Question about HP Photosmart C7280 Laser Printer
Copier will not work correctly
Fuzzy and prints larger than what is being copied
  • 169 Answers
Try cleaning the scanner glass(both the scan bed as well as the scanner glass on the Automatic document feeder)..then clean the copper contacts on the cartridges......if it still does not work then You can try a reset on the printer using the # and the number 6,holding them down while plugging in the power cord at the back of the should work......
Posted on Jun 25, 2009
Why do printouts have increasingly larger blank margins?
Go to the printer's settings menu and look for an option to "Restore Default Settings" or similar words.
Jul 30, 2014 | Brother MFC 7860DW - Multifunction fax /...
The printing on the accompanying manual is too small for me to read. Where can I find one that is larger print.
You did not mentioned the model or device ..but suggestion ..if it is a pdf file (digital ..on he computer or on a disk ) ..just use the magnifier scale on the adobe reader and enlarge it ..It is on the top bar in the middle ..and it shows percentage ...Just choose a larger one ...or ..if it is on an on line one ...(pdf ) and reprint it .or ..scan the one you have ..and print it larger..or ..just use a copier to copy it ..but set a larger format for the job ...(all copiers have a percentage scale for the enlarging a copy job ..
Aug 05, 2011 | Computers & Internet
The copies are not clear, they are fuzzy... its like somehow the reader is out of focus. have lots of toner and paper. we cleaned the glass and the spf roller and spf scanning window??
Have seen this problem before and if i remember correctly it is down to the fuser running at the wrong temperature. To prove this , make a copy. try and judge when the paper has left the drum but before it reaches the fuser. Open the side cover and very carefully remove the paper. look at the image. if it is clearer then it is the fuser. If it is still fuzzy then the problem lays in the development area.
Jun 18, 2011 | Sharp AL 1631 Copier
I placed a book on the copier and tried to copy it in a larger print but could not find a setting to make the printed page larger
The model of copier you're using is going to determine the verbiage the manufacturer uses but I have seen both "enlarge" and "zoom".
Mar 19, 2011 | Computers & Internet
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 01.duplex model memory error
02.LSU trouble
03.shading trouble (black correction
04. shading trouble(white correction)
05. shading trouble
06.Abnormal laser output
Jun 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
Printer does not print when I send from my computer, but does print when I place copy under screen for copying.
Copying and printing are two different functions. Your machine will process copies because the work is all done AT the copier. In order to print the PC and the copier need to be able to communicate properly.
Make sure that the printer drivers for your machine are set up properly on your PC and the two systems are communicating correctly.
Aug 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Toshiba 2060 Photocopier prints copies that are a bit too dark.
restart the copier while holding down the "0" and "5" keys. you will now be in service mode. enter "5" and press "start" key a number should show up in the display. this is the exposure value - how dark or light the copies will be. 5 is the automatic exposure setting. around 128 is the normal value. the larger this value the lighter the copies are - the smaller the value the darker the copies.
Enter a new number (exposure value) and press the "interupt" key to save the value. Restart the copier and check what the copies look like. Keep adjusting until it looks good/better.
Mar 26, 2009 | Toshiba 6560 Copier
Copy quality is poor. Replace toner, drum and transformer?
when you say the quality of the text is poor I am assuming that your are describing the line print
IF FUZZY remove corona wire and clean with q tip diped in alcohol
If IMAGE OFFSET check fuser rollers emove pad and ad fuser oil
IF copies lite remove print cartridge and shake back and forth to get toner distributed
also examine photoreceptor sounds the shutter is not closing and causing image distortment
Jan 05, 2009 | Sharp AL 1631 Copier
Not printing correctly from computers
try makling a copy from the glass if that is good then your problem lies with your net work try reboothing the colorpass, also have someone else print if you still have blank prints your color pass hard drive needs to be detach blow out then reattach
Jul 10, 2008 | Canon CLC 1140 Copier
HP Photosmart C7280 Laser Printer Logo
64 people viewed this question
Ben Johnson
