergeant:
    Champion:
  • 435 Answers
Hi, Try removing all batteries and disconnect the USB from the remote. Hold down off button and connect the USB while holding it. Release the off button and try performing the update.
Insert the batteries after the update.
Posted on Jan 07, 2009
    Genius:
  • 1,269 Answers
If the update does not work on your computer, you can try to use a different computer now. Updating the harmony remote is just easy, when you plug it to your computer and internet is working, that should do it automatically.
  • 4,806 Answers
Hi there
Start IE without add-ons and try and update the remote that way
Good luck and kind regards
  • 679 Answers
You needs to contact to your product provider.
because its a security reason.
Thanks for using FixYa.
  • 6,487 Answers
You can do first uninstall and reinstall the software for your remote from your computer and connect the remote on a different usb port and after that update now should be working for this remote...
  • 492 Answers
Well first of all harmony remotes are a Logitech device.  Read the model and serial information off the back and follow instructions for obtaining support from logitech
Posted on Jan 06, 2009
    Genius:
  • 1,913 Answers
First reset your remotecontrol to factory defaults.
then check in settings update is notturned off.
turn of the firewall
for add in allw thire site.
go to internet explorer.then tools then internet option then security then trusted zone.then clik on site then type site of then then clik on add if it has " https" then check box enabled if not then remove check mark.
then reset it to low then applty and ok.
  • 19,396 Answers
I think you first need to install the application on your computer with remote nunplugged, when setup has finished connect the remote, and it should be recognised.
  • 153 Answers
JUst connect to their website and follow the instruction there . You clear all your cookies in the web browser .
Where to buy transistor for hk3480 part num 328 kca3114
Are you sure that is the part number? The HK-3480 uses a KTC3114A and is quite easy to find. Q317 and Q318 in your receiver.
Make sure you see the numbers correctly.
Jan 16, 2015 | Harmon Kardon Harman Kardon Harman/kardon...
Harman/Kardon AVR 3650 3D A/V Receiver
Make sure TV's HDMI port is working if it is working check it with a new HDMI cable changing the HDMI cable will fix the problem
Dec 15, 2017 | Harmon Kardon Harman/Kardon AVR 3650 3D...
My Cox HD/DVR controller will turn off but will not turn on my new HKAVR1700 using the AUX button on the Cox supplied URC-8820-Cisco remote.
This is a documented problem with the Harmon/Kardon AVR-1700 and the Cox remote. Here's how I solved it. On the HK1700, go to System Settings and turn on HDMI Link. This will allow your TV (if it has the feature) to put the HK in standby mode when you power down the TV. Go to your setting on your TV and turn on HDMI link, or equivalent. I have a Sony TV and the setting is called "Control For HDMI." Then, use code 0110 for your Cox remote. This code will only turn on the HK, not turn it off. BUT, the HDMI Link should put the HK into standby.
Jan 06, 2013 | Harman Kardon Harman/Kardon AVR 1700
Harman Kardon HK 3250 Receiver- how can I connect my turntable? there is no PHONO input
These depends on what model of turntable you have .
On most it can be connected on the inputs you have mentioned ,
If only , a RIAA preamp is included in it.
You may need one, if it doesnt have,
sample phono preamp:
Phonopreamps.com Home Page
can also be connected to Aux or Tape
Oct 08, 2012 | Harman Kardon HK 3250 Receiver
I have a Harman Kardon cdr 30 that I use to burn my analog Vinyl and cassettes to cd. I have done this successfully for years. I recently got a reel to reel deck and unhooked all the components and moved...
try plugging the HK30 out to R2R in, R2R out to RECV in...RECV (you may need 2 rca "Y" connectors) tape out back HK30 & Cass
the "Y" connector needed is (2) 2 female to 1 male (connect both HK30 & Cass deck)
May 15, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
How can i make the sky remote control th avr 130 (harmon kardon)
Does the sky remote have a code for the HK receiver? If it does, use that code to program it. Most other remotes won't work completely because this receiver uses a seperate button to turn it off...
Mar 14, 2010 | Harman Kardon AVR 130 Receiver
I have a Motorola QIP6200/64xx DVR set-top box thru Verizon
The best code I could find was "007"
"210" kind of works, but can't compete with Mr. Bond.
After programming "007", if there are any features of you FiOS remote that do not work on the HK AVR 354 remote, simply follow the HK AVR 354 manual instructions to "learn" additional commands. See the last paragraph on page 31 through letter "e" on page 32.
Cheers,
Jeremiah Pattison
Keywords: Harman Kardon AVR 354 remote code to control FiOS DVR PVR STB cable box QIP 6416
Oct 28, 2009 | Motorola Televison & Video
I have a HK TC30 remote control that will reset itself, displaying "Testing" and then indicates that the remote thinks all devices are off.
Try re-loading the firmware again through safe mode. 1. Take out the batteries from the remote. 2. Turn on your computer and hold the off/on button and connect the USB cable to the computer and remote. 3. The remote display should say "Safe Mode Requested". 4. Start the HK software and login, then click on Support. 5. In the download section, click on firmware and then proceed to update the firmware again. 6. After you update the firmware, you will need to re-download your configuration again and update the remote.
Feb 22, 2009 | Harman Kardon Televison & Video
Learning remote codes for my harmon kardon avr354
a) Place the two remotes so that their IR transmitters face each other
end to end, separated by about one inch. The
AVR 354 remote’s transmitter also serves as an IR receiver during
the learning process.– AVR 354 and Original Remote Head-to-Head
b) Press the Source Selector for the device mode you wish to learn
a code into, and place the AVR 354 remote in Learning mode by
pressing and holding the Learn Button until the Source Selector lights
up, then release.
Learning Remote Commands
c) Press the button on the AVR 350 remote you wish to program with
the new code, and the Source Selector will flash once. You may
learn a new code into the following buttons: Device Power On/Off,
Alphanumeric Keys, Last Button, Back/Exit Button, Menu Button, Navigation Buttons, OK Button, Disc Menu Button,
the four Teletext Buttons, Channel Up/Down, Volume Up/Down,
Mute and the Transport Controls (including Record).
d) Press and hold the button on the device’s original remote whose
code you wish to “learn” until the Source Selector flashes three
times, then release.
e) You may program additional buttons by repeating steps c) and d).
Press the Learn Button once to exit Learning mode, or wait for the
remote to “time out” and exit Learning mode on its own after about
30 seconds.
Dec 11, 2008 | Harman Kardon Harmon Kardon SoundStick II...
Logitech  HARMONY 659 Remote Control Logo
35 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
