Good morning, my go gear is stuck, it will not allow me to operate any of the buttons. It just stay on one screen, and the computer does not recognize the go gear Hello. I'm having the same problem with my daughter's Philips Gogear sa3025/37. She was listening to voice recordings when the Gogear froze up. It is now stuck on one screen and my computer doesn't recognize it when it's plugged in.
  • pinkpuppi Jan 09, 2009
    Solved the problem! Gogear is no longer frozen and computer recogonizes it. Thank you so much!
  • 8,596 Answers
Make sure the hol/lock is not engaged. As logn as it's not engaged, run the Repair in Philips Device Manager. If the Device Manager will not recognize the player: Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
Posted on Jan 06, 2009
How do I now sign in to my other gmail accounts from the main account page
You can enable offline mode for your Gmail account, which links it to your hard drive where it stores messages.
Not all browsers and operating systems are supported, including Safari 4 on a Mac running the Snow Leopard OS and Google Chrome on all platforms.
Also, if you have enabled the multiple account sign-in, the offline reading feature is unavailable. Multi-account sign-in is a feature that lets you stay logged in to more than one Gmail account simultaneously.
Gmail offline mode requires that you install the Google Gears plugin that handles the processing and storing of emails on your local hard drive.
Open a Web browser and sign into your Gmail account.
Click the "Gear" icon on the upper right corner of the page and select "Mail Settings."
Go to the "Offline" tab and click the "Enable Offline Mail for this computer" button.
Click the "Save Changes" button.
Click the "Allow" link when Google Gears asks for permission to access your Gmail account. Once Google Gears receives permission, it may take several minutes for the messages to be downloaded to your computer.
Click and drag the Gmail favicon on the address bar to the desktop screen.
Moving and dropping the icon creates a desktop shortcut for your Gmail account.
If you click the "Gmail" desktop icon, then it will load your Gmail account, regardless if you are online or offline.
Oct 03, 2013 | Computers & Internet
Car shakes in reverse and engine light is blinking, gears will not change gets stuck in 2nd or 3rd gear
When the check engine light flashes it means DONT RUN IT or you will damage the engine. There are codes that your mechanic pulled from the computer, WHAT ARE THOSE CODES?
Apr 29, 2013 | 2002 Hyundai Accent
Can shift without applying brakes
There should be a cable that goes from the key lock to the shifter. That cable may be broken. There should also be a lock solenoid that requires you to push on the brake pedal to get the shifter out of park.
You would need to disassemble the console to get access to the shifter and then inspect these components.
Apr 14, 2013 | 1998 Saturn SC
My sony prs 350 ereader screen froze when i was reading my book when i try to turn it off the light turns red and it is fully charged
Hi!
If the Reader is frozen, you can try the following:
1. Disconnect the reader from the computer
2. Hit the reset button at the bottom of the reader for 3 seconds
3. Slide the power switch
4. Screen will blink and will show "Opening book"
5. Allow the reader to load and then see if operational
Note: If the reader get stuck again, connect it to the computer for 15-30 minutes and allow it to charge, make sure the red steady light comes on.
Good Luck!
eBookBoy
http://digialreader.freeforums.org
May 06, 2011 | Sony E-reader Portable E-book MP3 Player
Guages went dead, tranny not shifting from 3rd gear
Your transmission appears to be in "Limp Home" mode. This usually indicates an internal transmission problem that the computer has decided is too serious to allow regular operation. EVERYTHING, even your windshield wipers, has to get permission from your computer to operate. When the computer interferes with your operation of the vehicle, it sometimes gets overzealous and does other, more funky and entertaining things than it actually needs to do to protect or disable the vehicle.
The next place you need to go to in this vehicle is a transmission repair facility, attached to a tow-truck. They will confirm/eliminate the transmission as the problem. There are other things it could be, but it's telling you "transmission" and you need to have that confirmed/eliminated first, because it is almost always the most destructive and expensive fault a vehicle can develop. Don't drive it again, because it's cheaper to repair a transmission that has not grenaded.
Feb 14, 2010 | Oldsmobile Bravada Cars & Trucks
Phone doesn't turn on.
You should not allow the battery to fully drain,it will die sooner.
Remove the battery for 5mins, replace,and then try and turn on the phone.
Apr 07, 2009 | Motorola Mobility RAZR V3
you can try doing a soft-reset (off + volume (+) on the HDD6330 so probably the same on yours. This will reset the player and usually fixes crashes. Otherwise, I would return it if that doesn't work.
Jan 04, 2009 | Philips GoGear HDD6330 MP3 Player
Stuck on loading screen
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jul 31, 2008 | iLO (2 GB) MP3 Player
When I start my computer it goes to a black screen that tells me my computer did not start successfully and that that I can pick to start my computer in safe mode, safe mode with networking , safe mode...
while you in the booting screen like safemode , safemode with command prompt In that screen press F8 key you goto the other screen like safemode etc., select Enable Vga mode and select the operating system.If it is not work properly then you have reinstall the missing file in the operating system that means you have Repair the operating system.If you dont know how to repair the operating system plese inform to fixya.com
May 13, 2008 | Computers & Internet
204 people viewed this question
 Grubhead
Grubhead
