Question about IBM ThinkPad T43 Notebook
IBM T43 Bluetooth not working
I have installed the bluetooth driver in IBM T43 Laptop. The device manager is listing the bluetooth and says device is working properly. But  when I try to configure the bluetooth, it says no bluetooth device is connected. Connect it and make sure it is turned on..
Please help
  • Anonymous May 10, 2009
    I have exactly the same problem as sudhakar_kai has described above. I have used my bluetooth connection once or twice but from some moment it refuses to work, saying that my bluetooth device is turned off. And also, there was the device in the Device Manager (with yellow exclamation mark) but it disappeared after refresh.
  • Anonymous May 23, 2009
    Thinkpad T43 - Device manager shows that the Bluetooth Bis Enumerator is properly installed with the Broadcom Driver version 5.1.0.4601. But when trying to use it - error - Bluetooth Device not found.
Press Fn+F5 then push "Turn On. Now your bluetooth device is turned on, connected and working. :P
Posted on Jun 16, 2009
I need download bluetooth
You can find Bluetooth drivers for this laptop on this page. Click "Communications - Bluetooth" at the top and you'll scroll right down to the driver you need. Good luck!
Mar 13, 2011 | IBM ThinkPad T43 Notebook
I pressed fn + f5 but the bluetooth did not turn on
Make sure that the drivers are installed properly if so then you can update the drivers via below mentioned link,
Bluetooth:http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-61425click on 7jba10ww.exe and download the driver.
Optionally you might require to update the hotkey utility, sometimes it happens that hotkey software gets corrupt and does not shows any problem other than activating/deactivating
Hotkey:http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-74261#systemClick on 83vu18ww.exe and download the driver
Install the drivers and restart your laptop it should work then
Regards,Bilal
Jan 11, 2011 | IBM ThinkPad T43 Notebook
I HAVE DELL VOSTRO laptop. I am unable to get any bluetooth option in my notebook. plz suggest me what i should do.
In the device manager check if the bluetooth device is installed. If it is not installed, download the driver from support.dell.com and install it.If the device is listed under device manager and has an error on it, uninstall and reinstall. If the bluetooth device is not found under device manager, in the bios, enable bluetooth, save the changes in the bios.
May 29, 2010 | Dell Vostro 1014 Laptop Computer
Hello sir plz help i have dell inspiron 1545 with processor pentium dual core i am having problem with bluetooth sir i have tryed to install wireless 365 bluetooth modem driver but it is asking me to...
It is very likely that the Dell operator was right and the bluetooth option is not installed on your system. You will have to buy a USB bluetooth dongle or adapter.
click on control panel click on bluetooth devices if its there, is there anything listed as available? also in control panel click on system > device manager and see if any bluetooth devices are listed there. If not you don't have the option built in to your laptop
Jan 13, 2010 | Dell Inspiron 1545 Notebook
Sir,bluetooth is not working in my laptop
please describe which os ur using and bluetooth chip is detected in device manager if yes then go to support.dell.com enter your service tag no and download latest driver of bluetooth if bluetooth is not detected in device manager then press F2 at statup logo of dell and in hardware list u see one option bluetooth installed.
Dec 25, 2009 | Dell Studio 15 Laptop
Have reformatted the thinkpad t43 with windows xp. wireless adapter not visible in hardware devices. Help!
have you installed all the device driver for the hardware of the notebook? if not run all the device software including the driver for the wireless adapter, it will not appear if it is not windows compliant you have to provide the drivers
Nov 24, 2009 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Bluetooth not working
Try Downloading, Extracting and intsalling these Bluetooth Drivers:
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58617
Once downloaded and run, it will either extract and then run a setup, OR simply extract. If the file just extracts, the files will be located in C:\DRIVERS\WIN\Something...
Navigate there and run Setup.exe
Nov 08, 2009 | IBM ThinkPad T43 Notebook
Bluetooth is not working on dell laptop Xps m1330
Bluetooth is a optional feature, your laptop may not have the hardware - the bluetooth device installed inside even if it has the button.
If your bluetooth has worked before, with a phone or a wireless headset or similiar let me know and we can look into it more.
Sep 11, 2009 | Dell Latitude D600 Notebook
Ibm t43 laptop's bluetooth cannot find devices
This sounds like it is exactly what I scratched my head about when I first inhereted my T43 at work. If it is, you are going to laugh at how simple it issue is. IBM in their great wisdom made a custom control for the wireless network antenna and bluetooth antenna. Try:
Hit Fn+F5. This will bring up a window where you can control turning on/off each antenna. When you turn on the bluetooth, the symbol in the system tray should turn to blue and white and the little green bluetooth light just below the screen should come on. I hope this helps.
Mar 02, 2009 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Notebook Logo
5,526 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
