Question about Microsoft Windows Server Standard 2003 for PC
Dhcp in server 2003 in domain not working
I am using 2003 server is not supporting DHCP .
at my location class C IP4 version is using .but when i change client into DHCP Class B ip is assigning to client..
some solution i tried to re configured DHCP
i need a solution without re-installing win 20003 server
  • 36 Answers
Windows 2003 server supports DHCP. If you don't see in Administrative tool DHCP maybe the DHCP role is not enabled. You can add this role in "Manage your server". You don't need to reinstall win 2003 server.
Another way to access DHCP management tool is: in command prompt type mmc and then File> "Add remove snap-in" then "Add" and select DHCP.
Posted on Jan 08, 2009
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
Uses for DHCP, DNS, TCP/IP
DHCP: Domain Host Computer Protozoic. Basically an Address serving device, a "Client" "Asks" the DHCP "Server" for an "Address" on the network it is communicating on. THe DHCP Server, then sends that particular "Client" the ADDRESS, which, the device then "Stores" and Can then be identified by and Identify with that address when required.
Basically it is a Name Giver, and Finder.
DNS: Is Domain Name Server, Similar to a DHCP server, but in this case the device Translate Words and letters into an address, so the the DHCP server and other numerical only devices, can Ask for and Receive from "Other " "Addresses", that were described initially as Word Address, EG: WWW.Address.com, translates to (just say), 123.456.678:90.
If a device cannot "Understand" the Alphanumeric Address is then "Asks: the DNS, server, to "Translate" it into a "Numerical" one, that it can understand.
Basically it is a Translator.
TCP/IP: Transmission Control Protocol, Over, the Internet Protocol. It is basically a encryption algorithm, applied to all/any signals, that is then, introduced to, and transmitted to, and received over, the Internet Protocol signal, (Internet Standards of Operation) The Signal the internet operates "On". It is the bench mark, the correct way of doing it, a set of Rules.
Basically a Encryption vehicle and set of rules & standards.
Aug 26, 2010 | Computers & Internet
I have win2003 i want it serover what can i do
You can do a lot with this operating system.
Some of his features are: DOMAIN Controller, Active Directory, Ftp Server, DHCP, Web Server, Terminal Server, File server etc.
Here i have some very useful links.
About Windows 2003 Server Editions: http://en.wikipedia.org/wiki/Windows_Server_2003
Futures: http://www.microsoft.com/WindowsServer2003/evaluation/features/default.mspx
Configuring DNS Server: http://www.petri.co.il/install_and_configure_windows_2003_dns_server.htm
Configuring DHCP Server: http://www.windowsreference.com/windows-server-2003/install-and-configure-dhcp-server-in-win-server-2003-step-by-step-guide/
Configuring File Server: http://www.windowsnetworking.com/articles_tutorials/File_Server_Windows_2003.html
Configure Printing Server: http://www.brightrev.com/how-to/enterprise/55-best-practices-for-setting-up-a-windows-print-server.html
Configure FTP Server: http://support.microsoft.com/kb/323384
Configure Active Directory: http://helpdeskgeek.com/how-to/windows-2003-active-directory-setupdcpromo/
Configure Web Server: http://support.microsoft.com/kb/324742
All these are only some of his features.
I hope is useful to you and your friends
Mar 13, 2010 | Microsoft Windows Server 2003 Enterprise...
Dhcp setup on a Cisco 2851 router
Let's look at how to configure basic DHCP on an IOS-based router. For this example, we'll start off with the default configuration on a Cisco 2611 router running IOS 12.2. (The configuration should be the same—or very similar—on all IOS-based routers).
To begin, connect the router's Ethernet port to a switch, and connect the switch to a laptop, which will serve as the DHCP client.
To configure Cisco IOS DHCP, follow these steps, which include sample commands:
1.Configure an IP address on the router's Ethernet port, and bring up the interface. (On an existing router, you would have already done this.)
Router(config)# interface ethernet0/0
Router(config-if)#ip address 1.1.1.1 255.0.0.0
Router(config-if)# no shutdown2.Create a DHCP IP address pool for the IP addresses you want to use.
Router(config)# ip dhcp pool mypool3.Specify the network and subnet for the addresses you want to use from the pool.
Router(dhcp-config)# network 1.1.1.0 /8 4.Specify the DNS domain name for the clients.
Router(dhcp-config)#domain-name mydomain.com5.Specify the primary and secondary DNS servers.
Router(dhcp-config)#dns-server 1.1.1.10 1.1.1.116.Specify the default router (i.e., default gateway).
Router(dhcp-config)#default-router 1.1.1.17.Specify the lease duration for the addresses you're using from the pool.
Router(dhcp-config)#lease 78.Exit Pool Configuration Mode.
Router(dhcp-config)#exit
I hope this is helpfull for you.
Thanks
Vikrant
Oct 26, 2009 | Computers & Internet
Make additional DNS
Yes, all Windows Servers have the option to install DNS.
Set up a second Windows server and configure it to be a secondary server for your DNS domains on you current server.
Add the second DNS server's IP address to the secondary DNS field to your DHCP scope options and to all computers with static IP configuration so they will use it when your primary DNS is unavailable.
Don't underestimate Window's built-in Help and Support. It will help you install DNS and configure it.
Good luck.
Jul 29, 2009 | Dell Computers & Internet
DHCP installation problem
First of all, read this M$ article on setting up DHCP: http://support.microsoft.com/kb/139904
Secondly, check the following:
1. You have defined a valid scope and ACTIVATED it
2. You have AUTHORISED the DCHP server in Active Directory (see http://technet.microsoft.com/en-us/library/cc759688(WS.10).aspx)
3. Make sure that there are enough unused IPs in the address pool
Make sure that the DHCP server service is running - and check the EVENT LOG for errors
4. Make sure that there is no other, especially unauthorized, DHCP servers (i.e. router with DHCP enabled)
Actually the best article overall to review is http://technet.microsoft.com/en-us/library/cc781697(WS.10).aspx, which gives a big picture view regarding the role of DHCP autorization and what can happen in a mixed environment
May 21, 2009 | Microsoft Windows Server 2003 Enterprise...
Router not passing dhcp information from dedicated dhcp server on the LAN
Where are you trying to pass it to? If you are trying to pass it from the LAN to the WAN side, that won't work since DHCP functions on broadcast and routers separate broadcast domains.
Mar 24, 2009 | U.S. Robotics MAXg USR5461 (738168036790)...
Windows server
my suggestion is: without ADS, we cannot create a domain server(till 2003 server). because, ADS is only known as Server and also it is the primary record for a domain creation.
we can go for installing ADS, by two methods.
1. using "dcpromo" command
2. Go to Administrative tools on the control panel. we can see the manage your server wizard. work with this.
we can install some services later, like dns,dhcp,ris. but ADS is the primary part.
bye,
Jan 27, 2009 | Microsoft Windows Server Standard 2003 for...
Microsoft Windows Server Standard 2003 for PC Logo
964 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
