Question about Pioneer DEH-P5800MP CD Player
Dehp5800mp wire harness
Hi, i have a pioneer dehp5800mp that i am installing into honda civic 2000. i think i am missing a wire(orange/white) from the pioneer stereo harness. is there a possibility to see a picture of the wire harness and which wire is in what socket of the wire harness.
thanking you in advance.
ilan
  • ilanny25 Jan 06, 2009
    i am looking at the pioneer manual and it says the orange/white is "to lighting switch terminal". what is the function of this wire?
    also the manual does not have a picture of the stereo harness- so i cant tell which box is supposed to have this particular wire.
    please help.
    ilan.
    New Friend:
  • 111 Answers
Orange /white wire is power antenna wire i think.is your setup working????????.let me know the status..
Posted on Jan 06, 2009
  • nuwan chinthaka
    nuwan chinthaka Jan 09, 2009
    lighting switch wire is for illuminate the front panel of the set up.in my experiance give the direct supply for this wire swiched by main switch turnd on the power in ACC mode.check the exsisting harness for that type supply by using multimeter.and fix it to that wire.
    it will usefull to see your setup in the dark.
    nuwan.
I bought a Ouku 7" screen DVD Navi unit for my 2009 Honda Civic. There are 4 loose wires on the harness labeled as follows:
Orange goes to the switch on the emergency brake. This allows the DVD player to play movies with the brake on ( liability issue...people sued and bankrupted a manufacturer because they watched tv while driving and some people got killed) should be the light green wire at the switch on the ebrake handle.
Blue is used on a vehicle with factory analog steering wheel controls
pink is connected to the back up lights and activates the backup camera feature if you have a back up camera
blue w/white stripe...best guess has to do with infra red remote ...possible allows an ir eye to be installed.
I would suggest go ogling the model number for a wiring diagram or owners manual if you don't have one.
Nov 01, 2016 | Honda Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1984 - 1987 Honda Civic...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1984
1985
1986
1987
STEREO WIRING COLOR CHART:
Constant 12V+: White/Blue
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness:
1984, 1985:70-1388
1986, 1987:70-1720
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Coil
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Hatch Pin Switch
Parking Lights: Red/Black - (+) Light Switch
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Black - (-) Pin Switch
Door Lock: Green/White - (-) Driver's Kick Panel
Door Unlock: Green/Orange - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 01, 2010 | Honda Civic Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1980 - 1982 Honda Civic...
1980
1981
1982
Constant Power: White/Blue
Switched Power: Yellow/Red
Ground: To Chassis Metal
Illumination: N/A
Dimmer: N/A
Antenna: Drivers Side Pillar
Left Front (+): Red/Green
Left Front (-): Brown
Right Front (+): Blue/Green
Right Front (-): Gray
Left Rear (+): Red/Yellow
Left Rear (-): Brown
Right Rear (+): Blue/Yellow
Right Rear (-): Gray/White
NOTES: - none -
Metra Brand Wiring Harness: 70-1388
Tach: Blue - Coil
Hood Pin: n/a
Factory Disarm: n/a
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
I have 1993 honda accord im try to swap a 2000 honda civic radio but my honda accord all we have for speakers cables are red blue green yellow and white,i can't figure it out wich one goes were the 2000...
All cars with 4 speakers have 8 speaker wires (4 positive and 4 negative). The colors of the wires for these two cars are not the same. The only way to know which wire goes where is to get wire diagrams for both cars. Before cutting up your wire harness, check that the radio you're installing will bolt into your car and fit. Just swapping the mounting bracket may not work.
Mar 12, 2011 | 1991 Honda Accord
Is there anyone who can answer a question re color codes for matching wires from harness to stereo i have a pioneer stereo and and need to install it in a honda civic need to match its wire colors to...
hoy cr*p. Thats a big question. I'm used to the simple hook up of red = hot wire, black equal ground wire, and white usually goes to the speakers. MOST electronic equipment use red as the "hot wire"...or the wire that is the main electrical wire. If your colors dont match, you might talk to a shop that specializes in installing car stereos. Good luck. thats how they make their money, but depending on the price you may decide not to mess with it yourself. Just label the wires with tape when you find out.
Nov 06, 2017 | Pioneer Car CD Receiver, DEH-16
I need the radio wiring diagram for 88 honda civic hatchback
1988 Honda Civic Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: White/Blue
Radio Switched Ignition 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: N/A
Radio Amplifier Turn On Wire: N/A
Front Speaker Size: N/A
Front Speaker Location: N/A
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speaker Size: N/A
Rear Speaker Location: N/A
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Here can find the Stereo Wire Harness OEM Honda Civic 86 87 88 89 90 (car radio wiring installation parts)
Hope help with this.
Apr 26, 2010 | 1988 Honda Civic 2 Door
Installed car radio not turning on
do you have a tester to make sure you connected the wires right sometimes if you have the yeloow or orange wire for display you have to wire red wire and display wire together for power and make sure you ground the black wire good as well.. i remember buying a harness and there was one pin missing that didnt match up with of harness of the car
Feb 20, 2010 | 1998 Honda Civic
Red wire missing
the power wire goes above a blue wire or next to (white/orange) and (green) in top row if there is a space there
yellow should be above black
(white/orange) should be above (blue/yellow) i think
than red over blue
hope this helps
Jan 11, 2009 | Pioneer AVH-P6400CD Car DVD Player
I have a honda civic 1992 and i buy a sony car stero i have problem with de wiring like red goes with red black goes with black but de others color from my honda civic are difent can i have an ide
Battery
White/Yellow Stripe
or White/Blue Stripe
Accessory Yellow/Red Stripe Ground Black Illumination Red Dimmer Red/Black Stripe Power Antenna Yellow/White Stripe Left Front Speaker (+) Blue/Green Stripe Left Front Speaker (-) Gray/Black Stripe Right Front Speaker (+) Red/Green Stripe Right Front Speaker (-) Brown/Black Stripe Left Rear Speaker (+) Blue/Yellow Stripe Left Rear Speaker (-) Gray/White Stripe Right Rear Speaker (+) Red/Yellow Stripe Right Rear Speaker (-) Brown/White Stripe
Oct 19, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Pioneer DEH-P5800MP CD Player Logo
374 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
