Question about Electrolux Gas Hedge Trimmer
My hedge trimmer keeps switching off
I'm trying to use a hedge trimmer,
but it keeps on turning off by itself
I donno wats wrong with it,
can you tell me wat kind of problems it mite
have????
    Scholar:
  • 76 Answers
It sounds like you may have a loose wire some where that is grounding out. You might want to check all wire connections to make sure that they are tight and also check for any bare spots in the wires were they could be touching metal and grounding its self out.
Posted on Jan 14, 2009
My hedge trimmer got wet in the rain, now it won't work and keeps fusing the electric when I try turning it on, can this problem be solved?
you must completely dry the appliance out try using a hair dryer on a low setting and expose as much of the interior to the air flow water and electricity don't mix be careful switching trimmer back on
Aug 24, 2015 | Electric Garden
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
Do I ever need to sharpen? If I do, how?
Hey i found this for you i might help. Click on the link at the bottom!!
How to Sharpen a Black and Decker Hedge Hog sharpen-black-decker-hedge-hog-800x800.jpg Maintaining the sharpness of electric timmers can made landscape trimming easier with beautiful results. Electric hedge trimmers make trimming hedges and bushes easier and quicker than using manual hand-powered trimmers. Electric trimmers, the most popular type in the U.S., cost less and require less maintenance than gasoline-powered models. Electric trimmers are used most often by homeowners with the Black and Decker Hedge Hog series being very popular. While they are not premium products, electric trimmers like the Black and Decker Hedge Hog trimmer can keep trimming reliably for years with proper maintenance, including sharpening the blade's teeth.
Difficulty: Moderately Easy Instructions Things You'll Need
  • Work table
  • Two medium size clamps
  • Dremel tool or similar hand-held multi-purpose tool
  • Grinding wheel attachment for hand-held tool.
  • Dremel 971 (or similar) aluminum oxide grinding sharpening stone with a tip small enough to cover the flat facet of a Hedge Hog blade tooth
    • 1 Unplug the electric trimmer before trying to sharpen the teeth.
    • 2 Clamp the electric trimmer to the work table using two clamps if necessary so the Hedge Hog is firmly held down with the blade teeth accessible over the edge of the work table.
    • 3 Insert and secure grinding tip in hand-held multi-purpose tool.
    • 4 Maneuver the grinding tip so it is perpendicular to the facet of the Hedge Hog tooth.
    • 5 Sharpen teeth in one direction, being careful to try and maintain the same cutting edge angle on the sharpened tooth of no less than 35 degrees.
    • 6 Make same number of grinding passes/grind the same length of time a few seconds on each tooth.
Tips & Warnings
  • This task should take about 15 minutes.
  • Keep a light touch; too much force can break the grinding surface.
  • For best results, insert the sharpening bit slightly less than all the way into the tool.
Read more: How to Sharpen a Black and Decker Hedge Hog ' eHow.com http://www.ehow.com/how_7163131_sharpen-black-decker-hedge-hog.html#ixzz1XsAosvvl
Oct 17, 2009 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
I have a model # RY39500 ryobi hedge trimmer 2 cycle engine. Starts fine and idles however when i try to run it it dies. Whats wrong with it?
Sounds like the air screws need adjusted on the carburator. If there are 2 the one with the L above needs to be turned althe way to the right but not to tight and then backed out 1/2 turn to left. The one with the H anove it do the same except back it out 1 and 1/4 turns to left. If it only has 1 screw dot he same but back out 2 complete turns. Hope this helps?
Ralph at woodworking57@hotmail.com
Sep 15, 2009 | Ryobi Factory-Reconditioned 26cc 22" Gas...
I have a HC-1500 hedge trimmer tested the kill swithch and it tested good, thought it was a bad coil so put a new coil on, still has no spark, should I put on a new flywheel? One magnet on flywheel seems...
take it to local small engine shop and get a free estament from them
they will tell you whats wrong with the unit
also have you tried to hold the coil wire and have a friend pull it over ??
if you get zapped then try replacing the spark plug
Aug 04, 2009 | ECHO, Inc. 20 In. Double Sided Hedge...
I have lost the screws out of the hedge trimmer attachment
go to the hardware store and find screws that fit properly
Jul 11, 2009 | Garden
BLACK & DECKER TR1700, or aka an electric hedge trimmer. I plugged this little baby in correctly, and tried to turn it on and the blade would not move. The machine did turn on, but it was almost as...
electric hedge trimmers have two switches
one in the handle and the other where you hold the machine at the blades
both have to pressed or it will not run
it is a safety switch so that both hands and finders have to be occupied to stop cutting fingers off
Dec 24, 2017 | Computers & Internet
Trimmer safety problem
# Keep all people and animals away from the area you're working in # Hold the hedge trimmer correctly using both hands # Make sure the hedge trimmer's switched off and idle before attempting to remove any jammed cuttings # Wear protective clothing including heavy-duty footwear and safety goggles to protect your eyes from flying cuttings # Electric hedge trimmers: Don't use in wet weather. Keep the cable well away from where you are cutting and check that the socket outlet has working RCD protection # Read the manufacturer's instructions before use
Aug 27, 2008 | Walter Drake Garden Groom
Electrolux Gas Hedge Trimmer Logo
271 people viewed this question
Top Electrolux Garden Experts
Phil Walker
Phil Walker
John
Are you an Electrolux Garden Expert? Answer questions, earn points and help others
