Question about Jandy PHP High Head Pump 2 HP Up rated
The pump (Hayward) is rattling loudly, a pulsating vibration
    Problem Solver:
  • 7 Answers
Like a bearking grinding noise? or inside the wet end noise? if in wet end then it could be something broken inside or you have a rock inside by the impeller or diffuser open it up and check for anything broken up
Posted on Jan 07, 2009
Neon is very loud while at a stop
Catalylic converter heat shield rattle?
Mar 22, 2014 | 2004 Dodge Neon
Hayward h1001d diverter plate broken - How do you repair?
diverter plate controls water flow check flow from pump
May 22, 2013 | Hayward Pool & Spa
I have a hayward H100ID above ground pool heater. Recently the heater is making a rattling sound and the in and out hoses are bucking or pulsating. The water is still being heated but somehting does not...
low water flow is making the heater knock, (PULSATE) clean filter or backwash, check pump and skimmer baskets and empty. if still low flow and knocking, check impeller on pool pump to make sure it isnt clogged.
Aug 30, 2011 | Hayward Pool & Spa
My Hayward pump is pulsating rather than keeping a
make sure all intake unions are tight you have a air leak or top pump seal is bad
Jun 09, 2010 | Jandy PHP High Head Pump 2 HP Up rated
Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
Feb 03, 2010 | Aprilaire 550 Humidifier
Loud rattling noise that vibrates of oan on coming
check all things are tight like exhaust & fan etv & not rubbing
on anything
also look for wear marks from rubbing! shiny bits
Jul 18, 2009 | 2004 Jeep Grand Cherokee
Via Venezia- pump is very loud
Sometimes the water filter vibrates against the water tank and it sounds as if the pump is really loud and malfunctioning. It isn't. Just pull the water tank forward and play around with the water filter and hose and you will be able to isolate the problem. You could cut the hose slightly shorter to stop the "rattling". good luck.
Jan 05, 2009 | Saeco VIA Venezia
Vibrating noise
u may have food in pump u see sometimes it dose happen i have pop corn seeds in mine
Dec 16, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Engine vibration at start up
water pump by teh sound of it seal ok but bearing going
Nov 12, 2008 | 2002 Ford SVT Focus
On my 2001 Ford Focus. Bad gas milage, engine running rough, loud vibration when steping on the gas pedal.
IS YOUR LOUD VIBRATION A LOUD RATTLE IF SO IT COULD BE YOUR CAT BREAKING UP THIS WILL CAUSE BAD RUNNING ..GIVE YOUR ENGINE A GOOD REV 3 or 4 TIMES OUT OF GEAR AND LISTEN FOR A RATTLE,,,,, HOPE THIS HELPS IF NOT CHECK THAT THE EXHAUST IS NOT BLOCKED ?? BEST OF LUCK-ELL BOY.
Aug 13, 2008 | 2004 Ford Focus
Jandy PHP High Head Pump 2 HP Up rated Logo
710 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
