Question about Panasonic NV-GS33 Mini DV Digital Camcorder
Panasonic nv-gs330 camcorder- LCD problem
I have video camcorder panasonic nv-gs330. The problem is that the lcd screen doesn't work properly. It turns on only when the screen is turned 180 degrees. I got inside the LCD joint and everything seems to be fine. There is micro white switch which worked good when I pressed it manualy. I don't think is gold tape/wire problem because this working switch tells me that. I guess. It might be some broken little part missing, but I don't see anything broken inside. Do you have any clue?
5 Suggested Answers
SOURCE: My Panasonic nv-gs75eg 3ccd digital video camera is not working.
Did you chk whethere the symptom was there in Camera mode ? If camere mode is OK and if you are getting strips in tape mode,then head cleaning may solve your problem. If it is present in camera also, You will have to check LCD hinge Unit (strip)for brokenor cracked.
Posted on Feb 09, 2007
SOURCE: Panasonic Nv-GS3
I have the same problem, i was just using my camcorder and when i changed the tape, it says incompatble tape and now it wont play or record at all. It has happened to me today.My friend told me to leave for a while and try again. Hi C8dee, is your camcorder working, any updates, did you find a solution. jinn666@hotmail.com
Posted on Jul 29, 2007
SOURCE: LCD no image
it is same with my camera same type also.the problem is from flexible cable from mainboard to lcd .same of the core is break..until now i can'ot get that cable.
you just buy the cable and on your camera and ok.
if you have information abaut that cable please submit to me
iskmaulana@gmail.com
Posted on Oct 22, 2007
  • 30 Answers
SOURCE: LCD screen goes blank on my Panasonic NV-GS17 camcorder
you need to replace your camara's flex cable (LCD HINGES-technical name).
Posted on Jun 07, 2009
satavlad
  • 405 Answers
SOURCE: my dvc NV-GS25 lcd screen is not working
Common problem with this model, flat cable that connects lcd assembly to the main board is broken, replacement part comes as hinge assembly witch includes cable and the hinge.
Posted on Nov 11, 2009
No picture on lcd screen but ok through eyepiece
The lcd screen is no longer working. Fortunately the eyepiece still works and U can still use the camera and compose shots. Repair is not worth the cost.
Oct 14, 2015 | Panasonic NV-GS50 Mini DV Digital...
How can I transfer from tape in camera onto dvd
The best way to do this is to download the video onto a computer. Using video software (there is a lot available on the internet), edit your video and then send it to the DVD burner.
May 20, 2015 | Panasonic NV-GS330 Mini DV Camcorder
Lcd screen monitor
its may be LCD flex damage
http://www.ebay.com.au/itm/NEW-LCD-Flex-Cable-Repair-Parts-Panasonic-NV-MD10000-MD10000-F0081-/151132846898?pt=UK_Replacement_Parts_Digital_Camera_Parts&hash=item2330383b32
Mar 14, 2014 | Panasonic NV-MD10000 Camcorder
Where can I contact for Panasonic NV-GS400 LCD board?
go to any panasonic dealer or camcorder service shop and ask for your requirements
Mar 04, 2012 | Panasonic NV-GS400 Camcorder
I have panasonic PV-GS32 camcorder. The lcd was working fine for 2-3 years but suddenly stopped working. If i flip open the LCD screen then the viewpoint also goes blank. Is there some setting that needs...
It does look as if your LCD screen is dead, they are not cheap to replace, but you could pop it in to your local Camera shop, they will mostly be glad to help you.
Jun 16, 2010 | Panasonic NV-GS17 Mini DV Digital...
My dvc NV-GS25 lcd screen is not working
Nov 11, 2009 | Panasonic NV-GS25 Mini DV Digital...
Jun 02, 2009 | Panasonic NV-GS17 Mini DV Digital...
Panasonic NV-GS60 with horizontal lines appear on screen
Clean the heads(use the specified cleaning tape sparingly).
Change tape. Using Panasonic video tape? It sounds like no. You might get by with Sony... Try Panasonic.
The tapes are different thickness, durability and therefore suitability for cameras. Try to get ME -type tape( metal evaporated) instead of MP( metal particle) as the particles tend to flake off more readily. The blue often means no signal(video) was recorded in that space(on the tape). Let me know it it helps.
vac8
Dec 26, 2008 | Panasonic PV-GS39 Mini DV Digital...
Panasonic NV-GS33 Mini DV Digital Camcorder Logo
146 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
