Question about Fisher and Paykel GWL11 Top Load Washer
Water wont empty
My smart drive top load washer 7.5 won't drain the water, i know it's not a bra wire, but i believe an overfluffed floor mat shed too much lint & it seems the draining mechanism may be blocked. I forwarded to spin cycle to force drain but it just makes a buzzing sound like it's trying to drain & won't. is there any solution available?
We had the same problem with ours. I took out the steel tub and found there was a lot of lint blocking the pump (at the bottom of the plastic tub). There is a screw holding the pump cover. Once you remove this you can check it properly for blockages.
Posted on Jul 07, 2007
Will not empty of water
If it's a front load washer the coin trap may be clogged up with a sock I have found dollar bills, baby socks,bra wires, you name it in them.It could also be a door switch.If it does not drain or spin then I would check the door switch.Coin trap is usually the problem with a front load washer.
If a top load then either drain pump or clogged line I have found garments in the drain pump but it is rare.Check to make sure the pump is getting electricity if not a direct drive pump.
Aug 31, 2012 | Washing Machines
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
Washer won't hold water, just drains to the floor.
Sounds like there's a hole or loose ejection water hose.
Move the washer so it will run and you can look in the back to see where the water is coming from....fix the leaky problem once you find it. Could be a bad hose clamp as well
Dec 12, 2017 | GE WBSR3140DW Top Load Washer
My front loading GE washer WSSH300 will not drain.
Don't know if this will help or not, but your owners manual is available at http://genet.geappliances.com/DocSearch/Dispatcher
Water won’t drain
Drain hose is kinked or •
Straighten drain hose and make sure washer is not improperly connected sitting on it. Top of drain outlet should be less than 8 ft. (2.5 m)
above floor. Household drain may • Check household plumbing. You may need to call be clogged a plumber. Plumbing this washer directly to a pipe is hard on the motor. Usually the drain hose elbow is inserted in a stand pipe, meaning the washer would drain water on the floor is the stand pipe is clogged.
Several items can cause the lack of draining.
If you can get to the drain hose, try lowering to a point that it will drain into a bucket. If it drains the system is not clogged. If you advance the timer and the washer drains this maybe the culprit. The motor can overheat and shut off. I would advance the timer to spin and listen for a hum in the motor and then quiet, a sign that the motor has overheated. If the water drains it sounds like the timer is at fault.
I would first make sure the drain hose is properly installed and not kinked somewhere. In earlier GE's the water drain pump could clog, your manual doesn't indicate that as a defect. Regardless timer, motor and pump are in the cycle to empty the washer water.
Jul 10, 2010 | GE WSXH208A Front Load Washer
How do I drain the barrel
If this is a top loading washer, an easy method of draining the wash tub is to pull the drain hose from the standpipe at the wall and lower it into a bucket. Gravity will allow the water to drain. If the washer is in a laundry room or utility room with a drain in the floor, you can simply lay the drain hose on the floor and allow it to run into the drain.
A less messy method is to use a wet/dry shop vac and pull a vacuum on the drain line to pull the water from the wash tub. Most of the these top loaders have a capacity of about 30 gallons, so you will need to empty the shop vac a few times to empty the tub. Make sure you place the drain hose back into the standpipe when you need to empty the vacuum or gravity will force the water on to your floor.
If you have any questions, please let me know. I hope you find this information helpful.
May 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Machine is stuck on spin
Your smart washer equipped with fusion logic got confused at the different scenario that you just changed from automatic to manual mode.
1- Unplug the pwer cord. Open the door to get the the crazy floor mat out to dry under the sun or manually squeeze it before putting in the dryer to take are of the problem at the first place.
2- Pug in the power cord and start with a short run with an empty load to make sure the problem is not happen again then you are good in resetting it. Good luck.
Apr 21, 2010 | Whirlpool GHW9200L Front Load Washer
Top load overflowing, I shut water off. What causes? Any way to drain other than bailing out water?
Overflow due to pressure switch fault, drop down drain hose to floor to Gravity empty
Feb 09, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Our samsung j845 front load washing machine won't
You have a blockage in the drain pump or sump on the machine, it could be anything from a coin, bra wire or an elastic band, best thing to do is switch off the electricity and incoming water, remove as much water from the machine as possible, pull machine out place a suitable container below the drain filter and then open up the filter (if fitted) once cleaned check hoses and drain pump internally for blockages.
Sep 07, 2009 | Samsung WF337AA Front Load Washer
How do I drain a maytag washing machine?
If the machine will not operate to drain the water, gravity will do the job for you. Simply remove the drain hose from the standpipe, and lower it to a floor drain if one is near enough to the machine. If no floor drain, you can catch the water from the hose into a large bucket for disposal. You will need to empty the bucket numerous times before the washer is empty.
Jul 15, 2009 | Maytag MTW5900TW Top Load Washer
Washer won't drain.
hi, to empty water manualy, lift the hose from the stand pipe, keep it above the water level, place a bowl on the floor and lower the hose into it, the water should drain out, to stop the water flow lift the hose above the drum and empty bowl, continue until empty, hope this help, thanks for using fixya
Feb 14, 2009 | GE WBSR3140DW Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
285 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
