Question about IBM ThinkPad R60 Notebook
Thinkpad R60 auto-restarted when shutting down
This happened when the R60 is only running on battery. I tried changing the battery but it does not help at all. When on battery only, I can shutdown using the hard button, but cannot boot-up the system again until when I connect the AC power.
When the R60 operates with an AC power, it can shutdown properly. However, once the AC power source is unplugged, the system boot-up.
Try pulling the battery out for a day running on ac only
Posted on Jan 06, 2009
Ibm thinkpad r60 hard drive not recognized by
make sure your operating system having a sata drivers,if u r using sata HDD,try to install vista or 7 it show HDD but if you run XP it not detect HDD because XP dont have sata drivers,or burn XP using Nlight software add sata drivers in that
Nov 14, 2009 | IBM ThinkPad R60 Notebook
Sound not operating in R60 thinkpad with ubuntu desktop 9.x.x
Make sure you have the most up to date drivers and that the unit is installed properly. Has this card ever produced sound? Did it stop working all of a sudden? If so then you can try to roll back the drivers to a previous version. If nothing works then uninstall the device and optain the installation drivers from the manufacturer and attempt to reinstall the device over again.
Jun 22, 2009 | IBM ThinkPad T60/R60 Series (14-inch wide)...
T23 Thinkpad turns off during boot after restart
My guess would be ;-
A power supply problem with the battery and/or power adapter
The most likely one.
The CPU is overheating and shutting down and if you wait a while and it will power it up again, it will then run for a while and shut down again.
This can be caused by a faulty fan (its not spinning and needs to be replaced) or the vents are clogged with dust (needs to be cleaned and you may need to remove the fan assembly to do this).
Jan 27, 2009 | IBM ThinkPad T23 2647 Notebook
Thinkpad x31 wont turn on
plz try by resiting the ram, take out the battery and try to boot in.
Jan 17, 2009 | IBM ThinkPad X31 2672 Notebook
Problem with a IBM ThinkPad T20 2647 PC Notebook
check ur hd for bad sectors...shutting down for no reason is usually this(bad sectors)
also check system information and check device manager..could be software problem/incompatabilty/no drivers installed/or two devices trying to use same resource and shutting down cos cant.
Jan 07, 2009 | IBM ThinkPad T20 2647 Notebook
Shuts down autometically
Also, have you changed anything lately? and, Did this just start happening out of the blue, or did something happen to cause this, ie... power failure, kicked the plug out, ran the battery completely dead, overheated, etc...?
Aug 26, 2008 | IBM ThinkPad T42 Notebook
IBM Think Pad T22 auto -shut down a few minutes
Try running it without the battery. Sometimes an IBM battery can develop a short and cause this. If it still does it without the battery, I'm afraid it's the power management chip on the motherboard, and the motherboard will need to be replaced.
Jul 10, 2008 | IBM ThinkPad T22 2647 Notebook
Hoe to reboot my computer lenovo r60
go to start in the left corner below in the desktop and click it then you will get "turn off" or "shut down" click on it then you will get the option for "stand by","turn off" and "restart", just click on "restart", and you computer will reboot, if you click on turn off then the pc will shut down
dont forget to rate the solution
May 17, 2008 | Lenovo ThinkPad R60 with Wireless Wide...
IBM ThinkPad R60 Notebook Logo
123 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
