Question about MSI Wind UmNotebook
How to disable delete option from right click on every folder & how disable command prompt using visual basic 6.0 please help me...
How to get rid of windows command processor
How to disable the Windows Command Prompt Note: To follow the steps listed below, you'll need administrator rights and have access to the Microsoft Windows Group Policy editor.
Click Start, and in the Run box type: gpedit.msc and press enter.In the Group Policy window, browse to the User Configuration\Administrative Templates and highlight the System folder.In the System folder, double-click "Prevent access to the command prompt."Change the Setting to Enabled, then click Ok. When entering the command prompt, you should now receive a prompt similar to the example below.
The command prompt has been disabled by your administrator.
Press any key to continue . . .
If you want to re-enable this feature, follow the above steps. However, instead of setting the option to "Enabled", change it to the default setting of "Not configured."
Mar 15, 2015 | HP Computers & Internet
Tip
How to remove the scvhost.exe Virus.
Svchost.exe is the name of a generic host process for services that run from dynamic link libraries (DLLs). A variety of worm malware programs spread a similarly named file <b>Scvhost.exe </b>via Yahoo! Messenger that blocks the Task Manager and Registry Editor, as well as use of the command prompt.<br /> <br /> <b><u>Warning</u></b><br /> Manual removal of Scvhost.exe may be very difficult as the removal process requires knowledge of the Operating System's command prompt and Registry Editor. If not performed properly, your computer system might experience permanent damage. Consequently, manual removal might be best for experienced users. Less experienced users might want to consider using an automatic spyware removal application, such as that offered by Trend Micro. This worm duplicates itself to different locations of shared folders. The duplicated program uses a folder icon that has an .exe file extension. DO NOT double click on any of these folders.<br /> <br /> <b><u>Follow these step by step instructions to remove the scvhost.exe virus.</u></b><br /> <b></b> <br /> <b><u>Step 1 (Turning off System Restore)</u></b><br /> This is so that if you ever need to use System Restore after you have removed the virus, it doesn't restore the virus aswell.<br /> <br /> If the operating system of the infected computer is either Windows Me or Windows XP, turn off System Restore while this fix is being implemented. To turn off System Restore within Windows Me, click <b>Start &gt; Settings &gt; Control Panel</b>. Double-click <b>System</b>. Select F<b>ile System</b> from the Performance tab. Left click the <b>Troubleshooting</b> tab and check the <b>Disable System Restore</b> box. Click <b>OK</b>. <br />To turn off System Restore within Windows XP, log in as Administrator and click <b>Start</b>. Right click <b>My Computer</b>" and select <b>Properties</b> from the shortcut menu. Check the <b>Turn off System Restore</b> option for each drive on the System Restore tab. Left click <b>Apply</b> and <b>Yes</b> to confirm when prompted. Click <b>OK</b>.<br /> <b></b> <br /> <b><u>Step 2 (Run in safe mode)</u></b><br /> Restart your computer in Safe Mode and log in as Administrator. Press <b>F8</b> after the first beep occurs during start up, before the display of the Microsoft Windows logo. Select the first option, to run Windows in Safe Mode from the selection menu.<br /> <b></b> <br /> <b><u>Step 3 (Accessing Command prompt)</u></b><br /> Access the command prompt. Click <b>Start &gt; Run</b>. Type <b>cmd</b>. Click <b>OK</b>. Then in the command prompt type <b>cd </b>to<b> </b>change directory then press the space bar. <br />Type the name of the full directory path of the folder containing your Windows system files. It will be either <b>C:\Windows\System </b>or<b> C:\Windows\System 32</b><br /> <b></b> <br /> <b><u>Step 4</u></b><br /> From the command prompt, type the following to unprotect the files for removal:<br /><b>attrib -h -r -s scvhost.exe</b> and press <b>Enter</b>;<br /><b>attrib -h -r -s blastclnnn.exe </b>and press<b> "Enter</b>;<br /><b>attrib -h -r -s autorun.inf</b> and press <b>Enter</b>.<br /> <br /> <b><u>Step 5</u></b><br /> Delete the files by typing the following from the command prompt:<br /><b>del scvhost.exe</b> and press <b>Enter</b>;<br /><b>del blastclnnn.exe</b> and press <b>Enter</b>;<br /><b>del autorun.ini</b> and press <b>Enter</b>.<br /> <b></b> <br /> <b><u>Step 6</u></b><br /> Type "<b>cd\</b>" to return to the main Windows directory.<br />Unprotect and delete the Autorun.inf file by typing the following from the Windows directory command prompt:<br /><b>attrib -h -r -s autorun.inf</b> and press <b>Enter</b>;<br /><b>del</b> <b>autorun.inf</b> and press <b>Enter</b>;<br />Type <b>regedit</b> and press <b>Enter</b> to open the Registry Editor.<br /> <b></b> <br /> <b><u>Step 7</u></b><br /> Locate the following entry:<br /><b>HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run</b>.<br />Delete the incorrectly spelled Yahoo! Messenger entry with the value<br /><b>c:\windows\system32\scvhost.exe.</b><br /> <b></b> <br /> <b><u>Step 8</u></b><br /> Locate the following key:<br /><b>HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon</b>.<br />Within the key, there is a <b>shell</b> entry with the value of <b>explorer.exe, scvhost.exe</b>. Edit the entry to remove the reference to Scvhost.exe, leaving Explorer.exe as the remaining value in the registry entry.<br /> <br /> <b><u>Step 9</u></b><br /> Locate the following key:<br /><b>HKEY_LOCAL_MACHINE&gt;SYSTEM&gt;CurrentControlSet&gt;Services&gt;<br /></b>Delete the following subkeys from the left panel:<br /><b>RpcPatch</b><br /><b>RpcTftpd <br /></b>Exit the command prompt and return to the operating system. Type <b>Exit</b>, and press <b>Enter</b>.<br /> <br /> <b><u>Step 10</u></b><br /> Reboot the PC.<br />If Scvhost.exe still resides on the computer, repeat these steps or try using an automatic removal program from McAfee or Symantec.<br /> <br /> <br /> <br />
on Feb 25, 2011 | Computers & Internet
Tip
How to Restore Disabled Folder Pane in Windows Explorer
Problem:
When you open Windows Explorer, the left hand Folders pane is disabled or gray or blank and the folder tree on left is not available.
Cause:
There may be an error in the registry. A required system file is missing or an incorrect version.
Solutions:
Close Windows Explorer.
Start the Registry Editor (click Start, Run, type regedit and click OK).
Expand HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main.
In the right-hand pane, locate the value named ExplorerBar. If present, delete it.
Restart Windows Explorer. If this does not resolve the issue,
The correct solution depends on the version of Internet Explorer that is installed on the computer.Internet Explorer 5.5 or lower
The preferred solution for computers with Internet Explorer 5.5 or lower is to upgrade to the latest version of Internet Explorer.
If this is not possible:
Open the folder C:\Windows\System. Check that the file browseui.dll is present. If it is not present, restore this file.
Internet Explorer 6
Open the folder C:\Windows\System. Check that the file shdocvw.dll is present. If it is not present, restore this file.
Open a command prompt.
Enter the command cd \Windows\System
Verify that the command prompt shows C:\Windows\System.
Enter the command regsvr32 /i shdocvw.dll.
Enter the command regsvr32 /i browseui.dll.
A message will appear confirming the successful registration of the files.
Now restart the sytem and confirm the problem is solved.
on Jan 17, 2010 | Computers & Internet
Installation error --- Error Code 2203 Please help, thanks
It's long but this should get your problem resolved and I would appreciate a Four thumbs up if it helps you ,If u have connected your printer only through the USB then leave out the last step.
Fatal Error 2203 - Windows XP
Windows Vista.
Giving permissions to C:\Program files folder may sometimes be difficult but here is the resolution.
Perform L3 uninstallation.
Delete digital imaging folder from C:\program files\hp folder.
Delete digital imaging folder from registry.
Deleting registry key below:
Registry Path - HKEY_LOCAL_MACHINE\SOFTWARE\Hewlett-Packard\Digital Imaging
On completing the above steps
Note: * Do not Restart the computer.
Click Start and type Run command in start search bar.
Right click command prompt and Run as Administrator
Type the following command
Net user administrator /active:yes
The above command will enable hidden account in Vista Operating system. Once enabled,
Once Restarted, "New user account will show up on logon screen called "Admin" and no password required."
Once logged in to Admin account
Reinstall the software.
After successful software installation, Please use the below command to disable hidden account feature
Net user administrator /active:no
1.uninstall the complete HP software, run windows clean up utility
2.under msconfig, disable MSconfig's sevices(non microsoft)
Aug 19, 2010 | Office Equipment & Supplies
Files hidden in memory card
open any folder in your pc. click on tools -- folder ---option -- view. select show hidden files and folders. deselect hide extension for known file types. de-select hide protected operating system files. Now you can view your hidden songs files. Kindly use attrib command with *.* option through command prompt with -s -h option to convert them back to normal files. Kindly do comment back if you don't know how to use cmd prompt. I'll post the complete procedure.
Sep 04, 2009 | Nokia 3110 Cellular Phone
DHCP Lease Expired
Open your network folder,Right click on you network connection,select status,select repair.
close network connection folder.
Or click start,all program,accesories,command prompt,when the command prompt opens,Type ipconfig /renew
once completed, type exit and hit the enter key
Please rate this a fixya
Feb 14, 2009 | Acer AL1716 F Monitor
How to enable folder options disabled by malicious command prompt code in Windows Xp ?
Here's How:
  1. Click Start
  2. Click Run
  3. Type REGEDIT
  4. Click OK
    The Registry Editor will now open
  5. Browse to the following key:
    HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
    Note: HKCU stands for HKEY_CURRENT_USER
  6. In the right pane, look for the value: NoFolderOptions
  7. Right click NoFolderOptions and select Delete. (When prompted with "Are you sure you want to delete this value", select Yes.
  8. Now browse to the following key:
    HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
    Note: HKLM stands for HKEY_LOCAL_MACHINE
  9. In the right pane, look for the value: NoFolderOptions
  10. Right click NoFolderOptions and select Delete. (When prompted with "Are you sure you want to delete this value", select Yes.
  11. Close the Registry by choosing File | Exit
  12. You should now be able to access the Folder Options menu. If not, reboot into Safe Mode and repeat the steps outlined above.
Jan 27, 2009 | Computers & Internet
My hard drive giving me problem
1st - Right click the drive icon, i think you will find Autorun at First, if it is..
2nd - Right lick and press explore
Before that you have to enable Show Hidden files and Folders in Tools Menu, Folder Options.
3rd - You will find some files, that is like command prompt icon and Autorun icon.
4th - Delete both the files and reboot the computer..
The problem is solved...
or use USB Disk Security V5.0.0.85 - www.freshwap.net and install.... it will delete the files...
Oct 03, 2008 | Vantec NexStar-3 External 3.5inch...
ITunes Install Problems
Hi, are you using Windows Vista? If so, go to the Start Menu, click All Programs, then Accessories, then right click on Command Prompt and select Run As Administrator.
In the box that appears, type: CD c:\windows\system32\ and then press enter.
Then type: regsvr32 vbscript.dll and press enter, then click OK.
Close the command prompt and try reinstalling itunes.
Hope this helps.
Sep 16, 2008 | Apple iTunes
Windowslive messenger not responding keeps coming up error8100030d
Error: 8100030d If you are receving the error code 8100030d when signing into Messenger, do the following: 1. Determine what version of Messenger is installed on the computer, and then upgrade Messenger if it is required: 1.a. Click here to determine the most recent versions of Messenger for each operating system. If you are not running the latest version for your operating system, please install the most updated version. 2. Delete the cache files for Messenger. Follow the steps below based on which version of Messenger you are using: 2.a. For MSN Messenger: 2.a.i. If you are running Windows XP or Windows 2000 click Start, click Run, type cmd , and then click OK to open the command window. 2.a.ii. If you are running Windows 98 or Windows ME, click Start, click Run, type command , and then click OK. 2.a.iii. At the command prompt, type the following commands. After each command line, press ENTER:
cd\
cd %appdata%\microsoft
cd "msn messenger"
del /s listcache.dat 2.b. For Windows Live Messenger: 2.b.i. For Windows XP
  • Right click on the Start button and then click Explore to open Windows Explorer. On the Tools menu, click Folder Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Click to clear the Hide extensions for known file types check box . Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them
C:\Documents and Settings\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Documents and Settings\ Your Windows logon name \Local Settings\Application Data\Microsoft\Windows Live Contacts\ Your Messenger email address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
2.b.ii. For Windows Vista
  • Click Start and then click Explore to open Windows Explorer. On the Organize menu, click Folder and Search Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Clear the Hide extensions for known file types check box. Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them.
C:\Users\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Users\ Your Windows logon name \AppData\Local\Microsoft\Windows Live Contacts\ Your Messenger e-mail address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
3. Try to sign in to Messenger again.
Aug 24, 2008 | Computers & Internet
MSI Wind UmNotebook Logo
554 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
