Question about Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 - how to lift cooktop panel to clean underneath?
Eeek, a mouse!  And it appears to have been under the cooktop beneath the sealed burners.  How can I lift the cooktop panel to clean the panel underneath, between the cooktop and oven?  The manual is NO help. Thank you in advance!
    Sergeant:
  • 311 Answers
Hey thats not a hard one for you.kill the power to your range [breaker ok]under neath the cook top frount where the top of oven door meets the cook top.in there are screews into the cook top .remove and lift up cook top it is hinged in the back .clean ,then put back together.you got it God bless ,tom
Posted on Jan 06, 2009
How to fix igniter for top burners
Hello. The range you have has a spark ignitor module inside the top, beneath the cooktop. Also, there is a spark ignition harness that has the four switches(snapped onto each of the burner valves at the control panel) connected together(daisy chained) that goes to the module and the incoming 120v supply. HOWEVER, the bigger issue here is getting to the module, harness, and other parts beneath the cooktop. Gas ranges are notorious for having the mount screws seize in the burners. When removing them is attempted, the heads usually snap off causing burner replacement to be necessary(which is why I listed the part numbers for the burners and screws). The cost of this can be high. I suggest calling for service if you are at all hesitant about working on the range.
BURNER SCREWS(8) WB1K84
BURNER HEAD RR WB16K12
BURNER HEAD LF WB16K11
BURNER HEAD RF WB16K10012
SPARK MODULE WB13K25
HIGH VOLTAGE HARNESS WB18K06
Oct 07, 2015 | Hotpoint RGB745 Gas Kitchen Range
How to access under cooktop on sealed burner gas range.
There should be some screws just under the front lip of the oven or just inside it. Remove them and the top should lift up.
Jan 23, 2015 | Tappan Kitchen Ranges
Can't seem to access Hotpoint Stove Pilot Light?
Your range uses electronic ignition, not pilot lights. For surface burners the igniter sparks when the gas valve is turned to the "light" position. All burners should spark when any gas valve is in the light position. For the oven the ignitor is also electric but does not spark but rather heats up or glows. What is the problem with your range?
Nov 30, 2014 | Hotpoint RGB745 Gas Kitchen Range
I am wondering how I'm supposed to light the pilot on a Hotpoint stove. I think I'm supposed to lift up the cooktop, but I can't get to lift up. It feels like its locked/screwed down somehow but I c
Hot point has 2 pilot lights on top... light them... then go to oven and light that one... it is a safety feature... no pilot on top kills the pilot in the stove.
.. since gas is heavier then air the company made sure if there was a gas leak on top that it would not be caught by oven and blow up.
Can't seem to access Hotpoint Stove Pilot Light? Also is there a second pilot light for the oven?
For the last 10 years or more there are no pilot lights on gas ranges. Modern ranges have an electronic igniter on the burners and a different type on the oven.
Whirlpool Electric Cook top Coil
there may be 2 screws on the rear/behind of the cooker top or on the front underneath the top when top oven door is open.
Sep 30, 2009 | Hotpoint RGB745 Gas Kitchen Range
Grey scum marking clothes
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Mar 23, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Oven and broiler won't come on. Cooktop burners are fine.
Have you run the self-cleaning feature recently? I had a similar problem on my stove of the same model, and it was the switch that detects whether the oven latch is engaged (if it gets stuck and thinks the latch is locked, it will not ignite the main burner or broiler). An easy way to check if that's the problem: without touching the latch, turn the controls to Clean. If the burner lights, that is your trouble.
Jan 24, 2008 | Hotpoint RGB745 Gas Kitchen Range
How to clean an oil spill
All of you are MORONS. the guy is asking "quite clearly", how to remove the bottom pan so he can clean under it. It's quite obviouse he understands how to clean the the main part of the oven. He just want to know HOW TO REMOVE THE BOTTOM PAN.......
Dec 25, 2007 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
1,122 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
John Tripp
John Tripp
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
