Question about GE DWXR483EBCC Electric Dryer
My whrilpool mod. lgn20005qo gas dryer will start but the burner will not light
Thermal switch was no good
Posted on Jan 06, 2009
AMANA GAS DRYER, MOD.#LEA1OW/LGA10AW . CLOTHS WILL NOT DRY-IGNITER LIGHTS, BUT GO OUT BEFORE BURNER COMES ON.NO HEAT.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Amana Dryers
My Kenmore gas dryer mod 110.77522600 burner light when I first turn it on. After 4 mins. or so, it goes out. It will try to relight several time (igniter glows) but it never does.
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils. If you need further help try this link for troubleshooting a gas dryer
Jan 03, 2011 | Kenmore Dryers
Kenmore gas dryer mod.110-73942. burner comes on as normal. After 5-10 minutes running Cycles off, igniter ( new) glows but no burner ign. Also replaced the sensor adjacent the igniter.
The gas valve coil is bad. When the ignitor is glowing the gas valve should open and allow gas in to be ignited. Change the gas valve.
Aug 05, 2009 | Kenmore 63942 Dryer
Dryer runs. No heat
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jun 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whrilpool gas dryer lgn2000jqd stops heating half way
u have a maf coil the dryer has a prim/ second coil remove and replaced come in a kit
May 12, 2009 | Dryers
Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Apr 02, 2009 | Whirlpool LGV4634JQ Gas Dryer
Gas dryer won't dry
kbaker926:
This is a purchased product manufactured by another manufacturer for Sear.
It sounds as if have a flame sensor or a thermostat opening turning power off to the burner thus flame goes out.
If you are able to to catch the dryer just as it shuts off you would be able to do some ohms readings to find out what components have opened in the curcuit.
((((This is only if you are able to properly use and read a Volt-Ohm meter))))
These checks should only be done with the Electrical supply turned OFF and at least one wire disconnected from the component being tested
Woodychoppers
Oct 31, 2008 | Kenmore 75944 Gas Dryer
Whrilpool gas Dryer Mod # LGR54636JQO
probably your exhaust vent is clogged, make sure every inch of it is clean. as a safety measure, if it is clogged, your dryer will not produce heat, because it will have nowhere to go
Oct 26, 2008 | Dryers
How to light the pilot light on a Kenmore gas dryer.
no pilot light has glow bar ignition ..ck to see if bar glows when start button is pressed should be small plastic cap on bottom of dryer front remove it to ckd for glow and burner operation
Aug 29, 2008 | Kenmore 75962 Gas Dryer
Whrilpool gas dryer
Let it run. If nothing has changed, the dryer will go through several relight cycles and should eventually purge the lines of air.
Jan 15, 2008 | Whirlpool GGQ8831L Gas Dryer
GE DWXR483EBCC Electric Dryer Logo
144 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
