Question about Sharper Image Blue Hat Toy Company Kids Digital Camera
Thunder tumbler won't turn on
Nothing happened when we turned on the switch after we got it out of the box and installed batteries. I cleaned all of the connections, took off the body to see if there was a lose wire, nothing worked.  Eric
  • 1 more comment
  • eric368 Jan 06, 2009
    This is from the Blue Hat Toy Company
  • grayfree Feb 05, 2009
    The blue hat little tunes wont turn on.  It did once then no more. It will come on when I connect it to my computer but then it doesn't download music and it cuts off after a little while when I disconnect from my computer.  I cant convert my itunes files to mp3 unless they are itunes plus songs or something i don't know what that means help please
  • blue5 Feb 08, 2009
    After placing batteries and connecting to compute. Player won't turn on. Nothing.
  • 15001 Answers
SOURCE: won't turn on
Might be a fuse BUT it is enclosed in the unit. You would have to take it apart to see. IT could also be other parts in the power supply that have failed, With that in mind, if you do take it apart, take pictures so that you can put it back together.
Posted on Aug 27, 2012
How do I fix the remote on the RC Thunder Tumbler RC Car to prevent the tire from spinning as soon as the remote control is turned on?
Use the throttle trim control to try and adjust this unwanted throttle application out. Refer to the user manual on how to trim the remote functions
Oct 17, 2016 | RC Thunder Tumbler Rc Car
My son got a thunder tumbler for Christmas but the car will not turn off, the light remains on. What is wrong?
Probably different frequency remote relative to car, same deal with my sons......car and remotes need to be on the same frequency....either 27 or 49
Dec 25, 2014 | RC Thunder Tumbler Rc Car
Took my ford focus to a dealer because key would not turn either way. They said it was the tumbler and would have to be replaced. They jusy called and said they installed new tumbler and reprogramed the...
The reason that the key wouldn't turn must have come from a malfunction of the ignition switch or the connecting rod, rather than the just the tumbler. Since the dash lights & gauges work now, at least part of the ignition switch is working, but apparently not the part that's engaged when the switch is turned to the "start" position.
By replacing just the tumbler, the dealership tech would have jiggled the connecting rod just enough to reseat it (and fix the jam that was causing the key to fail to turn in the tumbler), but didn't fix the real problem, which seems to be a worn out ignition switch or worn connecting/actuating rod.
Here's your steering column anatomy - illustration courtesy Ford Motor Company.
Oct 19, 2011 | Cars & Trucks
1997 jaguar xj6 passenger side engine bay fuse box fuse # 10 IGN control (low current) 5 amp blows as soon as turn the key then the battery drains and car dies what is happening and how do i fix it. Also...
I think your thumbler is shorting and blowing the fuse..; replace the tumbler..
your ignition is wired to the tumbler.. if thats shorting it will explain your issues.
May 24, 2010 | Jaguar XJ6 Cars & Trucks
My motherboard (Tyan Thunder LE-T S2518) simply won't start. It is powered on, has memory and cpus installed but nothing happens. The power switch is in it's place. Network cable is plugged in, it shows...
first thing to check would be the CMOS jumper to make sure it's in not in reset mode. You'll probably find it near the battery on the motherboard. If it is in "normal" mode (or jumped across the right two pins) then you may want to check the battery itself. That's the easiest and quickest thing to check.
Secondly, do you get any beeps from the mobo when you turn it on? If not, and it's not your cmos jumper/batter, you may have a badly seated CPU or heat sync, OR a bad CPU all together. If you don't know a lot about cpu's and reseating them, you should bring it in to a tech to have that looked at. Otherwise, if you know what you're doing, I'd pull the heatsync/fan off the CPU, clean off the old thermal paste, put new on (use it lightly), and reseat it all. Then see what happens.
Mar 14, 2009 | Tyan Thunder LE-T S2518GN Motherboard
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Sharper Image Blue Hat Toy Company Kids Digital Camera Logo
60 people viewed this question
Top Sharper Image Toys Experts
ray gallant
Are you a Sharper Image Toy Expert? Answer questions, earn points and help others
