Question about HP DeskJet 1220c/ps InkJet Printer
Printing on thick paper
Show me how to print on thick card
  • harilalrajco Feb 02, 2009
    I put the photo paper at back of the printer but the printer did not load the photo paper why
  • jsnapper Mar 01, 2009
    Hi There, I have used Permajet papyrus 310gms in the past but now have trouble feeding it through my R1800 for some reason.
    Permajet highly recommend epson so no point in changing to another make it seemsn any ideas would be welcome .............Jon
The driver for this printer has a setting for thick paper. It is toward the end of the list of paper types in the HP supplied print driver. When "Thick photo paper" is selected, the printer releases some of the tension on the pinch rollers as the paper is being fed in. Otherwise, the paper is too thick and the last set of rubber rollers will not grasp it. Unfortunately, this feature is not included in the updated driver for Win XP. It only exists in the original Win 95/98 driver. It is not even in the HP supplied Open Source driver for Linux, either. I still maintain a dual-boot machine with Win98 SE because of this very problem.
Posted on Jan 24, 2009
  • jkirbyj Feb 02, 2009
    If selecting thick paper did not cause it to print properly, the large rubber print rollers may have dried out or hardened, so to speak. If that is the case, it is a pretty difficult problem to solve, as the rollers age and aren't adhesive enough, for lack of a better word. The symptoms of this is that it will start to feed the paper, enough to lift the paper sensor into thinking the paper is printable. But it doesn't quite get the paper under the print head, and it prints all over the inside of the printer mechanism instead. Several companies sell a product which is supposed to be a "printer roller rejuvenator", which primarily softens and swells the rollers a bit. I haven't used the commercial products, but I fixed mine with some regular household concoction from the garage.
When I print a thick blue line (about 3 inches thick) is printed also. How do I get rid of this?
Go into the computer and the click Printers and then Maintenance. do all the cleaning tasks including the one that cleans the paper path if there is one.
If you are printing a line that thick the inkjet head is releasing too much ink. If your menu is on card, you can only print successfully if the printer has a straight pass door at the rear of the machine so the card remains flat. The cardstock will smudge as it passes around the rollers. You can get over this by printing on quality paper and then putting them in a menu folder. I did this with my Inn's restaurant menus. The bar snack menus were printed on card using pass though and on a laser printer..
Jul 01, 2016 | Office Equipment & Supplies
Duplex printing with card stock paper jams in back on Brother MFC-9840CDW
I would try manually inserting the paper for the back side. Most of the time it's best to wait a few minutes before trying the back side to give it time to cool so it will lie flat.
Sep 08, 2017 | Brother MFC-9840CDW Laser Printer
Trying to print on card stock paper and get a paper jam Is there a setting for printing on card stock paper?
Hi Fuller90
Read your issue.
1. Kindly check the thickness of the paper. If the thickness of the paper or the card is more then normal paper, you will experience the paper Jam on this printer model.
2. You can try this step..... Take the Power cable out from the printer.
3. Press and hold down the power button for 35 seconds.
4. Now release the button and then plugin the power cable.
5. Check your issue.
Aug 20, 2010 | HP PSC 1350 All-In-One Thermal Printer
Project not printing when i put in card paper, but does print with copy paper, stops before finished, and error comes up
the printer gears becomeming tight due to thick ness of the card paper.do not use it as it will damage the printer paper pickup assembly.
Dec 10, 2008 | HP Office Equipment & Supplies
Thick paper wont print
Per the user manual you should try using manual feed, loading one piece of paper at a time into the try and then following the on screen directions(whould be press the stop button once after paper loaded), find attached a image showing how to set up the manual feed0c16087.jpg
Oct 21, 2008 | Samsung CLP 300 Laser Printer
C5280
when you hit 'PRINT' the window that opens up to complete the job will have a button called 'preferences'. Check to see that the paper selected isn't photo paper. You will have you choice of paper type thickness and size.
Jun 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
Paper type refers more to size & finish.
Glossy card stock, I would state the size of the paper & for the output quality pick best.
<print>::<properties> is a printer dialog, makes little difference what application it was called from.
Apr 23, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printing on glossy thick paper
perhaps the glossy thick paper isn't the indicated for the printer.
Try to change type of paper.
Dec 06, 2007 | Canon imageRUNNER C3200 Color Printer
Can't print onto thick card
Have you tried specifying the paper type and weight INSTEAD of the tray. Set the tray properties first, then print. If you leave it on auto tray it will use the tray that matches your paper type and weight.
Jan 09, 2007 | Konica Minolta bizhub C351 All-In-One...
HP DeskJet 1220c/ps InkJet Printer Logo
474 people viewed this question
Seeker5211
Seeker5211
