Question about Boating
Johnson Outboard Motor 175HP
At 4,000 RPMs the motor runs rough and cannot get it above 3,000 RPMs. Light and alarm comes on the panel and then cannot run above 3,000 RPMs.
Not knowing what year it is...Light and alarm? Reason: overheat low oil etc. check water flow..water pump. The motor is most likily going into S.L.O.W mode. its a fail safe system. Last possibile reason ..CDI box and or stator.. pull plugs check compression...should be 120-150 lbs.
Posted on Feb 21, 2009
Unplug the heat sensor and try it.
Posted on Oct 22, 2011
I had the same problem with a Johnson 150, which has the same power block as the 175. I had this rough running problem for a couple of years. The solution was to replace the CDI pack, the fuel bulb and all of the fuel lines. My engine now runs like a dream. The shop charged me $700 for this work and parts.
Posted on Apr 19, 2009
I have a 1966 Johnson 20 hp model fd-20c outboard motor. It has low power. The motor is mounted so low that the pee hole is submerged nunder water when running. Could this be the cause of my low power...
Try mounting it properly,cavitation plate 1/2 inch below bottom of boat.An old motor like that many things could cause a lack of power.
Sep 06, 2014 | Boating
Why does my 1991 60 hp Evinrude outboard alarm sound and motor sputter occasionally?
when the alarm goes off is the engine getting hot, try running it in gear under load while tied up and with the engine cover off see how hot it gets and if the water i circulating all the time , might have cooling problem !
Aug 04, 2014 | Seloc Johnson Evinrude Outboards 1973 to...
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
Dark oil coming from inside prop
might just be carbon from the ehaust . do you disconnect fuel line and leave motor in gear when hauling . wind sucks fuel thru the engine
Apr 26, 2010 | Light Outboard Motor Boat Bass Fishing...
When running over 4 thousend rpms I get over heating alarm
Hey .Might not be the problem,but I would get the water pump checked.Its a common problem that in lower revs water temp. doesn't come up and when the motor runs harder and hotter,the pump doesn't keep up.I hope this is of help
Oct 28, 2009 | Light Outboard Motor Boat Bass Fishing...
1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Jun 30, 2009 | Sport & Outdoor - Others
1974 60hp johnson outboard won't run on full throttle under load , max 10%. New fuel and filters ect. The motor is old but has very low hours.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Apr 12, 2009 | Boating
Boating Logo
1,163 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
