Question about Kenmore Dishwashers
Dishwasher leaks When we start the dishwasher we hear it try to start but no water enter the inside tub. If we hit the cancel button it shuts down and water starts spraying from underneath in the area where the main wate line hooks up.
    President:
  • 2,692 Answers
Sound like the fill valve is not working. I woudl check the hoze for a clogged screen ,then replace the fill valve if no clogs found.
Posted on Jan 06, 2009
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Dishwasher over flowed this morning. I hit the cancel/drain button and the water drained but kept coming in from the inlet valve. Had to shut the water supply off to the dishwasher.
Sound like the possibilty of the inlet valve regardless once the door is opened shut down power to the unit unless you have mulitiple failures going on at the sametime.
Nov 28, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Bosch Dishwasher will not power on
I saw my repair man do the following, which you might try...
Open the door and simultaneously press & hold down the power button with the 2 buttons used on your model to "Cancel & Drain." If the unit comes on it now is in self-diagnosis mode. Release the buttons and close the door. The unit should start to fill with water. Press the power button to exit the mode.
Jun 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher tub will not fill with water
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
May 24, 2009 | Dishwashers
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Water in dishwasher
if you push the start/cancel button it should start to drain water out. can you hear it drainin into the sink???can you at least hear thje drain pump activated trying to pump???perhaps its humming... if so id check your drain connection under the sink for blockage, and then next remove the drain pump itself and look for debris clogged within it stoppin drain
Mar 22, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Water will not go in dishwasher
first make sure your water supply had not been shut off under sink.next check the float switch inside the tub., In the front cornerof the dish washer floor (either left or right depending on model)when you open the door. Grab the float and lift slightly up it should move freely up and down, and although pretty faint you should hear a switch "click" as you doit. try it now!!!, if not id focus on bad water valve
Feb 20, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Kenmore dishwasher 15762
On the inside of the dishwasher (on the bottom), there should be a little "float" device, which tells the dishwasher when it has put enough water into the tub. Sometimes, this float gets stuck in the "up" position, so the dishwasher never puts any water in, but continues to run anyway as if it did. Try pushing down on the float to unstick it, then start the cycle over and see if it puts any water in.
Feb 06, 2007 | Kenmore 15762 Dishwasher
Dishwashers Logo
56 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
