Back to:
Tags:
Garmin StreetPilot C330  GPS Receiver
My Garmin C330 doesn't seem to show any maps (by 8 users)
posted by asadb1990 on May 25, 2007
I have bought a brand new Garmin C330 and for some reason i cant get it to work. For some reason the garmin does not seem to give any signals. The Garmin C330 just continues to say Locating Satelite or something but nothing is happening.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
7 Other Users Have The Same Problem
Comment by Guest, posted on Oct 01, 2008
will not locate satillites
Comment by Guest, posted on Apr 04, 2008
My C330 worked from Kentucky to South Carolina Beachs just fine many times, for alomst two years. Now it stops working once I reach the mountians in Tennessee and will not work past that point, even on the beach holding it in my hands with no antenna restrictions.
Any clues would be appreciated.
Comment by budshome, posted on Feb 18, 2008
When asking for address, it will not let me enter a county, but goes directly to select county..also only shows blue arrow, not the street we are on or near.
I have reloaded usb driver, charge the battery, taken unit outdoors to get the best reception. tried different address, still blocks me from entering addresses.
Comment by Guest, posted on Feb 17, 2008
tried resetting
just says - acquring satellites
but nothing happens
so what now?
Comment by Guest, posted on Jan 08, 2008
Says "Locating Satellites"
Best Solution
posted on Aug 16, 2007
Helpful (85)
dadtopes
Rank:Apprentice Apprentice
Rating: 73%, 16 votes
try to change the antenna
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on My Garmin C330 doesn't seem to show any maps:
I don't want to Accept this solution
Solution #2
posted on Aug 28, 2007
Thanks for Trying (70)
Guest
Rating: 0%, 0 votes
Try to change the antena?
what the hell does that Suppose to mean.
Where am I going to get an antenna and better yet why should I change the antenna on a unit the still has warranty.
The idiots at Garmin could not figure it out so how should I???
Thank You!
Solution #3
posted on Dec 27, 2007
Not Rated (0)
Smegman
Rating: 0%, 0 votes
location, location, location.... unfortunately, some locations are better than others for reception. If you are located in an area that is not good for satellite reception (buildings, mountains, etc) you will not have good reception. An external antenna is probably your only answer. I have the c330 and, to my surprise, it works inside of my house. I also have XM satellite radio that needs an external antenna to function properly.
Thank You!
Can you Help with these GPS Devices problems?
Garmin StreetPilot C330 (010-00401-10) GPS...
my problm with c 330 is that it keeps sending me west when...
Hello, I had a problem wiht my Notebook which required a...
unit will not stay on. I have tried the reset button under...
streetpilot c330 11months old rarely used stored inside...
My 330 wont power on
7 Other Users Have The Same Problem - Continued
Comment by BALLAN, posted on Dec 12, 2007
THE THING ALWAYS SAYS LOST SATELITE RECEPTION.
HELP
Comment by Guest, posted on Nov 27, 2007
same problem
Loading problems.
Repair Service
Find GPS Device Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
