Question about Compaq Presario 5000 PC Desktop
Boot up problem
My desktop computer has been experience the problem of not boot up the i try the solution of changing the video card, memory, power supply including monitor but the problem is the same.. pls help what will be the possible solution for this.. thank ypu
  • Anonymous Jan 06, 2009
    what are cause of this
    New Friend:
  • 111 Answers
Maybe the problem is with your prossesor or motherboard.
check wether its power up and turnd on hard drivei tself.(use your ears)
and turn off after 10 secs.and remoove the power cable then tuoch the heatsink wether the cpu heat up.if it heats abnormally problem with cpu.
Posted on Jan 06, 2009
Mouse keyboard and monitor dont work upon power up
If it seems like it booted up all the way except the screen is black try the steps below.
Either the monitor or the video card inside the computer is bad. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your video card is good, but your original monitor is bad. If the Borrowed monitor does not display then the video card inside the computer is bad.
If it does not seem like it booted up all the way try the steps below:
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 07, 2012 | Dell Studio 540 MT Pentium DualCore E5300...
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
Acer ax3400g does not boot and light blinks twice
Either your memory, lcd monitor or the video card is bad.
Check the Memory by steps below:
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
I'm thinking that it might be your monitor because if the monitor was working and the video card was bad, you would get a No Signal message appearing on your screen.
Try another monitor on the computer. Borrow a monitor from a friend, family member, neighbor or co-worker and see if it works. If it does then your monitor needs to be replaced. If it does not work, then you've got a video card issue.
Check Video Card below:
If nothing ever posts to the screen then more than likely your video card is bad. Go purchase a Video Card that will fit into one of your open PCI Slots.
May 12, 2012 | Acer Aspire AM1640-U1401A Desktop PC
My pc just beeps every 2 to 3 sec no vedio
Either your video card is bad or you might have some bad memory. Does the video ever post anything on the screen when you press the power button to start the computer?
It really sounds like a memory problem.
Apr 02, 2012 | Computers & Internet
I have a HP media center m7360n , with a 920 intel pentium D processor. I changed the video card which required a more powerful power supply. I upgraded the ram and changed the power supply out to be...
Open your computer casing where the motherboard lies in and then remove the memory card, your new video card and then reset the BIOS, refer to the motherboard manual on how to do it. After resetting, plug in the memory card and video card. Close the casing and connect all the wiring. Power up your computer.
Nov 03, 2009 | HP Pavilion Media Center TV m7360n...
Computer cannot boot up
try replacing power supply or battery pack. If problem persists, you may have to change your motherboard.
Aug 25, 2009 | ASUS P4B266 Motherboard
Won't boot and doesn't even get to BIOS
You definitely have a hardware issue so you need to go through a process of elimination to figure out what it is.
1) try another video card (if you are using a video card)
2) try your on-board video (if you have it)
3) take a look at your motherboard to see if any capacitors look bulged
4) try another power supply (although the computer is getting power, it might not be getting "good" power)
Usually if it is the memory you will at least get a beep. This sounds like it is probably your mobo if it isn't your video card.
May 26, 2009 | Racer AcerPower F5 PC Desktop
Monitor gets scrambled and computer will not respond
bad video card memory. try to change the video card. if it's built-in to the motherboard then it's a shared memory, disable it in the bios and put in a new video card. check if PCI, AGP or PCIexpress type of card. if problem persists, check also the memory card. hope this helps.
May 11, 2009 | Computers & Internet
Pc don't boot up and the monitor starts up then powers off. i hear the hard drive start up
If your PC don't boot up but the monitor starts up the problem is from the hardware. I will give you a tip how to troubleshooting this problem replace the memory of your pc and put a good memory that the same frequency if your computer boots up your memory is damaged, but if the troubles is the same try to change the video card and then try to power it again. If is does not work email me again for some tips.
Jul 01, 2008 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
29 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
