Question about Car Audio & Video
Amp do you know of a how to or some sort of direction on how to repair the FET problem with the amp? i can solder and willing to take time
  • 631 Answers
This is the first place I'd recommend.
Basic Amplifier Repair
Let me know if you have any other questions.
Posted on Jan 06, 2009
I just hooked an antenna to my sony bravia and it only picks up a few digital channels. I have two other Tvs hooked to the same antenna and the both pick up so many more channels. What could be the pr
i think the 'front end fet' or channel fet has failed
this amplifies the incomming antenna signal
however is the center pin of the antenna plug on the tv loose
inside the tv is a metal box this is attached too
it changed the UHF signals to a lower frequency range called an IF
the UHF signals are normaly have a path like this
antenna>>safety >>>amp>>mixeramp>>output to DTV decoder etc
the amp bit or connection to the tv is wrong
as its working quite well and gets like 2 channels
look inside the socket on the tv and examine it carefully for any bits of wire
or as i say loose connections
may just need to be soldered inside the can to reconnect the center pin
it will still give like 2 3 channels as the gap caused by the bad solder joint
will still allow some RF accross
so... its either a gubbed UHF RF amp or a broken connection or a short ... so...
Dec 11, 2014 | Sony Televison & Video
My peavey cs 800x amp keep cutting out one side
I just repaired a cs800 that was intermittant cutting out on one side only- The solder on the boards where the input/output jacks are connected had multiple cold solder joints and had cracked the solder around the pins- Just needed a resolder job.
Apr 27, 2012 | Audio Players & Recorders
Hey, I have a few Xbox 360s that originally came to me with the error 0102. I though "easy enough" so i reflowed them. Now I'm getting error 0003! turns out I forgot to bolt them down, and...
I would definitely try baking the board to fix the warping and then reflow the CPU to fix the cold solder joint(s). If that doesn't work, then go to the MOSFETs. But the only way to accurately test a MOSFET is too remove it from the board first with either a powerful soldering gun (60+ watts), or hot air. I prefer using hot air to minimize physical damage to the FET.
Here is an easy way to test a MOSFET: http://www.youtube.com/watch?v=2BU7qHWtsmQ
Because there are so many FETs on a board, it's best to start with the ones closest to the CPU. I typically start with the ones directly to the right of the RAM. If those are fine, move out to further ones. If you get through all of them and can't find the problem, you may need a new FET controller chip. This is located directly under the first 2 FETs.
You can find replacement MOSFETs and controller chips all over Ebay for pretty cheap.
Let me know how it goes. And don't be afraid to ask any questions!
Apr 13, 2011 | Microsoft Xbox 360 Console
Sat went out lost power. can not get tv to turn on. checked outlet (fine) sat powered up. no tv power.
When this happened it probably took out Q406 a switching field effect transistor on the power supply board along with F401 an 8 amp Slow Blow fuse. The FET will have to be soldered in if it is bad. If the fuse is blackened, it is almost certain that the FET is shorted as well.
Jan 30, 2011 | Panasonic TH-42PX60U Television
What does the red and green light mean ???
red and green light? there is most likely a protection and a power light. The red I assume would either be a protection light or a clipping light signal. Does the amp kick off then these lights kick on red then to green?
May 31, 2010 | Planet Audio VX4002 Car Audio Amplifier
When i started to plug my battery in my amp made
you have blown the actual filters that make the sound. a amp is basically a filter with the same filters on both channels on each side of the inside of the amp - channel 1 and channel 2, that pop was in the heat sinks of the amp usually. if you have replaced the fuse in this amp and you get no on light, the internal amp is in need of repair
Oct 24, 2009 | Rockford Fosgate Punch 401S Car Audio...
Pioneer VSX-52 Elite Receiver Dc offset problem..
Voltages will read differently because the output voltage is wrong.
They are not FET and with all due respect, if you are not aware of what they are, you don't stand much chance of reading the service manual and affecting a repair.
Take it to an authorised Pioneer Repair Agent.
Jun 17, 2017 | Pioneer VSX-52TX Receiver
800.2
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage is OK, the amp will likely need to be repaired. If that's the case, do you want to repair it yourself? This amp may not be easy to repair. If you are not interested in learning to do this type of work, you should pay to have it repaired. If you want to repair it yourself, I'll try to help you through it.
Nov 11, 2008 | Rockford Fosgate 800.2 Car Audio Amplifier
My amp is blown!! Dont know what part to replace.
those are likely "chips" or "integrated circuits". can you read any words, letters, numbers off it? if it's a common off-the-shelf chip you can buy from mouser.com or digitek.com, AND if you know how to de-solder and solder delicate electronic components using a hot soldering iron WITHOUT destroying them or the adjacent components. if no identifying codes on the chip, maybe google up a schematic of the board (unlikely) and figure out what it is. if it's a proprietary chip made Rockford Fosgate, it will be harder to find. Also, there could be damage to OTHER components that may not be visible, so if you go to all this trouble it might still not work and then you'd have wasted money. hopefully you are under warranty and RF can repair it. otherwise, chunk it in the nearest trash can.
Mar 06, 2007 | Rockford Fosgate P10002 Car Audio...
Car Audio & Video Logo
99 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
