Question about Sony PlayStation Portable (PSP) Console
Psp when my psp is charging i can turn it on and play but when i pull the wall charger plug it shuts off and the battery meter in the top right hand cornewr says its full is this normal or is there something wrong with my battery or charger or something? PLEASE HELP!!!!!!!
    Problem Solver:
  • 19 Answers
How to save your dead battery: Please note using below method at your own risk, and you have been told. Take out you dead battery (PDA battery,PSP battery,Phone battery etc), wape it around by using a big piece of dry newspaper. Then put the newspaper waped battery into the freezer at below zero temperture for 4 days. After days, take the whole thing out and put in room termperture for one day. Recharge the battery and use it.
Posted on Aug 08, 2007
SOURCE:
How do i charge my psp battery
Plug the charger into the wall. Plug the other end into the spot on the PSP with the yellow outline. Check for an orange light. If it's on, let it charge until the light turns off. It it's not on check connection. If it's still no charging, take out the battery and put it back in. If it's still not charging remove the battery and try to turn it on. If it will no start, your PSP is bricked.
Sep 30, 2011 | Sony PSP-3000 Silver Console
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
I have a PSP that I charged overnight and a orange light came on when i plugged it in to the wall charger. After charging all night I went to power on the PSP and it will not power on, no green or orange...
Remove the battery.
Plug the PSP charger into the PSP.
Turn it on.
The PSP works with no battery inside.
If you're not getting a green light at all, your PSP has some sort of damaged as it should work while plugged in with no battery inside.
Mar 17, 2010 | Sony PlayStation Portable (PSP) Console
PSP 2001 not recognizing battery
yes,and try using the right battery for ur system
Feb 10, 2010 | Sony PlayStation Portable (PSP) Slim...
Psp will shut off in 5 minutes
could be a faulty battery.
they just use a NMH type battery similar to a cell phone, and they DO die occasionally, or if its been used a lot and not charged properly.
you can buy replacements from gaming stores, and from online auction sites. they go from US$10 to US$25 so shop around for a good price.
It could even be your PSP wall charger that isnt delivering enough juice to the battery?
Jul 22, 2009 | Sony PlayStation Portable (PSP) Slim...
My Psp battery will not charge. I tired plugging it into the wall charger and I got nothing. I tried plugging it in through the usb part and it still won't charge! Help please?!
it is shot. a quick test is try another psp and charge it with that one.if it does charge then it is your psp and your psp might be fried.if the battery doesn't charge then try another known woking battery.if you got any more qeustions email me at gamecrazy944@yahoo.com
Jun 29, 2009 | Sony Battery Charger for PSP
PSP chager
Try a different outlet in the wall, it might be the outlet, if it isn't the outlet, maybe it's the power cord or the battery. If it's not that, then it's your PSP. You'll have to send it to sony for a new one if you want it replaced and if youve had it for over year you're going to have to pay $90. ------The fact that it turns off when the USB DC-in is connected and that it will not power up without the battery lead me to think that either the USB charging cable is just not supplying enough amps to run the psp standalone nor charge the battery very quickly, or something is odd in the PSP itself. I'm guessing when you plug something into the DC-in socket and it detects 5V then it switches to that as a source, if the USB cant supply the current it wants then it shuts down (just a guess).
May 06, 2009 | Sony Battery Charger for PSP
PSP Charging problem
TEST : Take battery out. Plug in to wall. Wait 30+ secs with psp on. if the power turns off, then its the adapter which is broken, which costs about 5$
OTHERWISE:
Your battery needs to be changed. Standard flavor costs bout 8$, extra long lasting spicy flavor costs 16$. (lol, chips)
Seriousley though, after some time, wear, and in some cases, temp. changes, the battery can become so weak, that it will only hold about a 5 second charge. Once you get less than 1 hour play time W/O charger, need to get a new battery.
Feb 21, 2008 | Sony PlayStation Portable (PSP) Console
Psp battery problem
the problem 's if u kept ur psp battrey without changing the battery it will bad , you have to wake up the battery by open the battery ,you remove the battery from the case .use solding iron to remove it after that , use ur psp changer to jump start the battery for just 5 min , after that solder it back it will start working ,,,,,,, bye
Dec 20, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
126 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
