Question about Norcent Technologies LT-3225 32 in. LCD Television
Thick faint lines on screen
I just turned on my television. I've had it a year or so. You can see lines about 2 inches thick running down the screen. The lines are faint and at times hard to see but they're there. It could be a bad cable or else the TV screen itself. Has anyone experienced this problem or have a fix?
  • krispaw Jan 06, 2009
    The problem happens on all the channels but when the screen is black you can't notice it. The are two lines about 2 inches thick and it just looks like the color os a bit lighter in those lines. Does that help? I'm not sure what you mean by does it happen on all TVs. I don't have another TV to plug in and try of that is what you are asking.
    Thanks
    Scholar:
  • 90 Answers
It sounds like it could be the cable. Does the same thing happen on all channels and all TV's?
Posted on Jan 06, 2009
How do i remove the thick black line at the bottom of my tv screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 19, 2014 | Luxor 27 Inch 2 Shelf Mobile TV Cart -...
Vertical line down the screen about 2 inches thick
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPING THIS WILL HELP TO SOLVE THE PROBLEM....
Aug 06, 2011 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Aug 19, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
42 LG Plasma
It can be fixed but about $300 in parts.
May 18, 2008 | LG 50PX4DR 50 in. Plasma TV
Thick color lines on screen
Hi ,Sorry, this is not a solution. I have a question about your line. Is it transparent? (can you see through if the picture is bright)Does it remain there all the time if you change inputs? My LG 42" just had a blue transparent line appear on the right side of screen. Tried a few trouble shooting things w/ no change. About 1 hour later it went away. Did you find a solution and what was it?
Sep 05, 2007 | LG 42PX5D 42 in. Plasma HDTV
Norcent Technologies LT-3225 32 in. LCD Television Logo
218 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
