Question about Yahoo Mail
I can receive large files, but I cannot send 7.5MB files. I get message error 451.
    Scholar:
  • 34 Answers
Hello!
You will find that most email services put limits on the size of the outgoing emails that they will allow.  If you actually have a need for sending large files all of the time (I send huge data and CAD files myself) you either have to set up your own email server (not that big a deal, and it cuts out the hassles of dealing with your ISP) or use one of the email services designed for larger files.  A few of these are Pando, SendThisFile, PodMailing, and Send6.  I am not a particular fan of any one of these guys, have used them all to get the job done from time to time.
To try to eliminate the hassles of going to a website to send large emails, I eventually wound up setting up my own email server.  Since I have both Linux and Windows systems running here, I was able to take an older system, load it with Linux and set up a server without much of a problem.  But that solution is for me, where I routinely send 10-50 meg files to different divisions of the company or to customers.
I hope that this helps you out!
Ken
Posted on Jan 06, 2009
Problem with Microsoft Outlook 2007
As the issue happens during sending and/or receiving of emails, the usual suspects are having a virus scanner installed which integrates itself with Outlook or having a corrupt srs-file(srs stands for: Send Receive Setting).
The solutions in this case are quite easy;
§Disable your virus scanner's integration with Outlook
This is a recommended procedure anyway, even when you don't have the error. For more background information about this see: Disable virus scanner integration?
§Reset your srs-file
The srs-file contains the settings that you set via the Send/Receive dialog in Outlook (CTRL+ALT+S). To reset it, simply rename it to .old when Outlook is closed. For more information and step-by-step instructions see: Cannot Edit Send/Receive Settings
Also you can use these steps:
Go to C Drive> Program Files> Microsoft Office> Office 2007. After doing this you will see the PST files. Right click on it and go to the Properties and then select the Compatibility tab. Click on it to clear down all the Compatibility Mode Check Box. After doing so, click on Apply and then press OK. Restart the computer and your problem is sorted out.
If it useless use special tool.
See more: http://www.oemailrecovery.com/outlook-recovery.html
Regards!
May 19, 2015 | Microsoft Office Outlook 2007: Windows
Tip
How to receive large files through bluetooth in nokia 5800
You can receive large files in your phone if you have enough memmory on your memory card.If we receive a file through bluetooth , it will be stored in the message inbox.So if we try to receive a large file,the phone says not enough memory to receive.You can avoid this problem by changing the storage memory for messages.Before receiving large files through bluetooth,go to messaging.Then select options.Select the settings.Then select other.There you can see an option for memory in use.Select it and change the memory in use into memory card and press ok.Then receive the file through bluetooth.After saving the file,you can change the memory in use into phone memory.Thanks.
on Jan 08, 2011 | Cell Phones
Cannot receive large files
Yahoo cannot send message with more than 10MB attachment size. You need to break the file if it possible or zip the file to be less than 10MB.
Jul 15, 2010 | Yahoo Mail
Problem with yahoo mess 10..pls help
1. Before you attempt to transfer any files or photos, be sure that they are saved to your computer and that none are open, to avoid getting an error message
2. You may want to consider doing several smaller file transfers rather than a single large file transfer.
3. If you or your friend is behind a firewall and you're having difficulty transferring files or photos, try temporarily turning off the firewall to see if you're able to send them.
Feb 24, 2010 | Yahoo Messenger
Message trunicated??
Better use some online storage services like http://rapidshare.com/ to upload big files and then send only link to the file over email or open email account at Gmail (http://mail.google.com); they will allow you sending and receiving big attachments
Apr 02, 2009 | Microsoft Outlook 2003 for PC
Need to delete email w/2 large of attachment after clicking send
1. Go the File menu, then choose Work Offline in order to stop Outlook from trying to send all mails:
2. Switch to the Outbox.
3. You now have two options:
a. Move the message: you can drag-and-drop or use the Edit: Move to Folder menu item to move the e-mail to your drafts folder. This will allow you to re-open the offending e-mail and slim it down by removing the large attachments before attempting to resend it.
b. Delete the message: this will immediately remove the message from the Outbox and put it in Deleted Items.
4.
If you receive an error at this point that says the message is being transmitted, close Outlook, wait for Outlook to exit (you may need to use Task Manager and wait for the Outlook.exe process to exit), and then start Outlook again and repeat steps 2-3. In some cases, the item may not be released until Outlook has restarted.
5. Go to the File menu, deselect Work Offline to start sending and receiving mail again.
Mar 20, 2009 | Microsoft Office Outlook 2007: Windows
Picture Messaging
If your sympton is:
You see a red X with unknown error on your BlackBerry smartphone when sending picture attachments in an email message.
The service books for the email integration are corrupt
To resolve this issue, delete and resend the service books from the BlackBerry® Internet Service or BlackBerry® Enterprise Server.
or
Picture messaging allows the user to send and receive photos to and from their contacts.
Important: The Instant Messenger recipient must be online to send the picture.
To send pictures from your BlackBerry smartphone camera using <Instant Messenger>, complete the following steps:
  1. On the BlackBerry smartphone, preview a picture.
  2. Display the menu and select the Instant Messenger you want to use to send the picture.
  3. Complete the onscreen instructions.
To send a picture from within an Instant Messenger for BlackBerry smartphones application session, complete the following steps:
  1. Within the Instant Messenger session, display the menu and select Send Media. The Which Type dialog appears.
  2. Click Picture. The Pictures folder opens.
  3. Select the picture you want to send. A request is sent to the recipient indicating you sent a file and an option to Accept or Decline the file.
    • If the recipient clicks Accept, the Save File dialog opens. The recipient saves the file on the BlackBerry smartphone.
    • If the recipient clicks Decline, The sender receives a message indication the file transfer was declined.
or
The BlackBerry smartphone user is unable to send a picture as an email message from the Media application of the BlackBerry smartphone. The Send option is not present on the menu when the email message is sent using an email account that is associated with the BlackBerry Enterprise Server.
Although the current BlackBerry Internet Service supports large attachments or attachments that are in their native format, BlackBerry Enterprise Server software version 4.0 does not.
A BlackBerry smartphone that is provisioned with the current BlackBerry Internet Service uses it as the default method for sending pictures from the camera. As a result, when attempting to send a picture attachment from an email account that is associated with the BlackBerry Enterprise Server, the Send option will be missing from the menu as the image is in native format and size.
Upgrade the BlackBerry Enterprise Server to software version 4.1 Service Pack 2 or later, since support for large attachments or attachments that are in their native format has been introduced in that version.
Follow the steps below to send the picture attachment from the Messages application on the BlackBerry smartphone:
  1. Select Messages on the Home screen of the BlackBerry smartphone.
  2. Press the Menu key.
  3. Select the Compose Email option from the menu.
  4. In the To field, enter the contact address where the email message is to be sent.
  5. Press the Menu key again.
  6. Select the Attach File option from the menu.
  7. Browse to and select the picture to be attached to the email message.
  8. Send the email message.
Sep 24, 2008 | RIM BlackBerry Pearl 8100
Facing problem with outlook plz help
Either the message you are trying to send is too big, e.g contains a too large attachment, or your mailbox on the server is full...
Mar 31, 2008 | Microsoft Office Outlook 2003 for PC
Bluetooth LG TU500
I suggest reducing the size of the SD card to a 512mb and you should have no problem. There have been problems with the 1GB for these phones and I mhave 2 of these phones and they both have 512mb with no problem any larger and they keep giving error messages
Nov 17, 2007 | Lands Phones
Yahoo Mail Logo
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
