I don't know if this will help but I remember seeing a site that talks alot about older saws like the 103. it was under antique/vintage bandsaws. also bobvilla.com may help. Good luck its a good saw.
It most likely is your foot pedal. Unplug your
foot pedal and start the machine without it. If it works properly
without the foot pedal plugged in then your foot pedal needs repaired or
replaced. This worked for us with the NX400 machine and I am sure the
NX450 is closely similar. Don't bother to buy a Manual if you didn't
already get one with the machine. A Service manual and parts manual is
best; But just so you know they don't show the error codes unless you
are a qualified and authorized repair person for the machines. I got my
info from the repair man where my wife buys and repairs her machines. I
am an electronic technician and mechanic so I understand how this system
works. I will be repairing my wife's machines from now on.
This is most unfortunate if this either club track 510 or 612 your out of luck the electronics are no longer available. If these are either 510 or 612 you can get it repaired call National Gym Supply @ 1-800-496-7278
I’m and owner of the FAV6800AWW and know this machine.Sorry I can’t help you with your front loader.I feel the service charge and diagnosis given to you are in left field.If no one can help you in the FAV6800AW forum try the links below.
Here is a link to tech info for your machine MAH6500AWNdo a search Literature By Model I would also try reposting over in this fixya forum Problems with Maytag Neptune MAH6500A Front Load Washer?Maybe a repair person or knowledgeable owner in that forum can help you DIY the repair or give you some knowledge to possibly help control cost and time to repair.
Tom,
I don’t believe you will find a schematic for the control board.I have a FAV6800AW all I have be able to find is the wiring schematic found in the FAV6800AW/FAV9800AW Service Manual.
Is your machine out of the 5yr warranty period for the Control Board?I got Maytag to send me one.
Saw this on e-bay NEW - Maytag Washer LCD Control # 25001189
Good luck …Rich
Hello glendeza I saw your previous post and I feel you have a Control Board issue.If power cycling the machine at the 120VAC service outlet doesn’t clear the issue this could be a $300+ fix by a service repair person. This is a $1000 machine so you will have to make the decision to repair or not.Because you are not the original owner you may not get any service support from Maytag.The control board has a 5 year warranty. If you want to DIY a fix I would have to start by replacing the Control Board. If you are near the 19344 area and decide to junk the machine I would make you an offer for parts.Here is a link for the Service Manual. Down load and take a look.Plug your serial number into this Age Finder to look up Mfg. date.
